Philips 70PUS7855/12 bad colors when applying the tape fix on teh T-con board
  • silikon77
    • Jun 2022
    • eu
    Hi!
    Got an 70 inch Philips tv model 70pus7855/12 from scraps and I decidet to give it a go. I'm an enthusiast but no porfessional in the electronics.
    Found some advices watching youtube nad came up with this:
    It came with no picture, after diagnosing it I found out that the right side of the T.con board was faulty.
    I taped down the clock signals and I got a picture but the left side of the panel has less pronounced colours. Only the right 3rd side of the panel has good colors.
    See attached picture.
    I tried a few combinations to block individual clock signals on the ribbon but I am not getting any impovements. It wroks only if I block at least 6 out of 8 clock signals.
    Is there a better solution to this. I have a spare t-con board an a spare main to t-con board cable, replaced them and stil no good colors on the left side. (is this a LCD panel issue or maybe a mainboard failure)
    Thanks for suggestions
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • kca
    by kca
    Hello all ~
    08-31-2025, 06:38 AM
  • x_orange90_x
    TCL 50S535 bad tcon or panel issue?
    by x_orange90_x
    Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
    03-29-2025, 11:02 PM
  • croupier36
    Philips 32PFL5605H/12 issue with displayed colors
    by croupier36
    Need help with this unit...looks like the colors are not displayed correctly....not an expert, but looks like something wrong with the GREEN...have attached the photo of the 'home menu' and the recorded video of the Demo video that's on the TV for viewing/testing.
    Where should I look for faults? Everything else looks/works ok.
    BTW...have upgraded to the latest FW/SW version, but nothing changed....
    11-09-2024, 11:07 AM
  • RetroComputingGrotto
    IBM LTO 7 Tape Drive - Dust Sensors??
    by RetroComputingGrotto
    I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
    I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
    09-19-2024, 01:54 AM
