Philips 243v5lhsb00 Monitor Picture too bright
  • Schwoin
    • Mar 2023
    • Deutschland
    Hey everyone,
    the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
    While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
    you can see them on the top half of the photo.
    At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
    Ofc i tried different inputs and different devices to test the monitor. This problem appeared with all combinations (HDMI, VGA, DVI) on different pcs.
    The OSD also appears way too bright.
    I have measured the voltages coming from the power supplay board and they all were stable as they should be.
    So i thought maybe it´s an issue with the t-con board so i measured all the testpoints there.
    Here are the results in volts:
    VDD 5.15
    VGH 27
    voff -5.5
    avdd 12.5
    vcom 3.7
    dvdg 3.3
    lv+5-0 1.25
    lv 1-5 1.29
    lvck 1.28
    xcon 3.3
    0vdd 3.3
    acing 3.3
    dvddc 3.3
    cpv 1.5
    de1 1
    stv 0.02
    oe2 2
    load 0.2
    mpol 1.6
    V1 12
    V2 11.4
    V3 9.5
    V4 8.9
    V5 8.6
    V6 7.6
    V7 6.8
    V8 6.2
    V9 5.2
    V10 4.1
    V11 3.7
    V12 3.1
    V13 0.95
    V14 0.3
    ud 3.3
    csc 0
    pwr c1 0
    pwr c2 3.3
    dir 3.3
    vmidsl 3.3
    vmidl 6.5
    I´m not sure about all these but i think for the most parts they should be fine? Only pwr c1 seems a bit off to me but i don´t know, what exactly that measures because i couldn´t find anything on the internet.
    So does anyone have an idea, what pwr c1 is or what else could be wrong with the monitor?
    BIG thanks in advance!
  • nomoresonys
    • 12328
    • U.S.
    Re: Philips 243v5lhsb00 Monitor Picture too bright
    If it's a settings issue maybe this video will help?: https://www.youtube.com/watch?v=6fCH1bxS0wg
    • Schwoin
      • Mar 2023
      • Deutschland
      Thank you for your reply but idon´t think that it´s an hardware issue because i´ve already tested all settings and nothing changed. Also the screen appeared normal for a moment, when i tilted it, so i guess the problem is hardware related.
      • nomoresonys
        • 12328
        • U.S.
        Strange, if it was ok at a certain angle look over the solder joints very closely, reflow any that look suspect, careful not to bridge any, examples of bad joints for any who need it: https://www.google.com/search?q=bad+...ih=607&dpr=1.5
          by momaka
          03-15-2023, 10:17 PM
        • Patrick501
          Philips 55PUS6704 no picture, backlight ok
          by Patrick501
          I'd like to repair a Philips 55PUS6704.
          It turns on and you can see the backlight, hear the sound but no picture.
          When I disconnect one of the T-con cables, half of the screen turns white.
          right cable disconnected= right side white
          left cable disconnected= left side white
          When I tape like 6 or 7 pins of one cable it looks like the picture attached. I already tried another T-con board without success.
          There are no shorts on the the mainbaord and the two lcd panel boards...at leat I couldn't find any.
          Also you can notice one single...
          11-12-2025, 08:46 AM
        • keepread
          Dell monitor PSU vs Dell laptop PSU
          by keepread
          Hi there!
          Someone gave me their old monitor, it's Dell S2715ht.
          The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
          Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
          10-30-2025, 04:45 PM
        • Rauni
          Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
          by Rauni
          Hello, this is my first post on this forum, and my first attempted to repair a TV.
          My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
          Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
          Read also that we should test what happens if we...
          10-01-2023, 12:06 AM
        • logocar3
          Philips 288P6LJEB/27 monitor PSU outputting 8V instead of 12V
          by logocar3
          I am having problem with fixing Philips 288P6LJEB/27 monitor PSU, board number 715G6457-P01-000-0010.
          Data:
          - Schematic is attached to post
          - Photos can be found on flicker: https://www.flickr.com/photos/198547898@N03
          Problem:
          - PSU board have power outputs at 5.2V, 12V and 24V - board is correctly outputting only 5.2V (correct), and not 12V (without load only 8.16V) or 24V (without load 0V)
          State of PCB / monitor:
          - Bought defect monitor from a company auction
          - There were some attempts to fix...
          06-19-2023, 11:40 PM
