Cleaning Question
    Cleaning Question
    What can I use to clean the vertical ribbon cables on a plasma? I recall being told not to use alcohol.
    LJ
    Re: Cleaning Question
    I have seen some youtube videos where they use a pencil eraser to do it.
      In most cases there is no need to clean them, they are usually gold plated. What problem are you having.
      If you have a black line going from one side to another on the screen, try reseating the cable in that area. if that does'nt help, check the buffer ic in that area for a short.
      If you remove the ultra thin gold plating, then you could have problems.
        Who said not to use alcohol? ShopJimmy says to use alcohol in this video https://youtu.be/aOCLpJub2l0?t=118
          I've used alcohol to clean alot. Just not Jack Daniels or Miller High Life, lol.
            Yep, use 91 percent alcohol, I've used 50 percent quite often but it's not really recommended, 91 is pretty common, I see it at the grocery store.
