philips lcd tv 40PFS5709
  • klj2030
    • Nov 2019
    • 13
    • Danmark
    This LCD tv have this strange display, there are sound and picture, but cant use the remote anymore to change channel etc. Just stuck, it runs back and forth between on-off, sound up-down, channel etc. (check the zip file)
    Any ideas?
    Thank you
    Kurt
  • William1967
    • Nov 2017
    • 212
    • Netherlands
    Re: philips lcd tv 40PFS5709
    For that problem there is an update , search for QN141E_012.003.026.128_upgrade_loader_2in1.zip , upzip the file on a USB drive , increase the name of the file to "upgrade_loader.pkg" .
    If the TV set is in STANDBY, then switch the power ON via the remote Control.
    Unplug the mains-cable to get the power OFF, place the USB drive in USB slot 1, plugin the power cable after start up the message "Upgrade in progress" should be vissible.
    Wait for the screen going black and then showing the channel and USB content browser.
    Disconnect the power and connect it after 1 minut to power for a reset.
    Select "TV settings" > "General settings" > "Re-install TV" and finally "Yes" to confirm.
    Now the issue should be resolved.
    • klj2030
      • Nov 2019
      • 13
      • Danmark
      Thank you, will post my progress
      • klj2030
        • Nov 2019
        • 13
        • Danmark
        Could only find QN141E _012.003.086.128 (Date published: 2018-01-09) (Upgrade_Loader). I get the "upgrade in progress", 7-8 minutes. Black screen, Phillips start logo, but no channel and/or USB content browser. Tried several times. Also tried disconnect the power, wait 1 min to power for reset...nope
        • klj2030
          • Nov 2019
          • 13
          • Danmark
          Found this file scc_106572_qn141e_012.003.026.128_upgrade_loader_2in1.zip?
          • yokoono
            • Apr 2010
            • 486
            Have you checked the remote control and the batteries? The latest software is 12.3.086.
            https://files.fm/u/q28uyjr9
            • klj2030
              • Nov 2019
              • 13
              • Danmark
              Yes I have invested in a new RC and. You can use the RC, but only to sound volume, change the channels. Trying to use other sources or TV setup is not possible.... so the smart TV is not so smart
              Thank you for link, I have tried the latest software, will give it another try
              • klj2030
                • Nov 2019
                • 13
                • Danmark
                Ooh, yeah I cant use the autorun... it comes up, pressing ok to update, and it goes back to the "problem" screen.
                • yokoono
                  • Apr 2010
                  • 486
                  For updates try also with the POWER key on the TV pressed until the update starts.
                  • klj2030
                    • Nov 2019
                    • 13
                    • Danmark
                    The uploader pkg as suggested by William1967, shows the software in progress, only the problem still remains after the upgrade.... and I have also tried holding the POWER key on the TV
                    • yokoono
                      • Apr 2010
                      • 486
                      I'm afraid the nand software is corrupt. Philips is famous for this flaw.
                      • klj2030
                        • Nov 2019
                        • 13
                        • Danmark
                        Okay, thanks for input yokoono.... so another mainboard could potentially work? Or can you reset the NAND Flash?
                        • yokoono
                          • Apr 2010
                          • 486
                          You cannot reset nand memory. Must be rewritten. If you have the necessary software and an rt809h programmer. You can replace the motherboard with one with the same code and for the same panel.
                          When rewriting the nand memory it is possible to receive a warning "ci plus key fail" for which no solution was found.
                          • klj2030
                            • Nov 2019
                            • 13
                            • Danmark
                            Okay, if I can find a motherboard, for this model 40PFS5709, then replace the old with the new, I dont have to mess with rewrite/program of nand memory, assuming the motherboard have a working nand memory... correct!
                            • Diah
                              • Feb 2013
                              • 6376
                              use USB 2 mouse or (air mouse Keyboard ) to control the TV and make hard reset from SM
                              • klj2030
                                • Nov 2019
                                • 13
                                • Danmark
                                Hi Diah, thank you for suggestion, USB mouse shows connected, however it is not able to function
                                • Diah
                                  • Feb 2013
                                  • 6376
                                  i didn't understand how it show connected but no function !!
                                  i use always this air mouse keyboard at TVs with RC no function. to control it..
                                  F are function which lead to many item at setup.
                                  • klj2030
                                    • Nov 2019
                                    • 13
                                    • Danmark
                                    Diah, have you had the same problem... as shown in the first post of the thread...pics and video? Im tellin you, it is not possible to acccess setup or any other function.... I can power up, volume control, change channels that is it.... the mouse connect... when I try to use it... it freezes and also turns of the tv sometimes I really value the replies... but Im throwin in the towel...dont have the tools to fix the possible nand memory corruption, as yokoono said... so Philips suck air, and will never buy another one
                                    • Diah
                                      • Feb 2013
                                      • 6376
                                      of course i faced such problem with Philips and another Linux system based TV. its not computation at NAND.. if NAND then you will never have what you saw now.. its Glitch at Firmware. so the Vendor RC key. don't function.. more to clear this Issue.. the TV recieve the IR code. but it will not match the Vendor Key on SW. some time when we use non original RC. such like android app with IR sender we find the TV response .. but on original RC not however the Original RC working fine.. but its IR code when it send to the TV the replay time are shorter than ( android apk) which it had delay value higher.. its same to mouse or the air mouse keyboard..
                                      its up to you... i just want to clear some things many users make wrong judgment on such issue.
                                      i find on my pc archive the service manual for yours Tv chassis TM14.2E its large file to upload over here.. and i found also the UART where once i used before many years.. don't know if you are familiar with UART how to use service port on the tv.
                                      • klj2030
                                        • Nov 2019
                                        • 13
                                        • Danmark
                                        thank you Diah... I will try again with an air mouse keyboard next weekend, I only had USB 2 mouse. The UART and service port no experience
                                        • eccerr0r
                                          old X58 triple channel board... memtest86 memory speed?
                                          by eccerr0r
                                          Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                                          Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                                          Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                                          06-28-2025, 09:06 AM
                                        • spleenharvester
                                          Reverse engineering of 18650 4-channel tester
                                          by spleenharvester
                                          Hi friends
                                          I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                                          05-04-2025, 02:43 AM
                                        • mikey5791
                                          Help on car amplifier only one channel works
                                          by mikey5791
                                          Hi all forum members,
                                          Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
                                          My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
                                          08-06-2025, 10:36 PM
                                        • dicky96
                                          American Audio VLP1500 Distorting on one channel
                                          by dicky96
                                          Hi guys I have a VLP1500 amplifier here - one channels works fine and the other channel distorts even at low volume settings
                                          Protection and Clip LED are off
                                          There is something wrong with the BIAS voltages around T16 and T18 (in particular) on the bad channel
                                          I tested all diodes and transistors in this area in circuit with diode mode - both channels seem identical. Same in resistance mode across all the resistors here.
                                          The output DC voltages on pin1 and pin8 of the 5532D dual op amp at the input of each amplifier module are the same, and the audio...
                                          07-13-2022, 05:25 AM
                                        • dicky96
                                          Hitachi V19B01922 Channel Tune problem
                                          by dicky96
                                          Hi Guys
                                          I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                                          He also has an LG TV, so three screens in the bar
                                          I installed three Satlink ST-6503 DVB-T Modulators
                                          This model https://www.aliexpress.com/item/32916553905.html
                                          These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                                          02-09-2023, 09:20 AM
