Tv Grundig Vision 2 22-2920 turn off after 2 secs
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Tv Grundig Vision 2 22-2920 turn off after 2 secs
    I have just taken another look at some of the readings you have supplied. TP34 = 0.6V?
    but D2017 should have 0.7V across it and the emitter / base voltage of T2002 should also have 0.7V across it so the base of T2002 to ground should measure approximately 1.4V minimum to turn on the transistor.
    • stomanata
      • Apr 2016
      • 82
      I don`t know about TP34. D2017 and T2002 are OK.
      I remove 560 ohm for OLP and remove R2054.
      Turn on TV, but it start to work for 2-3 secs and then turn off.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Resolder R2054 back in place and repeat the process for each of the other 3 resistors.
        • stomanata
          • Apr 2016
          • 82
          Ok. Thanks. I`ll do it
          • stomanata
            • Apr 2016
            • 82
            The result is the same - every time it start for 2-3 secs and
            then turn off
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              #26
              So with all 4 resistors removed one at a time, the lamps still switch off after a few seconds?
              What is the voltage at OLR pin 2 of IC2006 with the 560 ohm resistor still disconnected.
              With the set off and your meter set to diode mode can you check D2017 and T2002.
              T2002 should read 0.7 between base (TP34) and emitter (TP36).
              • stomanata
                • Apr 2016
                • 82
                #27
                Yes - i remove resistors one by one and every time it start for 2-3 secs.
                Voltage of OLR when it work is 0.1V.
                D2017 and T2002 are OK - i test it with removing them from PCB.
                Also 4 resistors are 33K.
                And yes - it is 0.7V. Base-colector is 720, and base-emiter is 724mv
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  #28
                  Was the base/collector voltage (0.72V) measured when it was out of circuit because if it was then the transistor is faulty.
                  Other than that I cannot think of anything else to try other than replace the FAN7314
                  • stomanata
                    • Apr 2016
                    • 82
                    #29
                    It was measured on PCB.
                    May be fault in transformer is caused fault in FAN7314?
                    But if i shunt OLP everything work, but there is high frequency noise - something
                    overload system...
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      #30
                      What did collector/emitter (TP33/TP36) resistance read with meter in diode mode, the 560 ohm resistor removed and the set switched off?
                      • nomoresonys
                        • 12274
                        • U.S.
                        #31
                        Caps C2067, C2069, C2015 and the one next to it checked out alright?
                        • stomanata
                          • Apr 2016
                          • 82
                          #32
                          T2002 soldered on PCB
                          1. negative on emiter, possitive ot colector - 1671
                          2. Possitive ot emiter, negative on colector - 1091
                          About C2067 and other next to connectors...
                          I use tester like this https://www.aliexpress.com/item/3299...archweb201603_
                          but it start from 25pF, so on all of them it show "unknown or damaged".
                          I try with multimeter on 2Mohm to check in both directions and multimeter
                          didn`t read any resistance.
                          Now i`ll try to desolder them and check it 2pcs at once.
                          • stomanata
                            • Apr 2016
                            • 82
                            #33
                            i can`t test them
                            i solder 3pcs in paralel, this must be 45pf and try to test them
                            but again it show "unknown or damaged".
                            How can i test them?
                            May be if i solder diode in series and connect it for short time to
                            AC230V and then to check is there spark? But capacitance is too small, so
                            may be it will not help me...
                            • nomoresonys
                              • 12274
                              • U.S.
                              #34
                              To test the capacitor with a multimeter, set the meter to read in the high ohms range, somewhere above 10k and 1m ohms. Touch the meter leads to the corresponding leads on the capacitor, red to positive and black to negative. The meter should start at zero and then moving slowly toward infinity. Suppose it could still have bad/low esr tho.
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                #35
                                Can you use your tester and test that transistor T2002 out of circuit.
                                • stomanata
                                  • Apr 2016
                                  • 82
                                  #36
                                  This situation with meter from zero to some readings is for high capacitor - some
                                  microfarads. This capacitors are 15pf, this is too small and can`t use this method.
                                  T2002 outside PCB also is OK
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    #37
                                    Other than changing the FAN7314 I don't know what else to try. Anyone else have any ideas?
                                    • nomoresonys
                                      • 12274
                                      • U.S.
                                      #38
                                      Change m out to rule m out I guess.
                                      • stomanata
                                        • Apr 2016
                                        • 82
                                        #39
                                        Oh... it is too complicate.
                                        FAN7314 drive transformer and receive feedback from lamps.
                                        OLP cause the TV to stop working, but why?!?!?
                                        From 3 lamps i measure ~2v, and from 1 lamp i measure ~0.2v.
                                        Now i try to change capacitor next to connector with 0.2V and put it
                                        on opposite lamp (from #4 to #1 for example). Again on this connector
                                        i have 0.2. So it is not problem in 15pF capacitor.
                                        May be it is problem with this lamp, lets name it as #4.
                                        But with my backlight tester i connect:
                                        digital wattmeter - computer psu - backlight tester.....
                                        It has 4 outputs, but cables are short and i can connect only 2 lamps.
                                        I connect #3 and #4 and power them up. Wattmeter read ~13W.
                                        Then i disconnect them and connect #1 and #2. Wattmeter again
                                        read ~13W.
                                        This mean that all 4 lamps has the same power consumption.
                                        When i power TV with 560 ohm resistor on blue screen backlight seems to be OK.
                                        But something broke OLP and tv goes off.
                                        TV has burned 1 (of 2) secondary windings of HV transformer.
                                        For me there is something about OLP line, but all components seems to be ok.
                                        May be there is problem that happen when TV work. Without power socket when
                                        i measure component by component all looks fine...
                                        For now i see 2 ways to fix it:
                                        1. To continue to work with 560 ohm, but this is danger.
                                        2. To buy led backlight and to try to change backlight. I never do this, but
                                        i hope that i can do it
                                        Other solutions?
                                        IF it is 100% sure that FAN 7314 is defective - it is not problem to
                                        buy new one and to replace it.
                                        • stomanata
                                          • Apr 2016
                                          • 82
                                          #40
                                          ???? i can`t understand this...
                                          • LEECH666
                                            Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                            by LEECH666
                                            Good day ladies and gentleman!
                                            I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                            This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                            I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                            01-19-2024, 05:46 PM
                                          • pajdek
                                            Lenovo Y700-17ISK turn on and off
                                            by pajdek
                                            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                            09-20-2023, 02:49 AM
                                          • RdeveLabs
                                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                            by RdeveLabs
                                            To all the members here...
                                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                            05-05-2025, 04:59 AM
                                          • robante15
                                            Acer Aspire 4520 won't turn on after reboot
                                            by robante15
                                            Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                            It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                            The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                            If I remove the...
                                            04-06-2024, 06:50 PM
                                          • masoksian
                                            Dell latitude e7470 not turn on .power buton on off and Run Power problem
                                            by masoksian
                                            I am dealing with the problem of turning on and off my Dell e7470 notebook.
                                            The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                                            The system does not turn on, there is no post.
                                            I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                                            The problem continues in the same way.
                                            I tried to turn on the Fn key, nothing came to the screen....
                                            02-15-2025, 12:08 PM
