Vizio E480i-B2 Won't Turn On DPS-167DP IC901
  • R_J
    • 9553
    Re: Vizio E480i-B2 Won't Turn On DPS-167DP IC901
    That will work, but It is unlikely the only problem.
    • 3GsDad
      • Oct 2020
      Originally posted by Digital_Dad
      The parts are ordered and will be here Jan 6th & 7th. I will post an update when they are here and start work on it. I did have to source the IC chip from ebay and I bought 5 of them so if anyone reading this ends up needing one just message me.
      Hey Digital Dad...I know this thread is old but if you have one of these parts still I'm in need of one. Your private messaging isn't working so I decided to just bump the thread.
      • Digital_Dad
        DIY'er
        • Apr 2017
        • 36
        • U.S.A.
        #43
        Yes, I still have a few. Try and PM me again I will keep my eye on it, if I don't reply pretty quickly just come back here and post. We will work it out.
        • stinger
          • Jan 2014
          • 57
          • usa
          #44
          Hi Digital Dad, I am in need of that IC also if you still have one you would like to sell. Thanks
          • Digital_Dad
            DIY'er
            • Apr 2017
            • 36
            • U.S.A.
            #45
            What part number do you need?
            • stinger
              • Jan 2014
              • 57
              • usa
              #46
              I need the LD7913JGM6. It seems like my pm's aren't getting through to you.
              • Digital_Dad
                DIY'er
                • Apr 2017
                • 36
                • U.S.A.
                #47
                I guess my inbox is too full with 30 messages? I didn't think they had a limit.
                I have all three of the parts you listed, shoot me an offer.
                • stinger
                  • Jan 2014
                  • 57
                  • usa
                  #48
                  $8 - $10?
                  • ping.saga
                    • Nov 2020
                    Did you ever fix this problem, I have the IC901 blown. No standby power. I got a replacement board 001(my board is 002). Unfortunately after swapping the replacement board no power either.
                    • squeaks
                      • Nov 2016
                      • 8
                      Hi Digital_Dad,
                      I am also looking for the IC LD7913JGM6. I did send a private message as well. Thanks if you can help. Mike
                      • Rodwillett
                        • May 2021
                        So, after replacing the IC and the ZDiode, did the TV work? Or did you have to replace other components?
                        • Rodwillett
                          • May 2021
                          Originally posted by squeaks
                          Hi Digital_Dad,
                          Regarding the IC901 I have three of them, let me know if you need one.
                          • jlee
                            • Jan 2022
                            • usa
                            #53
                            Anyone know what is the replacement for diode D901? 1Nxxxx?
                            • Camparts54
                              • Feb 2023
                              New here so I may need a tiny bit of help posting correctly. I too have the same problem in a Vizio tv set and will need the common repair parts. I can get back to anyone who suggests test results for components in this PS board. My Tv is also dead with a chip blown out of the same I C. It seems to be a common problem and I wonder if it is worth fixing or not. Anyone with spare parts please feel free to message me. Can't contact Digital Dad because i get a message that his message area is full and needs to be cleared out so that messages will go through.
                              • Mulp
                                VIZIO M65-C1 Does Not Turn On
                                by Mulp
                                Hi All,
                                I am having an issue with my Vizio M65-C1 where it does not turn on. When I plug it in the stand by light on bottom left of screen turns on (white) then fades away. If I press the power button it turn back on and then fades until it is super dim.
                                When I remove cover, there are no illuminated leds on the main board, I've seen others with a red/blue led that turns on.
                                I've done some research and what is interesting is my voltages all seem slightly different from other people. For example +5/3.5v is 3.48V when on which is different from others on here....
                                01-13-2024, 09:57 PM
                              • pajdek
                                Lenovo Y700-17ISK turn on and off
                                by pajdek
                                Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                09-20-2023, 02:49 AM
                              • mrtek
                                Vizio M65-C1
                                by mrtek
                                Hi.
                                picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                07-14-2025, 07:28 PM
                              • RdeveLabs
                                MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                by RdeveLabs
                                To all the members here...
                                Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                05-05-2025, 04:59 AM
                              • reessi
                                Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                                by reessi
                                Hello:
                                I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                                I started on the ACER:
                                Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                                All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                                I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                                10-29-2024, 11:31 AM
