Insignia NS-50DR620NA18 vertical colored lines no picture
  • daxlw
    daxlw
    • Apr 2020
    • 17
    Re: Insignia NS-50DR620NA18 vertical colored lines no picture
    I have cleaned the contacts, reconnected, unconnected, pressed, and other but only one side will work if the other side is disconnected before plugin. If both strips are connected from t-con to the inverter board? 50t32-soc xl bd, I get the color lines. My question here is, if I get an ohms meter, what do I do with it, what do I check, where, if I find one that is not pulling proper voltage, what do I do, what do I replace, it is worth it, is something like this issue usually fixable? do I need to separate the plastic ring from the panel to see what the board ribbons are connected to?
      You will set the meter to Ohm mode to check the resistance of the SMD MLCC (Multi Layer Ceramic Capacitor) for very low Ohm reading on the section of the bad tab bonding that is not connected to the T-CON.
      Most of the time the caps will be connected in parallel so you may have to remove the tested bad cap out until the shorts go away, you will need Hot air station, and good soldering iron to do proper works without damaging the boards.
      Is it worth it? That is up to you. I fixed many and it is great learning experience for me.
      You need to disassemble the LCD panel to get good access to the tab bonding board, 50" screen is big screen and can easily be damaged.
      • daxlw
        daxlw
        • Apr 2020
        • 17
        Thank you for the info. Is there a video or instruction on this procedure?
          • 12330
          • U.S.
          One there to give you the gist of it: https://www.youtube.com/watch?v=jLd6QO7Z7m4
          • daxlw
            daxlw
            • Apr 2020
            • 17
            • budwich
              • Jul 2015
              • 3097
              that first picture don't look so good... :-( if that is on the same side as your vertical lines, that is likely your problem. the tab appears to have been compromised.
              • ngth82
                • Jul 2015
                • 541
                I agree with Budwich.
                Looking at Post 10, 12 and 25... it appears to be the same side.
                -Thomas
                I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
                • daxlw
                  daxlw
                  • Apr 2020
                  • 17
                  If you are referring to the ribbons, they are all secure, it's reflection.
                    • 12330
                    • U.S.
                    #29
                    Well could try the "cutoff tape" method, might work who knows, sometimes you have to play with the size of the tape and placement to get it just right, example there: https://www.youtube.com/watch?v=7TT8QYeN1s8
                    • budwich
                      • Jul 2015
                      • 3097
                      OK..... you need to look at the other side of the panel where the tab ribbons are attached to the panel to see if there are any issues there.
                      As suggested, you should also do some component checks of the SMD's on the edge board of the side that does not work.
                      • Sergini
                        • Sep 2021
                        • US
                        #31
                        I found the same TV model with the same problem - vertical colored lines on the black screen.
                        I replaced the board labelled as "CTRL BD" - it didn't change anything.
                        When I disable the ribbons one by one - one half of the screen become dark (black/grey). No TV signal source attached during the tests.
                        Does it the panel itself is dead? Or it worth to try the other tests suggested in this thread?
                        • triplefour
                          • May 2014
                          • 1747
                          i tried to watch the video but its so shaky and the guy doesnt explain well. i did see him put a piece of tape on the ribbon cable from the tcon to the MB...what is the theory here? why would that work at all?
                          Don't fear the repair...
                          • Stanley1843
                            by Stanley1843
                            06-29-2024, 11:54 AM
                          • srs
                            Insignia NS-50DR620NA18 w/ large vertical lines & no picture
                            by srs
                            I'm not sure what to do next and came here since y'all helped me fix a 50" plasma TV back in 2014, which is still working!
                            A friend gave me an Insignia NS-50DR620NA18 50" TV that suddenly developed large vertical lines on it. He said he had no idea what might have caused it and has replaced it with a larger TV. He was going to throw it away.
                            I did not notice any bulged or leaking caps on any board, the voltages produced by the power supply match the voltage that the pins are marked. The backlight leds are working. I have tried cleaning the ribbon cables...
                            04-22-2023, 02:40 PM
                          • pni
                            LG 49uf695v vertical coloured lines
                            by pni
                            Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                            11-14-2025, 03:15 AM
                          • Falki
                            Colorful LCD Vertical Lines on Samsung ue55es8090
                            by Falki
                            Hello there, ive recently found an older 55inch Samsung SmartTV.
                            A similar issue has been posted as well but also with no actual response ...
                            08-12-2025, 04:19 AM
                          • visionbluedemon
                            Help. Sony kd-65x85dj vertical lines
                            by visionbluedemon
                            First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                            Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                            tried blocking LC lines too, but same results
                            is it lcd panel issue or tcon board issue?...
                            07-25-2025, 04:56 AM
