Samsung UN46D6500VF - no display, odd lines and double image on half of display
  • viewfindr
    • Feb 2019
    • 37
    Hi there, I'm seeing some tips/advice on how to pinpoint what might be going on with my TV. This is a continued discussion from this thread, as users suggested I should start a new topic to discuss my problem. In summary:
    Before I took the set apart, I started to see a double image come on after the set is powered on for a few minutes. (attachment #1).
    I came across this YouTube video, which seemed to describe a very similar phenomenon from what I was seeing. (In summary, the video suggests unplugging one cable, and using a small clear piece of tape to cover various pins on the cable until the entire image comes back together).
    Then, I took the set apart, and started messing with the left ribbon cable on the T-Con board to try and cajole the picture together.
    However, it eventually started getting worse. After a while, I had a large white vertical band on the right side of the TV. Now, there is no picture at all when both ribbon connectors are connected, but the backlight still works. Audio comes through fine as well.
    Per suggestion in the previous thread, I tried the set with one ribbon cable disconnected at a time. With only the right cable connected, half of the picture comes together, similar to before with the weird artifacts and double image (see attachment #2). With only the other cable connected, there is no picture. I've swapped both ribbon connectors around and can confirm both cables appear to be fine. These are the voltages that I obtained from the Tcon board:
    With both cables connected:
    VONE: 0.2V
    VOFF: 0.1V
    AVDD: 0V
    VIN_12V: 12.7V
    With only one cable connected, and picture showing:
    VONE: 32.0V
    VOFFE: -12.2V
    AVDD: 17.1V
    I've also attached a high res image of the Tcon board from shop jimmy (attachment #3).
    I'm at a loss for what's going on - some have pointed towards a bad panel. However, according to the video I saw above, Samsung TVs do show black screens with half the TCon connected, so could it just be a bad tcon board?
    Thanks in advance for any tips or suggestions.
    Re: Samsung UN46D6500VF - no display, odd lines and double image on half of display
    VONE:
    VOFF:
    AVDD:
    Check the resistance between those test points against GND when both cables from T-CON to panel is connected and when one is not connected at a time.
    • viewfindr
      • Feb 2019
      • 37
      Originally posted by budm
      VONE:
      VOFF:
      AVDD:
      Here's what I got:
      Both cables connected:
      VONE: 41.8
      VOFF: 7.4
      AVDD: 6.3
      Good (working) cable connected:
      VONE: 41.6
      VOFF: 7.4
      AVDD: 7.5
      Bad (black screen) cable connected:
      VONE: 41.1
      VOFF: 7.3
      AVDD: 6.3
      Seems like there's only a meaningful difference in the AVDD?
        Are those reading in Ohms, K Ohms, or M Ohms?
        • viewfindr
          • Feb 2019
          • 37
          K Ohms, I believe since my meter was set to "200k". Thanks for the help!
            I am expect something <50 Ohms reading for typical failure due to bad caps on the tab bonding board.
            • viewfindr
              • Feb 2019
              • 37
              To clarify, does that mean you think the panel is fine, and the issue is in the Tcon board?
                • 12307
                • U.S.
                No, the board between the tcon and the panel, test the little MLCC caps for lower than 50 ohms, meter set to ohms of course with tv UNPLUGGED from power.
                • viewfindr
                  • Feb 2019
                  • 37
                  I just got down to that board, and realized that there are also test points for AVDD, VDD, HVDD, VCOM, etc. and a GND point. Testing the caps between each other (on each end of the MLCC cap) doesn't yield any readings with my meter set to 200. However, with the negative lead on the GND point, I get about 2 ohms on some of the caps. Seems like results are similar on both sides. Is this a good or bad sign?
                    May be show us good clear pictures of the tab bonding boards so we can see the caps, etc.
                    • viewfindr
                      • Feb 2019
                      • 37
                      Attached below - let me know if these are clear enough to see.
                      In order from left to right, first 3 are the left board, second 3 are the right board for the 6 tabs in total.
                      • budwich
                        • Jul 2015
                        • 3097
                        do similar voltage checks across each side (as you kind of did during the first post) to compare sides. Do this with one cable connected.... checking the difference between the two side. It is likely that the side that provides no picture / nothing when the tcon to panel cable is connected also sees little / no voltages on those test points.
                        • viewfindr
                          • Feb 2019
                          • 37
                          Some interesting findings today: with only the bad side plugged in and power applied, no voltages are present (0V across the board, screen completely dim). However, I found out that if I power the TV on with the "good" side connected and then switch the connection over to the "bad" side, then the vertical white strip comes back, and I get a partial image on the other half of the screen. The voltages then make more sense as well, and are actually quite similar:
                          "Good" side:
                          VDD 1.7V
                          AVDD: 17.1V
                          HAVDD: 8.5V
                          SVCOM: 7.6V
                          "Bad" side, after cable switched:
                          VDD: 1.7V
                          AVDD: 17.0V
                          HAVDD: 8.6V
                          SVCOM: 6.9V
                          What could this mean?
                          • viewfindr
                            • Feb 2019
                            • 37
                            Bump for suggestions - I find it curious that the panel partially works when the cables are switched around, but not when connected directly. Is this an indication of a tcon, mainboard, or power issue?
                            • Moreno83
                              • Jun 2014
                              • 2008
                              • The Netherlands
                              This is as BUDM says a problem in the t-con or panel. The D5000 and 6000 series are known for bad panels.
                              Let's wait for BUDM to respond , im curious!
                                • 12307
                                • U.S.
                                "Testing the caps between each other (on each end of the MLCC cap) doesn't yield any readings with my meter set to 200." this seems wrong, is your meter working correctly? try measuring some of the little MLCC caps on the tcon, probe on each end of cap, see what you get.
                                • viewfindr
                                  • Feb 2019
                                  • 37
                                  Just tried on the tcon, and couldn't get much of a reading either. Only one of the larger caps (labeled B1) came up with a reading of 0.2 ohms. None of the smaller units caused any movement. I tried two meters, but neither of them are very good, so maybe that's the issue?
                                    • 12307
                                    • U.S.
                                    Just tested some with a 5 dollar Harbor Freight meter, they read over 120, sometimes you need to re-apply probes to get a reading to make sure you have good contact, you need to look quick because it will give the reading then go back to 1 in about a second til you re-apply the probe.
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      None of the capacitors should read 0.2 ohms. I would lift it off the board and check again.
                                        B1 is not capacitor, it looks to be inductor.
                                        BTW, back to your reaindgs in post #1:
                                        VONE: 0.2V
                                        VOFF: 0.1V
                                        AVDD: 0V
                                        VIN_12V: 12.7V
                                        VONE: 32.0V
                                        VOFFE: -12.2V
                                        AVDD: 17.1V
                                        Those readings go down to 0V when the bad side cable is connected, that bad side is loading down the those switching power supply outputs. Are you 100% sure that the resistance readings of the caps on the tab bonding boards are done correctly.
                                        • howardc64
                                          TCL 49S405 double image
                                          by howardc64
                                          LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
                                          This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
                                          06-23-2025, 03:20 PM
                                        • Formaster
                                          Sony KD75XE9005 Bottom half double image
                                          by Formaster
                                          Hi guys,
                                          I'm tyred from these sympthom, if anyone helps me really big thx.
                                          When i open the connection and play with these ribbon cables, i can get back the image problem free. BUT after turn off and ON, the bottom half is ghosted/doubled again. Did'nt from touch, only reboot the TV. I have changed the ribbons from the other side, but the same. Anyone any idea please?...
                                          08-10-2021, 06:57 AM
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          08-18-2025, 11:38 AM
                                        • jason123
                                          Hisense 65R6E3 double-image / horizontal strips - TCON?
                                          by jason123
                                          Hello all. 3 years back, with your help, I replaced the LEDs on this TV. It's been working great. Yesterday, I turned it on (garage TV), and it has blurred horiz / vert lines as you see in photos. Definitely no physical hit or damage. Top 1/6th of the screen is perfect. Could it be main / TCON board? No tabs to cut on this model. Thank you...
                                          07-19-2025, 08:07 AM
