Samsung ue46f5000 standby light flashing
  • Bloopeta
    • Jun 2018
    • 526
    • United Kingdom
    Have a Samsung ue46f5000, wont power on, standby repeadly flashing, 5 times (double flashes)
    Pulled the back off, no obvious domed caps etc, disconnected T con, no difference, disconnected main board, no difference. Tested power board on bench with nothing connected and getting 0 readings on all pins.
    Here are some pics
    • 12276
    • U.S.
    Re: Samsung ue46f5000 standby light flashing
    Check all diodes.
      Here are some pics
      100% sure that you get ZERO Volt on ALL the power supply pins connector?
      The standby must be present to have standby LED flashes, so at the least the standby power supply is putting out something, so recheck the standby power output pin.
      • Bloopeta
        • Jun 2018
        • 526
        • United Kingdom
        Sorry, the actual accurate readings are
        1 B13v 0
        3 B13v 0
        5 Vamp 0
        7 Vamp 0
        9 GND 0
        11 B5v 0
        13 B5v 0
        2 Pwm.Dm 0
        4 N.C 0
        6 BLU ON 0
        8 GND 0
        10 GND 0
        12 A5v On 5.33
        14 PS.ON 3.16
        • Bloopeta
          • Jun 2018
          • 526
          • United Kingdom
          I would have thought powerboard, but would rather repair than replace it, anyone have any ideas as to what may be at fault?
            What is the DC Voltage measured between the two legs of the main cap in the hot side when TV is turned on?
            • Bloopeta
              • Jun 2018
              • 526
              • United Kingdom
              what is the dc voltage measured between the two legs of the main cap in the hot side when tv is turned on?
              333v
                PS-ON (3.16V as reported) is present but the PFC Boosted Voltage is not present, the Voltage on the main filter cap should be around 380 ~ 400VDC range for the rest of the power supply to be working.
                You need to locate the PFC IC, get the spec sheet to get the pinout of the VCC pin so you can verify if it has switched VCC for it to run or not.
                Power supply board P/N is BN44-?????
                • Bloopeta
                  • Jun 2018
                  • 526
                  • United Kingdom
                  ps-on (3.16v as reported) is present but the pfc boosted voltage is not present, the voltage on the main filter cap should be around 380 ~ 400vdc range for the rest of the power supply to be working.
                  You need to locate the pfc ic, get the spec sheet to get the pinout of the vcc pin so you can verify if it has switched vcc for it to run or not.
                  Power supply board p/n is bn44-?????
                  bn4400610
                  • satinser
                    • Oct 2012
                    • 214
                    I have the same issue with double flash of standby. Did you manage to resolve this matter. If so be great if you could advise
                    • neilc6
                      • Nov 2015
                      • 1550
                      Samsungs don't have blink codes and the front LED will flash when booting and will be off when the TV is on. If a Samsung turns on and there is no backlight and you can turn it off, suspect an open LED in the backlight string. First test is to disconnect the main to ps cable and plug in the TV to see if the backlights come on.
                      • satinser
                        • Oct 2012
                        • 214
                        Thanks for your reply.
                        No I know its not a blink code just an indication of an error because of either a fault on power board or main board.
                        Not all Samsung when you remove connector to main board from PSU provide power to backlight. Its diagnostically an excellent way to check the PSU.
                        Are you sure that with this model that will work?
                        Incidentally I know for sure the backlights for this model are not the issue.
                          1) What Voltage testing have you done so far on the power supply connector pins that go to the main board?
                          2) Is your power supply board bn44-00610A, D?
                          3) Most of these new Samsung models have pull-up resistors to allow self test of the power supply board, you can easily verify if it has pull-up resistors or not by checking the Voltages on the power supply connector pins when it is not connected to the main board.
                          • neilc6
                            • Nov 2015
                            • 1550
                            I recently had a UN40F with no backlight which was odd since usually you get dim backlights versus none at all and it was wired as two separate strings. Sure enough, there was an open LED in each string. I rearranged the strips so that one string had a closed circuit so I could check the screen before ordering new strips. I have yet to encounter a Samsung model that didnt have pullups on the power supply.
                            • satinser
                              • Oct 2012
                              • 214
                              Many thanks for your replies.
                              Nothing to do with backlight. PSU number bn44-00610A.
                              The fault was caused by a faulty PFC chip SPC7011F. Didnt have one but managed to find one on a scrap board and when fitted fault cleared and working fine again. I belief the original starter of this thread most probably had the same issue but never posted back if it was ever repaired.
                              So if any members in the future with similar issues with this PSU refer to this link hopefully this info will be of help to them.
                              • Ukdigger
                                • May 2020
                                • 121
                                • England
                                I have the same TV Samsung UE46f5000AK with the same symptoms, when I first got the TV, it turned on then off and back on again 3 times and then stayed on until switched off.
                                The next day it just had a flashing standby light and would not turn on. I held a hairdryer on the CM871 350v 22u cap and then TV turned on after a few seconds and then stayed on until switched off. I haven't got any replacements but I have got some new 450v 22u caps. Can I safely use this as a replacement?
                                PSU number bn44-00610A L46SF_dpn
                                1 B13v 12.4
                                3 B13v 12.4
                                5 Vamp 12.4
                                7 Vamp 12.4
                                9 GND 0
                                11 B5v 5.1
                                13 B5v 5.1
                                2 Pwm. Dm 0.3
                                4 N.C 12.4
                                6 BLU ON 4.7
                                8 GND 0
                                10 GND 0
                                12 A5v On 5.1
                                14 PS.ON 3.4
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  1 B13v 12.4
                                  3 B13v 12.4
                                  5 Vamp 12.4
                                  7 Vamp 12.4
                                  9 GND 0
                                  11 B5v 5.1
                                  13 B5v 5.1
                                  2 Pwm. Dm 0.3
                                  4 N.C 12.4
                                  6 BLU ON 4.7
                                  8 GND 0
                                  10 GND 0
                                  12 A5v On 5.1
                                  14 PS.ON 3.4
                                  yes no problem going up in voltage.
                                  • Ukdigger
                                    • May 2020
                                    • 121
                                    • England
                                    Thanks for the reply, I'll try it today and report back after testing
                                    • Ukdigger
                                      • May 2020
                                      • 121
                                      • England
                                      Worked first time, but this morning was back to the same problem. If I disconnect the main board I don't get any voltages apart from the standby. If I hold a hairdryer on the CP821 450v 100u cap, the back light comes on and stays on and all my voltages are there. I should have tried this first. I will have to order a new cap because the biggest I've got is only 400v 120u
                                      • Ukdigger
                                        • May 2020
                                        • 121
                                        • England
                                        I replaced the CP821 450v 100u cap and the TV worked again. When I switched to a HD channel the tv turned itself off and on again and wouldn't show the HD channel but it worked fine on SD channels. The next day it wouldn't turn on again and has the same flashing standby light problem. Do I need to change the PFC chip SPC7011F as suggested by Satinser?
                                        • Bloopeta
                                          Samsung UE43KU6400U Flashing Red Standby Light
                                          by Bloopeta
                                          Have a Samsung UE43KU6400U that will not turn on, just continuous flashing red standby light.
                                          Power button does nothing
                                          Have unplugged the mainboard, and backlights illuminate.
                                          Have tried removing panel ribbon cables one at a time, and that makes no change.
                                          With mainboard unplugged, all voltages from powerboard seem ok, but with mainboard connected, they never quite reach full voltage, and drop and raise in a constant loop (in time with click noise from mainboard.
                                          Using backlight tester, I get 63.6v on both sides, so seems like no bulbs...
                                          09-11-2023, 02:34 AM
                                        • ChristianBr01
                                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                          by ChristianBr01
                                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                          04-23-2025, 01:48 AM
                                        • Kaar3l
                                          Samsung QLED QE65Q7FNAT only standby light
                                          by Kaar3l
                                          TV: Samsung QLED QE65Q7FNAT
                                          PSU: BN4400940A
                                          MB: BN94-12832K
                                          I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                          09-24-2024, 01:35 PM
                                        • 7ony
                                          Samsung plasma - flashing standby light
                                          by 7ony
                                          The TV is a 2013 Samsung plasma, model # PN60F5300AFXZA.
                                          Snagged it up in non-working condition a couple years ago. Previous owner said that sometimes he could get it to come on after repeated tries but other than that he couldn't get it to turn on.
                                          Personally I haven't been able to get it to turn on at all. The standby light comes on solid when plugged in, but pressing the power button results in the standby light flashing once every 4 or so seconds. No "click" noises, no light from the panel at all. Just the flashing standby light.
                                          No visible...
                                          08-31-2020, 05:18 PM
                                        • fuxxy
                                          Samsung UN55D6000FXZA - Won't stay on, standby light flashing rapidly
                                          by fuxxy
                                          This is a set I posted about a few years ago. Replaced LED strips and worked fine until now.
                                          Plug the set in, and it will turn on and functions with no issues.
                                          After a while, (sometimes hours, sometimes minutes, sometimes immediately) the tv shuts off. When I approach the TV I notice the standby light is flashing rapidly, but the pulse of each flash is not long enough to notice from afar.
                                          Other than the standby light, the unit is completely unresponsive until the power is removed and reapplied, then the cycle starts over. It does appear that the time it takes...
                                          08-02-2022, 09:44 AM
