Diagnosing EAX64905001
  • pi3141592
    • Apr 2020
    • 8
    • United Kingdom
    Hi All,
    I am trying to diagnose a EAX64905001 power board. The back-light will not come on. I have tested the LEDs and they are fine.
    From reading another post - if I short 3.5V and PWR_ON with a 1k resistor - these are voltages I get.
    PIN --- OUTPUT
    3.5V = 3.47v
    24V = 24.7v
    12V= 11.94v
    If I need to test the LED+ and LED-. Do I need to short DRV_ON with 3.5V? (I'm guessing this stands for LED DRIVER.)
    Many Thanks, J
    • 12192
    • U.S.
    Re: Diagnosing EAX64905001
    Yes, give it a shot, see if the backlights come on.
      • 12192
      • U.S.
      Can try test #3 below, that will tell us if your getting the right voltages and proper signals from the mainboard too.
      • neilc6
        • Nov 2015
        • 1550
        32LN series? Probably bad backlights. How are you testing them? You can remove the panel and see if they flash or check this Shopjimmy video. DRV ON turns on the backlights. Make sure it goes high when you turn on the tv.
        https://youtu.be/2pyuXwNkBMA
        • R_J
          • 9535
          You can also check the voltage on P801-4 LED+, You need to monitor this voltage when the tv is first turned on. Then do the same check on P801-1.
          • pi3141592
            • Apr 2020
            • 8
            • United Kingdom
            Hi All,
            Thanks for your replies. I've checked LED+(Pin4) and LED-(Pin1) on P801 when the DRV_ON is shorted to 3.5V and the voltages are in the mV range and jumping allover the place.
            Anyone seen symptoms like this? is it likely the chip IC801(MAP3202) is faulty?
            I have also tested the LEDs with a donor board and so I know they are good.
            Many Thanks, J
              • 12192
              • U.S.
              "If I need to test the LED+ and LED-. Do I need to short DRV_ON with 3.5V? (I'm guessing this stands for LED DRIVER.)" Yes, do it with 2 resistors pwr_on and drv_on both to 3.5 stndby, see if backlights come on and stay on if they do the powerboard and backlights are ok. Did you do it??
                • 12192
                • U.S.
                We can't help if you don't do the tests requested, we don't have the tv in front of us.
                • dick_barton
                  • Aug 2015
                  • 6642
                  • Wales
                  What dc voltage do you have at these pins of the MAP3202
                  VCC Pin 2 =
                  EN Pin Pin 1 =
                  REF Pin 8 =
                  Readings given from an earlier post on this forum.
                  What dv voltage do you have at P802
                  • ngth82
                    • Jul 2015
                    • 541
                    +1 to post #7 from nomoresonys.
                    You don't want to directly short pins together. A small value resistor (the through hole, legged kind) - ~10K to ~100K range should do just fine. The idea is to provide a pull-up voltage. Not much current runs through this at all so you don't need to worry about the IR drop across it.
                    -Thomas
                    I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
                    • R_J
                      • 9535
                      The supply that gives you +24 volts, also provides the base voltage for the led's from D204, through L801, so you should have at least +60v on L801 when you have the PWR-ON forced on. (A 1K resistors is recomended) anything higher might not turn on the power supply causing you to think there is a PS problem when there is not.
                      Check J34 (should be +24v)
                      Check J14 (led base voltage)
                      • pi3141592
                        • Apr 2020
                        • 8
                        • United Kingdom
                        Hi All,
                        I shorted PWR_ON and DRV_ON through a 1K resistor. Then I checked the voltages on MAP3202 and got the results below.
                        1 - EN 2.9V
                        2 - VCC 11.9V
                        3 - GATE ~0V
                        4 - GND 0V
                        5 - CS 0V
                        6 - RT 3V
                        7 - SYNC 0V
                        8 - REF 5V
                        9 - PWMO ~0V
                        10 - OVP 2.8V
                        11 - PWMI 4V
                        12 - COMP ~0V
                        13 - FBP 0.8V
                        14 - FBN 0V
                        I went ahead and touched up the solder on on all the pins. Put it back together and it all seems to be working now. Not sure if that actually made a difference or the act of me taking it apart and putting it back. Will see how long it lasts.
                        Well hopefully this tread may help someone else out.
                        Thanks all for your input.
                        J
                          • 12192
                          • U.S.
                          Good to hear, yep the solder joints should should be one of the first things looked at, lots of times a bad joint is easy to spot and if that's all that's wrong can save a lot of time wasted doing a bunch of other tests, just because they didn't check the simple junk first. (Karl Childers rules)
                          • litec systems
                            Electronics is
                            • Feb 2018
                            • 97
                            Originally posted by neilc6
                            Hi
                            Could you please help me diagnose my(EAX64905001) 32Ln5400. Psu too? If so should i open a new thread or you can help me Here ( so iv someone will find this page from Google he'll have more troubleshooting ideas at one post + maybe the above dear members might be able to help me too?
                            The issue is no standby voltage no matter if the mainboard is connected or not.
                            Basically the mosfet + its 1kv capacitor + a 2w resistor + the fuse blown up ( known issue on this set)
                            So I've replaced them with new ones, but didn't knew that I have to pay attention to the fact that its a plastic ( isolated) mosfet
                            So as I've solder it up, the fuse got blown right away.
                            It tooks me time to understand that. Then I've isolate the mosfet from the heatsink, and plugged it in.
                            Now the tv isn't blowing up the fuse or something, it looks like there is a power to the main cap and not on the secondary side( I'm little afraid to probe the mosfet to prevent a short if i accidentally move my hands
                            Anyway
                            Do you have an idea what it could be and how to fully diagnosing it?
                            I suspect the mosfet isn't compatible with the PS \ it's got bad after the short because I haven't isolated it\\ the mosfet ic.., how could I test the mosfet ic?
                            Do you suspect that something else fried on the PS?
                            Hope you'll be able to help me out with this issue
                            Thanks alot!! :-)
                            • dick_barton
                              • Aug 2015
                              • 6642
                              • Wales
                              Do you have the screen label numbers eg Qxxxx, Cxxxx, Rxxxx and what was the original mosfet part number (printed on it) and what did you replace it with part number?
                              A picture is worth a thousand words so photo's of your boards would be helpful.
                              • litec systems
                                Electronics is
                                • Feb 2018
                                • 97
                                Hi
                                Thanks so much for your reply! 🙏🙏😃
                                By "Screen label" you meant to the sticker on the chasis? If so I've attached a picture of it. ( it's says 32ln542z because it's a local model number) but it looks the same as the international \ USA models ( the difference is probably the 1080p vs 720p but according to the videos on YouTube, they're all build from the same boards, just different panels + firmwares)
                                About the Mosfets
                                The original one was MDF11N65B
                                And I've replaced it with an st 15NM65N
                                g408t v6 *
                                chn 150 *
                                * ( the "0" might be "o" lol ST uses special font that I'm not always identify the characters 😂😂😂
                                  • 12192
                                  • U.S.
                                  Some of your solder joints look a little funky as well, maybe touch them up.
                                  • litec systems
                                    Electronics is
                                    • Feb 2018
                                    • 97
                                    Hi
                                    It's because It didn't worked ive tried on the solder joints and added more solder to it that's why It looks like that...
                                      • 12192
                                      • U.S.
                                      [/url] https://www.google.com/search?q=exam...w=1280&bih=645
                                        • 12192
                                        • U.S.
                                        More examples: https://learn.adafruit.com/adafruit-...ommon-problems
                                        • mostachio
                                          Looking for help diagnosing a 65" Panasonic Viera TV - TH-65DX700Z (Turns on - Clicks - Turns off)
                                          by mostachio
                                          Hi Badcaps,
                                          I've had a friend discard a TH-65DX700Z Pansonic Viera Television and I've decided to have a go at repairing it. If possible could I please get some advice in terms of diagnosing the problem so I can purchase the appropriate parts for repair whether it be components, a repair kit or a replacement board. I am happy to post pictures if required.
                                          TV Details:
                                          Model # - TH-65DX700Z
                                          Symptoms:
                                          The television turns on and displays a picture then makes a clicking sound and turns off.
                                          I haven't opened it up yet but...
                                          09-04-2024, 02:32 AM
                                        • choucroutman
                                          Need help diagnosing why my TV isn't working anymore
                                          by choucroutman
                                          Hello, my LG OLED55C8PLA TV stopped working, and here's what happened:
                                          Around noon, it stopped turning on, meaning the screen stayed off, I heard a ticking sound when I tried to power it on, and the red LED light blinked 3 times. Afterward, nothing would happen for about 1 minute, and then the same cycle would repeat. A few days later, there was no more red LED blinking, and whether I tried turning it on with the remote or the power button on the back, it wouldn’t respond. I’ve tried some "quick fixes" I found online, like unplugging the TV and pressing the power button for...
                                          08-04-2025, 03:10 AM
                                        • JJ8409
                                          Need help diagnosing the NM-D471 REV 2.0 motherboard for a LENOVO laptop.
                                          by JJ8409
                                          I need your help with an issue I'm encountering while diagnosing a NM-D471 REV 2.0 motherboard from a Lenovo laptop. The laptop won’t power on. I started by checking the power rails, including the main power line and the 3.3V and 5V rails.
                                          I do have a proper 3.3V across the line, including at the chip responsible for managing 3.3V/5V—same goes for the 5V rail. I haven’t tried to simulate a power-on yet, since the main issue still needs to be resolved.
                                          I have full access to the boardview, but I’m not sure what to check next to isolate the problem.
                                          06-25-2025, 08:49 AM
                                        • code share
                                          Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                                          by code share
                                          I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                                          Here's what I've tried so far:
                                          • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                                          • Booted successfully on AC power only with the battery disconnected
                                          • Visual inspection of the battery — no swelling, burn marks, or connector damage
                                          • Battery
                                          04-21-2025, 12:50 PM
                                        • tony359
                                          diagnosing an old ATX PSU help identifying resistors (PowerComputing TCX-20D)
                                          by tony359
                                          I'm diagnosing an old ATX PSU. Symptoms are:
                                          - PSU turns on regardless of the ON/OFF status for a few seconds
                                          - Voltages don't reach nominal
                                          - PSU then turns off and needs power cycle to power on again
                                          I found two charred resistors, they're across the main capacitors on the primary, I think they are bleeding resistors?
                                          They're both charred, but I don't think it's the issue with the PSU as they read 22kOhm
                                          See pics. Is the black band some custom tolerance then? As 22Kohm should be Red-Red-Orange.
                                          08-06-2023, 01:41 PM
