Silly question about led strps
  • layad
    • Nov 2011
    • 249
    Hi , what makes the exact led goes bad within 3 days, changed one single led on LG TV and within 3 days the same led gone bad , really burned , did it several times but still the same one goes bad
    Re: Silly question about led strps
    What is the specification of the replacement LED?
    • R_J
      • Jun 2012
      • 9624
      Likely how you changed it. What did you use to remove it and then resolder it? was the trace also damaged?
      • petehall347
        • Jan 2015
        • 4449
        maybe the old ones killed it .
        • layad
          • Nov 2011
          • 249
          First one was taken from an other strip , use air gone from underneath to remove and resolder, second one was brand new, heat from underneath, third one was brand new, traces are fine
          • layad
            • Nov 2011
            • 249
            By the way can I bypass it by make a jumper?
            • petehall347
              • Jan 2015
              • 4449
              if you really want to bypass it an led of correct spec is best to do that . or pick a diode with similar characteristics ,
              • throwaway327
                by throwaway327
                Model No: RC72LA
                Serial No: SBNVKD001014459
                06-18-2025, 05:52 PM
              • panoss
                Samsung LS19A100, slowed down, colors changed, lines not very crisp
                by panoss
                In the above mentioned monitor, I removed the plug a few times and this resulted no power.
                I opened it, soldered the dc jack and worked again.
                But since then colors have changed, too bright (or something like this) and lines, eg letter, are not very crisp as they used to be, they are vague, like faded out.
                I checked voltages on the main board, they look ok (according to the service manual. It' attached at the bottom):
                IC600 (D9329)
                pin 1 (BST) 9.6V
                pin 2 (VIN) 13.5V
                pin 3 (SW(Switching output)) 4.8V
                pin 7 (EN)
                pin 8 (SS) 2.6V
                IC601...
                10-13-2024, 10:21 AM
              • ivtec
                Win 10 home edition changed to Win 10 pro help
                by ivtec
                Hi guys; i have installed win 10 Home Edition from a DVD iso and it changed to Win pro ,how i change it back to Home edition without reinstall again ?Thanks
                06-21-2024, 08:43 AM
              • Ferimonka
                Dell Latitude 7420, 7320 voltage changed
                by Ferimonka
                Hi there,
                I got 2 Dell laptops with a locked bios (dell management protection).
                When I sent the dumps to this forum I got unlocked .bin files.
                The issue I am getting the voltage on the bios chip pins has changed once I soldered the chip back (with the unlocked even original bios file) and doesn't turn on anymore.
                Before I started to re-program the chip the voltage on the pins were 3.3V almost on each pin. Once I soldered the chip, voltage changed to 1.9V or 1.3V on few pins. No 3.3V anymore.
                I appreciate any help to get me this...
                07-18-2022, 02:11 AM
              • link626
                TCL 43s405 power board 81-PBE045-M02 (PLE100-2A) changed out the cheap caps
                by link626
                changed out the cheap HEC caps on my tv power board to a mix of nichicon chemicon and panasonic caps below.
                now there's louder buzzing noise from the yellow thing in the upper left corner. (anyone know what that yellow thing does? is that the transformer?)
                and the screen flickers in brightness. It's a light flicker, but noticeable.
                the buzzing ebbs and flows, like cicadas buzzing.
                in similar fashion, the brightness flickering ebbs and flows. the flicker might stop for a minute or two.
                these are all low esr caps, and I'm wondering if that might...
                08-08-2021, 11:11 AM
