Denon AVR E400 - Very unwell
  • Crystaleyes
    • Sep 2021
    • 496
    • Brazil
    Hi everyone.
    Hoping that someone here has some experience with the AVR E-Series
    Came across this pristine but poorly unit in a 2nd hand HiFi shop the other day and thought I might learn something in nursing it back to life.
    It had a sticker on it stating, "working but only in one (left or right) channel".
    Speaking with the shop owner, he said that in fact it would occasionally work in both channels but he doesn't do repairs so it was selling 'as is'.
    Anyway, when he went to show me all this, it refused to even start up. When plugged in, it displayed the red LED. Turning it on, the LED flashed green for several seconds then stayed on... And that was that. It wouldn't turn off unless unplugged. No relay sounds, no display appearing on the front.
    Regardless, as it was cheap (20 Dollars), I fancied the experience. 🤦‍♂️
    Opening it up revealed a LOT of dust so I carefully dismantled the entire unit and cleaned and visually inspected all the boards. I also verified that the fuse on the back of the display boards was ok.
    On the main board, I ESR tested all the electrolytics and verified all the voltage regulators (by applying voltage) and bridge rectifier were working.
    Looking closer, the main 3-wire (2 reds, 1 yellow) connector was noticeably loose on this board, so resoldered the three pins to solve that particular problem.
    After finding the loose connector I was quietly confident that that might resolve the issue but no. What it did do was give the ability to switch the front LED from green to red and back again, but still no relay action, so no display.
    Tried the factory reset I.E. holding the two furthermost left, front-panel buttons as switching it on, but again... No relay, no display.
    Obviously, I'll have to look deeper into the manual however I'll probably still disassemble the main boards and verify that the relays are working first.
    So... Do any bells ring with anyone? Does anyone know of any other 'reset' options?
    If it is true that it had been working in the shop, then hopefully it will turn out to be something straightforward, like the loose connector causing the microprocessor to go into protection mode.
    ps. There is no remote control
  • Crystaleyes
    • Sep 2021
    • 496
    • Brazil
    An update...
    I found all the different reset and error record code options in the manual but still nothing appeared on the display and no relay action was coming from the receiver.
    ..After looking for relays, there is one which switches on the mains voltage, located on the power supply board, and I think five on the main board (of which at least four seem to be for different input channels).
    Clearly the PS board relay should be activated when the on/off switch is pressed on the front panel... This hasn't been happening.
    So, after waiting for the LED to stop flashing and become a solid green, I momentarily energised the relay with 20vdc, at which point the display lit up with 'AV SURROUND'.
    This lasted perhaps three seconds before disappearing, and the solid green LED began blinkin fast, red.
    If I then press the on/off switch, it goes solid red. Pressed again, AV SURROUND appears once more before going blank etc. I can do this ad-infinitum it seems.
    At least the display is not the problem. 👍
    If I press the factory reset buttons option however, the receiver does indeed do the slow flashing display thing until I release the buttons whereupon it displays' AV SURROUND' once more, and then blink with the flashing red LED. Same with the 'Error History' option.
    Considering how the microprocessor appears to be doing the reset thing, surely 'that' has not failed... ?
    One last thing is that even though I can keep looping with short appearances of the display, once unplugged, the relay has to be remotely powered once more otherwise we are back to square one. No display and no fast blinking red LED.
    I now know that I need to trace the PS board relay switching circuit, it's just that I don't have much spare time right now, however it shall be done.
    Any ideas from anyone?
    • Crystaleyes
      • Sep 2021
      • 496
      • Brazil
      Deep diving into the manual, I've arrived at that, 'can't see the wood for the trees' moment so am asking for some help in following the circuitry
      Enclosing the service manual this time...
      The current situation is, that the relay on the SMPS board isn't being activated when the unit finishes it's green flashing LED cycle upon being switched on.
      The on/off switch 'is' sending the 'POWERKEY' (3.3v) signal from the front panel up to pin 9 of U3002 CPU on the HDMI board, however the 'MAIN POWER' signal from CPU pin 127 (and which is needed to turn on the smps relay) is getting lost somewhere beyond U3002.
      I'm struggling to trace the path between pin 127 of the CPU and connector N3601 , where the signal goes via cable directly to the relay. I'm struggling both with the schematics and on the actual HDMI board.
      To clarify, there is no 'MAIN POWER' signal at the N3601 connector, only the Gnd and +5.2v at this point.
      Relevant schematic pages in the manual are on pages 94, 96, 115/116, 121, 138, etc.
      Any advice will be gratefully received.
      • SevenOFF
        Denon AVR-X4000 – Fast red blinking after 2nd relay
        by SevenOFF
        I’m working on a Denon AVR-X4000 that goes into protection mode (fast red blinking LED) shortly after the second relay click.
        According to the service manual, a fast red blinking LED indicates a DC detection (DC_DET) or ASO (abnormal current) fault, meaning the unit is detecting a potentially dangerous condition on the power amp or power supply side.
        Here’s what I’ve done so far:
        • Fully opened and cleaned the unit (a lot of dust inside)
        • Removed and visually inspected the AMP board → nothing visibly damaged or burned
        • Testing is done with
        06-18-2025, 09:54 PM
      • CoinCoin88
        Garage door RX unit (Cardin S38C) does not short relay to send opening signal
        by CoinCoin88
        I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
        Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
        09-15-2025, 03:36 AM
        FUJITSU ESPRIMO E400 ESPRIMO E i3-2120 Specification for Upgrade or Repair
        This specification for the FUJITSU ESPRIMO E400 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ESPRIMO E400 boardview and ESPRIMO E400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for FUJITSU...
        09-12-2024, 03:36 PM
      • sheffieldyorky
        ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
        by sheffieldyorky
        Hey there people
        While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
        This is what I tried, but not in any order.
        Google
        YouTube
        BIOS
        Command Prompt (administrator privileges)
        On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
        10-25-2025, 02:22 AM
      • jm1234
        9V relay temperature 40C
        by jm1234
        Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
        I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
        05-09-2024, 03:03 AM
