LG 65UH6030-UA lightning strike, no S/B light, no backlights, no OSD
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    A few weeks back I got a call from a guy who said lightning had struck close to his apartment building, and ever since the TV would not come on. He said a total of four electronics items close to the TV were lost at the same time. He just wanted to get rid of it, and I'm always game for that!
    So finally today I had a chance to check it out. When it's plugged in to the wall there is no stand-by light. When the power button on the TV or remote are pressed the S/B light flashes three times and the Optical Audio light comes on.
    Shining a flashlight upon the screen reveals no image on start-up or when the TV is on. Press the power button again, the Optical Audio light goes out but the S/B light does not come on.
    Here's the pinouts and corresponding voltages found:
    Pin name……………….v TV off……………………..TV on
    MS…………………………. 0v ………………………. 0v
    GND
    13.2v……………………. 7.7-7.9 unstable ………13.2v
    13.2v……………………. 7.7-7.9 unstable ………13.19v
    GND
    PWR_ON............... 0v …………………….…. 3.37v
    PDIM1…………………… 1.84-1.87 unstable … 3.28v
    GND
    13.2v……………………. 7.81-7.96 unstable … 13.2v
    13.2v……………………. 7.81-7.96 unstable … 13.19v
    PDIM2………………….. 1.84-1.87 unstable … 3.28v
    LED+………………………………………………………… 326
    LED-…………………………………………………………. 162
    LED-……………………………………………………….… 162
    I tested both backlight strings with the tester and they do illuminate. I also tested the T-CON fuse, it is good with voltage present on both sides. Furthermore there appears to be signal voltage at the T-CON LVDS side test points as well as output voltages present at the T-CON FFC side.
    Detaching either FFC from the T-CON to the Source driver boards results in a white screen on the corresponding side of the screen.
    Powering up the backlights with the tester while the TV is on and there is no picture upon the screen.
    So can anyone help me with troubleshooting this further? I'd appreciate it!
    Pictures posted!
    They call me......."threadkiller"
    • 12332
    • U.S.
    Re: LG 65UH6030-UA lightning strike, no S/B light, no backlights, no OSD
    What do you have on the big cap C611when powered on?
    • DXseekerMO
      • Feb 2018
      • 1119
      • US
      I've got 395v
        Looks to be the main board issue, more likely the surge went through the HDMI port.
        • DXseekerMO
          • Feb 2018
          • 1119
          • US
          Would this affect backlight operation? Also, what is the MS pin on the Power Supply and its function?
          As far as I can tell the PS is working ok so yes very likely HDMI entry point for the surge
          • R_J
            • 9627
            What is the number on IC801, that would help to determine the function.
            The pin looks more like M5 than MS
            • DXseekerMO
              • Feb 2018
              • 1119
              • US
              I'd love to tell you the number off IC801, unfortunately its covered with a thin shellac and obscured. Any suggestions on how to remove that coating?
              I have urethane grade reducer for auto body repair....but it eats plastic quick.
              • R_J
                • 9627
                Just try some alcohol, that usually works, you may also need to look at an angle to read the number.
                  • 12332
                  • U.S.
                  So if you're getting a white screen then the backlights are on and you are just not getting a picture, correct?
                  • DXseekerMO
                    • Feb 2018
                    • 1119
                    • US
                    Sorry, no that isn't correct. I have no image on the screen, the screen is black and I have no backlights.
                    • budwich
                      • Jul 2015
                      • 3097
                      go to the usb connector and look for 5v. pull the shield / heat sink on the main board so you can see whats up there.
                      • Bardou Kari
                        HP EliteBook 840 G6 – no power after lightning strike
                        by Bardou Kari
                        I’m trying to fix an HP EliteBook 840 G6 that stopped working after a lightning storm.
                        – Charger is OK and 19V is present at the motherboard.
                        – No charging LED, no fan, no reaction.
                        – I don’t see any 3.3V or 5V near the coils.
                        – Battery is unplugged.
                        – I’m new to board repair but can use a multimeter.
                        I added a clear photo of the board.
                        Any idea where to start or what to check next?
                        Thanks a lot for your help!...
                        07-01-2025, 10:45 AM
                      • karthur
                        Samsung UN60EH6000 wont come on after lightning strike.
                        by karthur
                        We had a lightning strike a few days ago really close to my house. My Samsung UN60EH6000 was on when it hit. Afterwards, the TV would not come back on.
                        I had repaired this TV a few years back by replacing the T-Con board. (The post I had on this is repair is here.)
                        When I turn on the TV, I don't get any start-up melody. The screen just dimly flickers around the edges.
                        Here is what I have checked.
                        On the power supply board, 14pin connector:
                        1 :12.7 Vdc
                        3 :12.7
                        5 :12.7
                        7 :12.7
                        9 :0
                        11 :5.
                        13 :5....
                        11-01-2023, 06:18 PM
                      • MrCreosote
                        Lightning Strike: 55" TV dead: is display panel OK?
                        by MrCreosote
                        THE LIGHTNING:
                        This was a very close strike, blew a 15 amp breaker for all ceiling lights in home AND could smell ozone for a few minutes after strike.
                        Very close and probably a very strong EMP.
                        THE TV:
                        No standby LED. Some voltage from PSB (not totally dead).
                        But found a kit of ALL 4 circuit boards for $55.
                        At first thought, this will fix my TV.
                        But then lightning has the ability to totally fry semiconductors. Which would include any or all of the PCBs. However, the display is one big semiconductor and given...
                        08-16-2021, 10:27 PM
                      • pbig
                        advices for repairing Sony Bravia 32EX600 after lightning strike
                        by pbig
                        hi everyone,
                        my parents in law have seen their Bravia Sony LED 32EX600 TV set stop after a lightning strike. After being plugged to mains, it shows nothing no power LED on bottom left shines.
                        On the power PCB (GE3b, attached pic), I chacked the fuses and the only roasted one is R6536 : 0.47 ohms, 1/2W. After replacing it, I made some voltage measurement with ref to the chassis :
                        - the 450V/150uF capacitor voltage when plugged is normal at 394V
                        - from connector CN6150 (15 poles)
                        STBY normal 3.3V -> I shunted it to 3 (POWER ON) and 11 (BL ON) and unplugged...
                        06-28-2023, 02:43 AM
                        Lithonia Lighting versus Light of America Compact Fluorescent product quality
                        by sam_sam_sam
                        I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                        I also have back when Light of America had these light bulbs available for yard lights
                        The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                        While the Lithonia lighting fixture has all most certain bulb failure
                        So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                        I have only had this light fixture for not more than a year if it...
                        07-02-2023, 03:45 PM
