Samsung UN65KS9800FXZA T-con fuse blowing
  • Bootleg1
    • Feb 2020
    • 10
    Hi all, so i was watching tv acreen went black and no sound. Traced problem to blown tcon fuse. Replaced and it blows replaced again samething. So my tcon fuse keeps blowing. I bought a new board havent installed yet infear its just going to keep blowing the fuse. If i only connect the right side ribbon cable the fuse doesnt blow but as soon as i connect the left cable my tcon fuse instantly blows and no picture. The right side picture works clear as day and left side picture is grey (picture attatched) im hoping its a bad tcon board itself or a cable or anything and not the panel. Thank you for all your help!!!
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Samsung UN65KS9800FXZA T-con fuse blowing
    maybe a shorted capacitor on the pcb thats bonded on to the lcd panel
    this video shows the pcb board that maybe giving you issues (from about 9 minutes in)
    https://www.youtube.com/watch?v=jLd6QO7Z7m4
    • Bootleg1
      • Feb 2020
      • 10
      Im sorry dont know much but can the capacitor be replaced in that location?
        Yes if you experience with SMD repair.
        • Bootleg1
          • Feb 2020
          • 10
          Not really no but i know someone that can kinda walk le through. Would that bad capacitor constantly cause the tcon board fuse to fail if i don't connect just the left side? And as for the picture on post#1 does that mean the panel could potentially be bad? Sorry im new at this
            Well, did you start checking the resistance of the caps on the tab bonding board as suggested? That is what you should be testing right now.
            • Bootleg1
              • Feb 2020
              • 10
              What ohms is normal?
                Just look for very low Ohms reading, <100 Ohms, that will indicate issue with either caps or IC's.
                • Bootleg1
                  • Feb 2020
                  • 10
                  So im still at work soni havnt been able to check the ohms So hypothetically speaking to be armed with as much knowledge as possible lets say the panel boards are good no shorts. What would cause the tcon fuse to blow almost automatically from plugging in the left side ribbon and not the right? Or the does the problem specifically isolate to the panel boards being bad being the half screen issue? I.e leftside is white and the right side i have a clear picture*check post#1 for picture.
                  The panel cant be bought i spent 4k on this tv three years ago so im just arming my self with all the knowledge i can before tearing into the tv deeper. Thank you for sharing your thoughts.
                  • petehall347
                    • Jan 2015
                    • 4426
                    • United Kingdom
                    can you not claim from samsung as not fit for purpose as you expect it to last more than 3 years ?
                    • Bootleg1
                      • Feb 2020
                      • 10
                      I tried they basically told me to go to he** so im here with little knowledge trying to fix it
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        No, we claim from the vendor not the manufacturer. In this case I think he would win, a 4 grand TV should last longer than three years. I believe we have stronger consumer laws than the US though.
                        • Bootleg1
                          • Feb 2020
                          • 10
                          Anyone else have an input on why the tcon fuse always blows when connecting the left side ribbon cable?
                            Shorts circuit such as caps on the tab bonding board or short IC, i.e COF.
                              • 12164
                              • U.S.
                              DID you do test in post #8??
                              • Tips
                                Samsung PD27AOQ (BN44-00506B) constantly blowing internal fuse.
                                by Tips
                                Looking for some assistance please.
                                Trying to repair a PD27AOQ samsung power board.
                                Initially had the typical problem of cm806 capacitor blown, additionally thermistor NT801s blown.
                                Replaced the ceramic capacitor, str60252s, bridge rectifier, thermistor and fuse.
                                Testing it the fuse blows immediately power is turned on.
                                diodes dm852 and dm853 test as shorted when in the board but fine when removed.
                                any assistance, guidance would be appreciated.
                                04-11-2024, 11:24 AM
                                09-07-2024, 05:50 AM
                              • RogerH58
                                Samsung 46" TV LE46B530 blowing fuse
                                by RogerH58
                                I am a newbie and not very experienced so bear with me if i struggle sometimes with technical language - but I'll do my best. I searched "Samsung" and the model number on the forum but didn't find anything I could understand!
                                I'm not an electronics guy - just picked up stuff over the years through my flight-simming hobby.
                                I have the above mentioned 46" tv as the monitor for my flight-sim setup. Recently it went "crack" and stopped working. No standdby light and no response. I assumed a fuse had blown and after investigation...
                                06-10-2023, 10:27 AM
                              • TR103
                                by TR103
                                - it keeps rebooting
                                01-22-2025, 04:12 PM
                              • JJAAMM
                                by JJAAMM
                                Problem
                                07-06-2023, 06:01 AM
