Philips 32PF3320/10 bad colors / too bright
  • dominik0801
    • Feb 2018
    • 98
    • Hungary
    Hello!
    A friend of me gave me an old television, he told me, that it's not working. It's an Philips 32PF3320/10 TFT LCD TV.
    Since I like to fix stuff, I decided to fix this TV too. I plugged it in, it turned on, I got backlight and also, sound. The only thing that didn't work is the screen itself; it had nothing on it.
    After I took it apart, I noticed, that everything seems okay, so I got to the T-con board. The model is: V32BC3 (the big chip version).
    The F1 fuse was blown, but I didn't find any shorts on the board, so I just replaced it with a cable for testing purposes. (I know that it blew for a reason)..
    After turning the TV on like this, I now have picture, and can confirm that the TV is in fact working in general, but the colors are waaaaay off.. It's like the picture had a white fog in front of it. It's hard to see.
    Also, if say, I open the menu for 10 seconds, then close it, the menu won't fully disappear, like it burns into the screen.. (picture attached)
    I have read some forums and watched videos, and I saw that the AS15-F chip can die and produce this, so I replaced it, but the problem remained.
    I didn't meausre everything yet, because I had to go to work, but I can confirm, that between GAM2 and GAM17 everything seemed fine about the voltages. But then I noticed, that the GAM1 and GAM18 is at a completely different spot on the board!
    The GAM2-GAM17 testpoints are connected to the AS15-F chip and they are located at the left side of the board (blue marking on picture), however, the GAM1 and GAM18 points are on the right side of the board, and connected to the AS34-G chip. (marked with red).
    And the voltages seem switched to me.. the GAM1 has 0V, while GAM18 has ~14.7.
    Meanwile, on the other side of the board, GAM2 has ~14V, and GAM17 has ~0.7V.
    I might not understand everything completely here, but what do you say? On the hungaian TV forum they told me it's a bad LCD and its not fixable.
    Important note: i tested the voltages without the LCD connected.
    Thanks in advance,
    Dominik.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Philips 32PF3320/10 bad colors / too bright
    I see the AS34-G referenced as a gamma correction IC, if replacing the AS15-F hasn't made any difference then I'd change the AS34-G.
    • dominik0801
      • Feb 2018
      • 98
      • Hungary
      So, I ordered a new AS34-G chip, but since it's from aliexpress, it's gonna be at least a month till it arrives.
      However, I measured a lot more things than yesterday, like all the VGAM points an others.
      I made a graph with the VGAM voltages, you can see the attachments.
      Note: the GAM1 and GAM18 are connected to the AS34-G chip, and not the AS15-F chip.
      But I am not sure, which side of the chip is an input or output, nor how it really works, since there is not much information about it.
      Other voltages I measured:
      VGL -6.3V
      VGH 33.5V
      VLS 14.9V
      VCOM2 0.17V (this is the other side of the AS34-G chip)
      VCOM3 0.4V (this is the other side of the AS34-G chip)
      D_VDD_F 3V
      There are a few more testpoints, that I could measure, like VCOM1 and a few other one, but now I'm a bit concerned, if it's the T-con board or not.
      • R_J
        • 9623
        That voltage graph looks ok untill VGAM18, that voltage should likely be around 0.5 and not 15v
        • R_J
          • 9623
          I looked at the t-con board picture and I only see GAM2~GAM17 where did the GAM1 & GAM18 come from? It would seem that the GAM voltages are ok and the graphed voltages are missleading.
          Have you tried disconnecting (with power off) the cables between the t-con and the panel, try them one at a time and see if it makes a difference to the video ojn the screen.
          • dominik0801
            • Feb 2018
            • 98
            • Hungary
            As I mentioned, the GAM1 and GAM18 are on the right side of the board, but I'm gonna attach a picture again, with them highlighted.
            Yes, I tried connecting only one side of the screen, but that didn't make a difference.
            Some new information: I have read that the VCOM voltages should be like ~7V, however, I have ~0V on the VCOM2 and VCOM3 (didn't measure VCOM1 yet). Could this make this problem?
            • dominik0801
              • Feb 2018
              • 98
              • Hungary
              So, today I changed the AS34-G to a new one, and it fixed the problem! ...well, for a few minutes. Then, again, the picture got weird. Not as bad, as before, but definitely brighter than it should be. I was checking the GAM18 voltage, while it was good, the voltage was around 0.6V.
              Then, now, with the messed up picture, it's now around ~6V, so now I am pretty sure, that the GAM18 voltage is the problem. I got another spare chip, and I'm gonna try that one too, and if that also fails, at least I will know, that the GAM18 line is the one to fiddle with.
              EDIT: i put in the other chip, and now the colors are fine! And it worked so far. However, there are some weird flickering on the top middle part of the screen, I also see some horizontal lines on that area... it might be the burn in from the previous chip, so I'm gonna turn the TV off for a few hours, and then turn it back on.
              However, if it will still do this same thingy, I'm giving up on it.
              • dominik0801
                • Feb 2018
                • 98
                • Hungary
                Last post about the TV, since I call this a win situation and a working TV from now!
                So since the colors were okay, and the only problem was the picture lining and the vibrating area, I opened up the TV again, and started to turn the pot on the LCD's top PCB, and it suddenly stopped the vibration and the lines went away too.
                I know, that my thread is a bit messy, and it's mostly just me telling unnecessary informations, but maybe someone else will find these posts and help them too.
                • R_J
                  • 9623
                  "LCD's top pcb" ?
                  What "pot" did you adjust? Is there a pot on the board on the lcd panel board? This is the board between the t-con and the lcd panel itself.
                  • dominik0801
                    • Feb 2018
                    • 98
                    • Hungary
                    Yes, between the T-Con and LCD panel, there was a PCB. It only had 1 pot, which seemed to be a pot to set the VCOM voltage.
                    After fiddling with it, the picture became good, and working ever since.
                    • silikon77
                      Philips 70PUS7855/12 bad colors when applying the tape fix on teh T-con board
                      by silikon77
                      Hi!
                      Got an 70 inch Philips tv model 70pus7855/12 from scraps and I decidet to give it a go. I'm an enthusiast but no porfessional in the electronics.
                      Found some advices watching youtube nad came up with this:
                      It came with no picture, after diagnosing it I found out that the right side of the T.con board was faulty.
                      I taped down the clock signals and I got a picture but the left side of the panel has less pronounced colours. Only the right 3rd side of the panel has good colors.
                      See attached picture.
                      I tried a few combinations to block individual clock...
                      01-02-2025, 02:26 PM
                    • croupier36
                      Philips 32PFL5605H/12 issue with displayed colors
                      by croupier36
                      Need help with this unit...looks like the colors are not displayed correctly....not an expert, but looks like something wrong with the GREEN...have attached the photo of the 'home menu' and the recorded video of the Demo video that's on the TV for viewing/testing.
                      Where should I look for faults? Everything else looks/works ok.
                      BTW...have upgraded to the latest FW/SW version, but nothing changed....
                      11-09-2024, 11:07 AM
                    • Schwoin
                      Philips 243v5lhsb00 Monitor Picture too bright
                      by Schwoin
                      Hey everyone,
                      the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
                      While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
                      you can see them on the top half of the photo.
                      At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
                      03-21-2023, 12:40 PM
                    • alro7779
                      Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                      by alro7779
                      Hello, guys!
                      The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                      09-14-2025, 12:25 AM
                    • G33RT
                      Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                      by G33RT
                      Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                      It does power up when pressing the power button.
                      I already try the power button while plugin the plug with no result.
                      Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                      Could this be an PSU or eMMC issue ?
                      07-19-2025, 03:43 AM
