Insignia NS-50DR620NA18 vertical colored lines no picture
  • daxlw
    daxlw
    • Apr 2020
    • 17
    Re: Insignia NS-50DR620NA18 vertical colored lines no picture
    I have cleaned the contacts, reconnected, unconnected, pressed, and other but only one side will work if the other side is disconnected before plugin. If both strips are connected from t-con to the inverter board? 50t32-soc xl bd, I get the color lines. My question here is, if I get an ohms meter, what do I do with it, what do I check, where, if I find one that is not pulling proper voltage, what do I do, what do I replace, it is worth it, is something like this issue usually fixable? do I need to separate the plastic ring from the panel to see what the board ribbons are connected to?
      You will set the meter to Ohm mode to check the resistance of the SMD MLCC (Multi Layer Ceramic Capacitor) for very low Ohm reading on the section of the bad tab bonding that is not connected to the T-CON.
      Most of the time the caps will be connected in parallel so you may have to remove the tested bad cap out until the shorts go away, you will need Hot air station, and good soldering iron to do proper works without damaging the boards.
      Is it worth it? That is up to you. I fixed many and it is great learning experience for me.
      You need to disassemble the LCD panel to get good access to the tab bonding board, 50" screen is big screen and can easily be damaged.
      • daxlw
        daxlw
        • Apr 2020
        • 17
        Thank you for the info. Is there a video or instruction on this procedure?
          • 12123
          • U.S.
          One there to give you the gist of it: https://www.youtube.com/watch?v=jLd6QO7Z7m4
          • daxlw
            daxlw
            • Apr 2020
            • 17
            • budwich
              • Jul 2015
              • 3097
              that first picture don't look so good... :-( if that is on the same side as your vertical lines, that is likely your problem. the tab appears to have been compromised.
              • ngth82
                • Jul 2015
                • 541
                I agree with Budwich.
                Looking at Post 10, 12 and 25... it appears to be the same side.
                -Thomas
                I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
                • daxlw
                  daxlw
                  • Apr 2020
                  • 17
                  If you are referring to the ribbons, they are all secure, it's reflection.
                    • 12123
                    • U.S.
                    #29
                    Well could try the "cutoff tape" method, might work who knows, sometimes you have to play with the size of the tape and placement to get it just right, example there: https://www.youtube.com/watch?v=7TT8QYeN1s8
                    • budwich
                      • Jul 2015
                      • 3097
                      OK..... you need to look at the other side of the panel where the tab ribbons are attached to the panel to see if there are any issues there.
                      As suggested, you should also do some component checks of the SMD's on the edge board of the side that does not work.
                      • Sergini
                        • Sep 2021
                        • US
                        #31
                        I found the same TV model with the same problem - vertical colored lines on the black screen.
                        I replaced the board labelled as "CTRL BD" - it didn't change anything.
                        When I disable the ribbons one by one - one half of the screen become dark (black/grey). No TV signal source attached during the tests.
                        Does it the panel itself is dead? Or it worth to try the other tests suggested in this thread?
                        • triplefour
                          • May 2014
                          • 1747
                          i tried to watch the video but its so shaky and the guy doesnt explain well. i did see him put a piece of tape on the ribbon cable from the tcon to the MB...what is the theory here? why would that work at all?
                          Don't fear the repair...
                          • Stanley1843
                            by Stanley1843
                            06-29-2024, 11:54 AM
                          • srs
                            Insignia NS-50DR620NA18 w/ large vertical lines & no picture
                            by srs
                            I'm not sure what to do next and came here since y'all helped me fix a 50" plasma TV back in 2014, which is still working!
                            A friend gave me an Insignia NS-50DR620NA18 50" TV that suddenly developed large vertical lines on it. He said he had no idea what might have caused it and has replaced it with a larger TV. He was going to throw it away.
                            I did not notice any bulged or leaking caps on any board, the voltages produced by the power supply match the voltage that the pins are marked. The backlight leds are working. I have tried cleaning the ribbon cables...
                            04-22-2023, 02:40 PM
                          • gpo23
                            Sony KDL-40V3000 - Vertical lines
                            by gpo23
                            i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                            With the new t-con the color are good but there are vertical lines on all the screen :
                            I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                            Is there a way to fix the vertical lines on the new t-con ?
                            Thank you for your help
                            gpo23...
                            10-04-2023, 09:11 AM
                          • Superluminal
                            LG 47LV5500-UA Vertical Colored Lines/Alignment Issue
                            by Superluminal
                            Hi all, looking for some input on this one. I've been reading the forums for quite some time but this is my first time posting for help.
                            LG 47LV5500-UA
                            10 years old
                            20,000+ hours on it.
                            Watching TV on it last week and right while I was watching the image suddenly started experiencing the symptoms in pics. Rainbow chromatic vertical lines and alignment issues. The issue is uniform across the entire panel. It does not come and go, the symptoms are stable.
                            Here is what I've tried so far:
                            - Factory reset and cycle of picture options....
                            11-19-2022, 07:41 PM
                          • Maverick1234
                            Colored Vertical lines on Samsung UN55C6400RF TV
                            by Maverick1234
                            I have a Samsung 55inch TV (UN55C6400RF). It has started showing colored vertical lines. I have opened the TV and the power board had one pin (out1-) which is discolored (Model # bn44-00358b). Can this be bad or is it the T-Con board (Model # D03464E0J09B6012066). Any recommendations on diagnosing the issue?
                            Thanks,
                            Sanjay
                            09-13-2021, 02:43 PM
