Cleaning Question
  • ljintexas
    LJinTexas
    • Jan 2015
    • 669
    Cleaning Question
    What can I use to clean the vertical ribbon cables on a plasma? I recall being told not to use alcohol.
    LJ
  • Lydia
    • Oct 2019
    • 19
    Re: Cleaning Question
    I have seen some youtube videos where they use a pencil eraser to do it.
    • R_J
      • Jun 2012
      • 9624
      In most cases there is no need to clean them, they are usually gold plated. What problem are you having.
      If you have a black line going from one side to another on the screen, try reseating the cable in that area. if that does'nt help, check the buffer ic in that area for a short.
      If you remove the ultra thin gold plating, then you could have problems.
      • maneatingmonkey
        • Feb 2020
        • 36
        Who said not to use alcohol? ShopJimmy says to use alcohol in this video https://youtu.be/aOCLpJub2l0?t=118
        • tvtimmy
          • Mar 2015
          • 1160
          • usa
          I've used alcohol to clean alot. Just not Jack Daniels or Miller High Life, lol.
          • nomoresonys
            • 12331
            • U.S.
            Yep, use 91 percent alcohol, I've used 50 percent quite often but it's not really recommended, 91 is pretty common, I see it at the grocery store.
            • ClockChip
              Isopropyl alcohol as a cleaning agent?
              by ClockChip
              Hello All,
              I wanted to check with the board before I do anything foolish and/or irreversible. Can someone please set me straight on the use of isopropyl alcohol to clean electronics? I understand it is commonly used to clean electrical contacts. However, in this case, I am wondering if I can safely immerse a small electronic item in alcohol provided a) all power has been removed and b) I take care to dry it thoroughly before re-applying power.
              The short version is that I am seeking to clean an older used (well-used) electronic item. The basic plan is to immerse it in...
              03-16-2024, 12:10 PM
            • zesko
              xps 9520 ribbon cable
              by zesko
              I have a XPS 9520 with broken daughter board and missing ribbon cable. I can fix the board by replacing the connector, but I can't find the correct ribbon.
              There is 2 models, idk which one is needed on my laptop.
              0xkvng
              00vpr2
              Daughter board is LS H822P. When I check for a palmrest, the board attached to have a 0xkvng ribbon. But when I check for LS h822p, it's 00vpr2 ribbon...
              Someone can help me with that please ? Idk the difference between these 2 ribbon but they definitely doesn't look the same..
              thanks...
              10-23-2025, 05:03 PM
            • Tr0ll
              by Tr0ll
              Original T-con:
              First replacement T-con:
              10-07-2023, 07:48 PM
            • rumi409
              LG OLED C1 Pixel Cleaning Made Picture Worse
              by rumi409
              ​​​​​​ Hi,
              I'm trying to resurrect a LG OLED C1 TV that has some panel banding. I used the TCON error bypass to get a picture. I was able to update the firmware as well. But when I performed a pixel cleaning to try to get the banding out, it made the image significantly worse. I tried to undo the effects of the pixel cleaning by performing a factory reset and IN_Stop, but that didn't work. Any way to reset pixel cleaning data?...
              11-15-2024, 01:09 AM
            • Rubenlily
              Quick question about the ribbon
              by Rubenlily
              Hey,
              So I have horizontal lines on my TV and I'm trying to trouble shoot. My question about the ribbon is:
              When I disconnect one ribbon from the t-con I should get half picture working and other half black or something like that correct? But when I disconnect the ribbon on one side I just get a dark screen and it doesn't matter what side I disconnect. I just get the dark screen. No half working, no one half black and the other one left. Sound is playing from the TV so it's obviously on and when both sides are connected I have the picture with the horizontal lines...
              08-17-2023, 11:09 AM
