LG 42LV355T Blue screen No picture
  • notallbad
    • Oct 2012
    • 1190
    Re: LG 42LV355T Blue screen No picture
    Could you recommend a suitable replacement for the inductor L702 please.
    I have found the Q409 (AO3407A) on ebay.
    Thanks budm, you have been a tremendous help!
    • notallbad
      • Oct 2012
      • 1190
      Quick update,
      replaced the T-con D109,
      the main Q409 & L702(with fuse, not yet knowing what to replace the original with)
      and the TV is working again.
      However, there is no speaker audio.
      Headphone jack works fine with all inputs hdmi, pc audio in, scart etc...
      Tv def not in 'mute', volume cranked up, menu audio setting set to 'auto' and both speakers do work.
      Get 2.9v Hp_det with hp out and 0.3v with hp plugged in.
      Theres 24v at the amp i.c.
      Theres 0v on Amp Mute, not sure if this should be high or low.
      Applying heat to the board makes no difference.
      With the hp plugged in or out the following volts remain the same:
      Q1106
      B - 0v (Side_HP_Mute)
      C - 2.9v
      E - 0v
      Q1105
      B - 2.9v
      C - 0v
      E - 3.5v
      Have confirmed the hp plug contacts do engaged/disengage.
      All 4 speaker outputs (L+/- & R +/-) are shorted.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        May be stupid of me to ask but have you reconnected the speaker connector to the mainboard. Check the mainboard connector solder joints are good. I have had solder breaks in the socket on the mainboard as a result of plugging in and out the speaker connector.
        • notallbad
          • Oct 2012
          • 1190
          thanks, yh the speakers are def connected and solder joints are all good!
          • vinceroger69
            • Mar 2012
            • 6714
            Factory reset tried?
            • notallbad
              • Oct 2012
              • 1190
              Yh, I did try that from the user menu but no joy.
              From the service menu there does not appear to be a reset option.
                • 12274
                • U.S.
                #27
                A firmware updates sometimes fixes audio issues.
                • notallbad
                  • Oct 2012
                  • 1190
                  Beginning to think its the NTP-7100 ic at fault.
                  Don't really fancy trying to replace it until all other options have been exhausted.
                  Not sure I will be able to do it successfully but would have a go if necessary and as a last resort.
                    • 12274
                    • U.S.
                    #29
                    Try in audio settings-sound mode and hit the reset option if you didn't already.
                    • notallbad
                      • Oct 2012
                      • 1190
                      yh tried the Audio 'reset' first before the 'Factory reset'.
                      Even tried disabling headphone in service menu, from '1' to '0'.
                        • 12274
                        • U.S.
                        #31
                        Did you recheck the service menu to see if the setting stayed 0?
                        • notallbad
                          • Oct 2012
                          • 1190
                          yh, power cycled and checked!
                          Current fw version 04.30.01
                          Is there a way to do fw update via lan?
                            • 12274
                            • U.S.
                            #33
                            Sometimes plug and unplug headphones many times will work.
                              • 12274
                              • U.S.
                              #34
                              Maybe hit the amplifier IC with a little heat??
                              • notallbad
                                • Oct 2012
                                • 1190
                                Tried this also sprayed in some contact cleaner.
                                • notallbad
                                  • Oct 2012
                                  • 1190
                                  Had no effect either
                                  • notallbad
                                    • Oct 2012
                                    • 1190
                                    Cant find fw anywhere at the moment.
                                      • 12274
                                      • U.S.
                                      #38
                                      Ok, I had a typo in the search.
                                      • diif
                                        • Feb 2014
                                        • 6978
                                        • England
                                        #39
                                        It's here.
                                        https://www.lg.com/uk/support/softwa...e=42LV355T.AEK
                                        • notallbad
                                          • Oct 2012
                                          • 1190
                                          thanks, just found it too, cheers.
                                          Will try it and see.
                                          • Daren87
                                            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                            by Daren87
                                            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                            08-13-2023, 03:25 PM
                                          • kca
                                            by kca
                                            Hello all ~
                                            08-31-2025, 06:38 AM
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
                                          • alltvrepairs
                                            Lg TCon test pins for screen test
                                            by alltvrepairs
                                            i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                                            Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                                            Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                                            Appreciate your help....
                                            06-13-2025, 06:33 AM
                                          • arbitarytwist
                                            Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                                            by arbitarytwist
                                            Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                                            Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                                            03-01-2025, 01:16 PM
