Vizio E60u-D3. Will not come on. No Stand-By light
  • karthur
    • Nov 2015
    • 150
    Set will not come on when I press the power button.
    Verified it is getting 120v to the set.
    Checked the fuse on the P/S board. Its good.
    Here is what I get when I check the voltages on the connector between the p/s and the main board with 120VAC power connected.
    Pin# (Name) Voltage
    1(VSNS) 0
    11(+16VS) 16
    12(AC-DET)1.9
    13(PS-ON)0
    14(+16VS)16
    15(+16VS)16
    Pressing the "power on" button does not change any of these voltages.
    Trying to determine if I have a problem with the p/s board or main board. I think it is the p/s since there is PS-ON is 0volts.
  • nomoresonys
    • 12145
    • U.S.
    Re: Vizio E60u-D3. Will not come on. No Stand-By light
    PS-ON signal comes from the mainboard.
    • karthur
      • Nov 2015
      • 150
      So the Mainboard is probably the issue? Anything else to check to confirm this is the issue?
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8146
        It's a main board issue as nomoresonys already mentioned. Pson comes from the main IC on the main board. The fact of no stby light is caused by a faulty main IC, or simply the main IC doesn't get any power. So follow the power to see if it enters the main board and goes to the main IC. If it does, then the main IC is bad. If it does not, I guess something is burnt out / an open circuit.
        • karthur
          • Nov 2015
          • 150
          I replaced the main board. Now when I turn on the power, the screeen tries to come on for about 5 seconds or so, but then goes off for a few seconds, then back on again for about 5 seconds. It does this several times then just doesnt come back on again. Here is what I am getting on the connector going between the P/S and the main board.
          Power OFF -
          Pin# (Name) Voltage
          1(VSNS) 0
          11(+16VS) 16
          12(AC-DET)1.9
          13(PS-ON)0
          14(+16VS)16
          15(+16VS)16
          Power ON -
          Pin# (Name) Voltage
          1(VSNS) 2.4 VDC (for 8 sec, then goes to 0, then back to 2.4....repeats)
          11(+16VS) 16
          12(AC-DET)1.9
          13(PS-ON)5.09
          14(+16VS)16
          15(+16VS)16
          I also have a p/s board that I got from ShopJimmy. Put it in and the set does the same thing. Does not change the voltage values that I gave above.
          Any ideas? Only board left is the T-con and the board with the power and volume buttons on it.
          • nomoresonys
            • 12145
            • U.S.
            Maybe unhook backlight plug from powerboard, see if voltages get stable.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8146
              Now you have a problem with the backlight leds. The VSNS probably is in sync with the backlights turning on and off.
              • karthur
                • Nov 2015
                • 150
                I tried unplugging the LED and the T-Con board and the cylcling continued. The only thing left that was plugged into the main board was the speakers. So I unpuged them and the cycling stopped. I reconnected the T-Con and the LED and I now have an image on the screen. The display is no where near correct, but at least I do have an image. I reconnected the speakers and now it does not cycle.
                The rest of the warning is on the other side of the dispay. Obviously, this is not correct. There is not but one other board left. I really dont think the problem is the LEDs, but I guess it is possible.
                Suggestions?
                Thanks.
                • nomoresonys
                  • 12145
                  • U.S.
                  So what do you get when you try to play a source, tv, dvd player?
                  • karthur
                    • Nov 2015
                    • 150
                    Here is what I get with a Direct TV reciever connected.
                    • nomoresonys
                      • 12145
                      • U.S.
                      Did you try updating the firmware?
                      • nomoresonys
                        • 12145
                        • U.S.
                        Maybe try a factory reset, any time I see fluctuating voltages or cycling, I check the solder joints, sometimes they look good but are not, look closely at the solder joints of components on heatsinks and transformer legs they take a lot of abuse, of course it won't always be a bad joint but like Karl Childers does, why not check the easy things first, sometimes that's what's wrong. As always BE VERY CAREFUL what you touch on powerboard, DEADLY voltage on HOT side.
                        • karthur
                          • Nov 2015
                          • 150
                          I can check the solder joints, but I have replaced both the Power board and the main board. I guess the board could be bad.
                          Already tried the Factory reset (unplug and hold in power-on for 10 sec).
                          Have not done a firmware update. Will have to research how to do that.
                          • nomoresonys
                            • 12145
                            • U.S.
                            (unplug and hold in power-on for 10 sec). That's just a quick reset, not a factory reset.
                            • nomoresonys
                              • 12145
                              • U.S.
                              See if that helps: https://support.vizio.com/s/article/...language=en_US
                              • karthur
                                • Nov 2015
                                • 150
                                Updated the firmware and that did not help. Will try the factory reset.
                                • karthur
                                  • Nov 2015
                                  • 150
                                  Factory reset did not help either. When I go to the System setting and look at the details, it says the model is a E70u-d3, which is a 70in screen. I figure that is why the screen image is so messed up. I dont see any wy to tell it the screen size. Figure it gets that info from the screen or other board.
                                  Any other thoughts on what I could try?
                                  Here is a sample of what the acreen looks like. Ots messed up pretty bad.
                                  • budwich
                                    • Jul 2015
                                    • 3097
                                    you have to go into the service menu and set the correct panel.
                                    • karthur
                                      • Nov 2015
                                      • 150
                                      I found these instructions to get to the service menu. My TV only has Power, Vol+, Vol- and Input buttons on the back and my remote does not have a MENU or EXIT button, so I could not do any of the steps I found.
                                      I posted a pic of my XRT-132 remote.
                                      Is there another way to get to the service menu on the model E60u-D3?
                                      Thanks.
                                      Method 1
                                      Turn The TV off.
                                      Press and hold the {CH +} & {CH -} buttons on the TV.
                                      Then press and release the {POWER} button on the TV.
                                      Release the {CH +} & {CH -} buttons.
                                      Now press the {MENU} button on the remote.
                                      You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This is for factory).
                                      Press and hold the {MENU} button for few seconds.
                                      The Service Menu will be displayed.
                                      Method 2
                                      Turn The TV off.
                                      Then press and hold the {POWER} button on the TV.
                                      Keep all three buttons pressed for few seconds.
                                      Method 3
                                      Press and hold the {EXIT} button on the remote for 3 seconds then release it.
                                      Then press the {1} {2} {3} buttons on the remote.
                                      To exit, press the {EXIT} button.
                                      Method 4
                                      Press the {MENU} {2} {4} {8} {9} buttons on the remote.
                                      Method 5
                                      Press the {MENU} {1} {2} {3} buttons on the remote.
                                      • nomoresonys
                                        • 12145
                                        • U.S.
                                        Wonder if you could use a universal remote to try the procedure.
                                        • x_orange90_x
                                          Vizio E550i-A0 no power, no standby light
                                          by x_orange90_x
                                          I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
                                          11-20-2023, 09:49 AM
                                        • p-top
                                          Vizio, E60u-D3, no standby light, no ps_on
                                          by p-top
                                          Have vizio E60u-D3. No standby light. Have searched and read all D??u-D3 posts. posts with same symtoms fixed by new power supply, one guy needed back lights also.
                                          main boards are kinda spendy and, out of stock alot of places. i would like to fix my board.
                                          PS voltages
                                          1 VSNS -2mV
                                          2-5 LED-OUT -2mV
                                          6-10 GND -2mV
                                          11 +16VS 16.29V
                                          12 AC-DET 3.929V
                                          13PS-ON -3mV
                                          14 +16VS 16.29V
                                          15 +16VS 16.29V...
                                          11-27-2023, 10:44 AM
                                        • ChristianBr01
                                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                          by ChristianBr01
                                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                          04-23-2025, 01:48 AM
                                        • bunting78
                                          Vizio D650i-B2 wont trun on and no standby light
                                          by bunting78
                                          First off i want to say hello, as i am new and happy to be in the presence of people that know much more than me in these situations. I have searched through quite a few threads and not found and issue just like the one i am having. I just acquired a Vizio D650i-B2 that I was told just quit turning on and has no standby light. Going through some light diag last night i found that the set has a steady standby 5v at the power board connector. without removing any of the boards yet there is no obvious signs of burning, bloating, or cracking on anything that i see. I unplugged the IR board as i saw...
                                          09-23-2021, 08:53 AM
                                        • fharris1977
                                          Vizio D50u-D1 Dead Set No Standby
                                          by fharris1977
                                          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                          12-28-2023, 10:25 AM
