Samsung__UN75J6300_wont turn off or remote fuctions work
  • hmendez86
    • Jun 2015
    • 344
    • united states
    Samsung un75j6300 ___ the tv works perfectly watching a movie or regular fav channel would work good all day, but when it comes to change Channel wont change or go off no functions.....i did think was remote but in had several Samsung remote and they all do same thing not working.....change the main board and it work good but for a day or 2 and it the same thing again...so not the main board problem...whats next migth be the IR on the tv sensor????
  • nomoresonys
    • 12323
    • U.S.
    Re: Samsung__UN75J6300_wont turn off or remote fuctions work
    Maybe try a factory reset if no go maybe a firmware update if you have not yet, I'm guessing there's no button board on tv to try change channel or on off.
    • hmendez86
      • Jun 2015
      • 344
      • united states
      Yes.. it has toggle button on the back and rigth at the botton it has the sensor....when i did replace the main for another it work but for 2 days and it started doing the same.....so difenetly not the main, but i will take consideration on firmware update...
      • budwich
        • Jul 2015
        • 3097
        likely issue is the connection between the main board and the ir / input board.
        • Crystaleyes
          Denon AVR E400 - Very unwell
          by Crystaleyes
          Hi everyone.
          Hoping that someone here has some experience with the AVR E-Series
          Came across this pristine but poorly unit in a 2nd hand HiFi shop the other day and thought I might learn something in nursing it back to life.
          It had a sticker on it stating, "working but only in one (left or right) channel".
          Speaking with the shop owner, he said that in fact it would occasionally work in both channels but he doesn't do repairs so it was selling 'as is'.
          Anyway, when he went to show me all this, it refused to even start up. When plugged...
          11-23-2025, 12:39 PM
        • maxim2511
          LG 55EC930V OLED - swich on swich of no screen
          by maxim2511
          My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
          Then I get an idea to take it apart and clean boards from dust.
          In side of Tv was not so bad, I take compressed air in can, and gently blow up.
          Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
          05-14-2021, 02:21 AM
        • edugimeno
          HiSense 55A7500F won't obbey to remote after power on
          by edugimeno
          Hi! I have this TV set that does the following:
          1) I press the red power button on the remote
          2) The TV turns on normally
          3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
          4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
          Then after it's off, it would again accept the TURN ON from the remote and same again
          BUT:
          -The remote does show the correct IR beam while observed thru a phone camera
          -The TV works fine while using the MiRemote...
          03-14-2023, 11:22 AM
        • eccerr0r
          old X58 triple channel board... memtest86 memory speed?
          by eccerr0r
          Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
          Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
          Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
          06-28-2025, 09:06 AM
        • Chuper
          RCA RLDED4016a-b
          by Chuper
          So I got this TV with not turning on symptom.
          Using my backlight tester I confirmed that LED backlight is fine. Ordered a replacement main board TP.MS3393.PB851. With this replacement board TV turned on but original remote control will not work on a TV and side buttons are mixed up(for example if I press "Source" TV will increase volume).
          So I swapped Eeproms and confirmed that it is a problem on my original main board, meaning with my original main board and an Eeprom from replacement board I got TV to turn on with not working remote and mixed up side buttons and the replacement...
          11-09-2023, 11:26 AM
