Tv Grundig Vision 2 22-2920 turn off after 2 secs
  • stomanata
    • Apr 2016
    • 82
    this TV stays on standby, but when i try to switch on via remote it
    start for 2sec and goes to standby again.
    Before this i change backlight transformer, dut to problem
    in secondary windings. Also i change 220nF X2 capacitor.
    It has PSU YTF194-08 V-0
    Also i notice that voltages are 5.3V and 13.5V, but no idea
    why both of them are ~10% up.
    Capacitors on output are with low ESR - tested with MESR100
    Any ideas what/where to check?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Tv Grundig Vision 2 22-2920 turn off after 2 secs
    Can you post some photo's of the circuit board as an attachment. Also of the capacitors and the transformer you replaced
    • stomanata
      • Apr 2016
      • 82
      Yes. Here are pics of both sides of PCB.
      There is signs of flux because i remove some parts from PCB to
      measure them. All parts that i test seems to be OK
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        So the transformer is the same part number (TMS93633CT) as the original so that cannot be the problem.
        I would check that the ends of each fluorescent tube are correctly seated into their connectors and not damaged.
        Open lamp protection overide using 560 ohm resistor from Pin1 to ground
        https://english.electronica-pt.com/lcd-repair?p=fan7314
        • nomoresonys
          • 12274
          • U.S.
          Are those burn marks on S206 and S207?
          • stomanata
            • Apr 2016
            • 82
            I`ll try to turn off OL protection. Btw i test all 4 lamps with
            my universal CFL tester and using digital wattmeter.
            First i connect 2 lamps, and then second pair of lamps.
            Both has ~13w consumption on app. half brightness.
            may be you mean S2006 and S2007 - CFL connectors?
            No, there is no burn. On the top there is some red mark with
            marker...
            Btw optocoupler seems to be a little burned around transistor side...
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              I do not think there is a problem with the opto-coupler since you have the 5V and 13V supplies.
              The photo of the back of the board is very out of focus. Perhaps you could post a good focused one.
              • stomanata
                • Apr 2016
                • 82
                But why 5 and 12v are high?
                I make test with resistor - it work for 5-6 secs and
                picture (blue sreen + no signal message) looks good, then
                i turn it off.
                I upload new pictures of back side.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  Are you 100% certain that all the lamps were working. With the overide resistor added did the lamps stay on until you turned off the set or did they turn off by themselves?
                  • nomoresonys
                    • 12274
                    • U.S.
                    Maybe check all the diodes, diode mode, tv unplugged from power, see if you get a reading in one direction then reverse the meter probes should be OL or 1 in other direction.
                    • stomanata
                      • Apr 2016
                      • 82
                      Yes, i`m sure and they work.
                      Here are 2 pics with 14secs between them + some secs before
                      start camera
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        +1
                        I would now do what nomoresonys has suggested and start testing the components and solder joints in that area.
                        Check you have 2.5V on Pin 6 of IC2006
                        • stomanata
                          • Apr 2016
                          • 82
                          +1
                          Thanks.
                          Wich area you mean?
                          I`ll check later for 2.5v
                          All diodes and mosfets seem to be ok. I desolder both mosfets that
                          driver CFL transformer - both are ok.
                          In fact open lamp protection make all my problems, right?
                          But mosfets, transformer and all lamp are OK. So, may be some
                          component in OL line is defective?
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            Can you measure the voltages at TP21, TP22 & TP34
                            TP21 =
                            TP22 =
                            TP34 =
                            and also if you have 2.5V on Pin 6 of IC2006
                            • nomoresonys
                              • 12274
                              • U.S.
                              The bottom left of the board in your picture looks kind of tore up.
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                TP21 =
                                TP22 =
                                TP34 =
                                What readings did you get. Have you found the fault?
                                • stomanata
                                  • Apr 2016
                                  • 82
                                  Sorry for my late reply.
                                  Which side - solders+smd or PTH elements?
                                  I try to measure all transistors and diodes that are relevant to OLP, but all of them look OK.
                                  About readings:
                                  TP21=1.84
                                  TP22=1.44
                                  TP34=0.6
                                  On pin6 of IC2006 there is 2.53v
                                  All this is with 560 ohm resistor to ignore OLP
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    Originally posted by stomanata
                                    About readings:
                                    TP21=1.84
                                    TP22=1.44
                                    TP34=0.6
                                    Can you also check TP93 and TP95 which I missed out of the above list to test.
                                    Then take the same readings ( including TP93 and TP95) but with the 560 ohm removed
                                    You need to check each point as you power up the set out of standby.
                                    • stomanata
                                      • Apr 2016
                                      • 82
                                      Now i test it but still with 560ohm resistor.
                                      TP93=1.96, but after some secs it drop to ~1.85-1.9
                                      Tp95= 1.71-1.75
                                      At the same time i check again TP21 and TP22. TP21 is ~1.85, but
                                      TP22 like my previous test is still low - this time was ~1.3v
                                      Did you mean now to try to measure all of them withou 560ohm resistor?
                                      TV will work for 2-3 secs and then will turn off.
                                      May be there is problem with CFL connected to S2006, wich is relevant
                                      to TP22?
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        I really do not know what else to suggest.
                                        The only thing I can think of is first remove the 560 ohm resistor.
                                        Next remove resistor R2054 (TP22) and switch on and check if you have the backlights.
                                        If you do not then replace R2054 and remove resistor R2053 (TP21) and again check if the backlights come on. If you do not then replace resistor R2053.
                                        Repeat this for resistor R2056 (TP93) and resistor R2057 (TP95)
                                        Hopefully this will identify which lamp circuit is causing the problem.
                                        • LEECH666
                                          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                          by LEECH666
                                          Good day ladies and gentleman!
                                          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                          01-19-2024, 05:46 PM
                                        • pajdek
                                          Lenovo Y700-17ISK turn on and off
                                          by pajdek
                                          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                          09-20-2023, 02:49 AM
                                        • RdeveLabs
                                          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                          by RdeveLabs
                                          To all the members here...
                                          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                          05-05-2025, 04:59 AM
                                        • robante15
                                          Acer Aspire 4520 won't turn on after reboot
                                          by robante15
                                          Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                          It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                          The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                          If I remove the...
                                          04-06-2024, 06:50 PM
                                        • masoksian
                                          Dell latitude e7470 not turn on .power buton on off and Run Power problem
                                          by masoksian
                                          I am dealing with the problem of turning on and off my Dell e7470 notebook.
                                          The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                                          The system does not turn on, there is no post.
                                          I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                                          The problem continues in the same way.
                                          I tried to turn on the Fn key, nothing came to the screen....
                                          02-15-2025, 12:08 PM
