philips lcd tv 40PFS5709
  • yokoono
    • Apr 2010
    • 515
    Re: philips lcd tv 40PFS5709
    It's like a computer. If the operating program has driver installed for the used wirelles, it will work. If the computer does not work, you can install the necessary driver. It is not possible on the television. It works with wirelles given by the manufacturer.
    • Diah
      • Feb 2013
      • 6565
      of course you need tp plug the delivered receiver with mouse or key board in tv to make it work..
      about driver no need at all ... over all TV system either Mobile system.. they can function because all designed under ONE licensees ( PLUG AND PLAY )
      • Maalobs
        • Jun 2016
        • 120
        • Sweden
        The complete service manual for your TV-model is free to download from this page:
        https://www.electronica-pt.com/esque...ileinfo/66102/
        Note that the chassis covers many different models, so look up your specific model in table 2-1 to see which sections of the manual are relevant for you.
        If the previous comment about the NAND being corrupted or worn out is correct, then the Linux OS has lost at least one of the filesystems and probably isn't booting correctly.
        If the Linux system doesn't boot, then you don't get drivers loaded for things like USB HID, which means mouse and keyboard.
        The "NAND" is actually an eMMC (Samsung KLM4G1FE3B-B001), which essentially means that the chip contains both a NAND and an onboard microcontroller that simplifies integration of the chip into the rest of your device (this is excellent for ISP capability).
        This chassis doesn't seem to have a UART to the main processor that can be listened to with a serial-TTL adapter.
        As far as I can tell, it only has the Philips ComPair technician's interface, which seems to be I2C.
        Or are the ComPair pins dual function; I2C and UART?
        I'm only familiar with the later Philips models that have the larger DEBUG-port, which contains both UART and I2C for all the processors on the system board.
        If there is no serial output on your model then that's too bad, because if you had access to the serial boot-output of the main processor, you would get error-messages that tell you exactly what's wrong.
        The upg-files are encrypted collections of several flash memories inside the device, so you can't easily access the contents of one specific memory from that file.
        The "solution" is to have a backup in advance of each flash memory chip in your TV, or to find a working dump from another model with the same chassis.
        This dump must be written into a new NAND-chip with a tool like the iFix RT809H, and that chip will then replace the old one on your system board.
        There is an "Eeprom dump thread!" on this forum where you can beg for a working dump.
        The eMMC chip is a 153FBGA package, which is not easy to solder for an amateur, and the ZIF-sockets for BGA are kind of pricey so it would be cheaper to do in-system programming (ISP) with the RT809H.
        In your photo of the back sticker of the TV, you can see a series of numeric codes in the bottom right corner, labelled "option codes".
        These codes tell the system board exactly what features are present in your TV-model.
        There is a process described in the service manual for replacing the system board, and in that process is a step for entering the option codes.
        In case you manage to get hold of a working dump and replace the eMMC, or find a replacement system board (preferably one with a new eMMC already on it), then this is the process you need to follow.
        • Diah
          • Feb 2013
          • 6565
          Originally posted by Maalobs
          If the Linux system doesn't boot, then you don't get drivers loaded !!!!!!!
          This chassis doesn't seem to have a UART to the main processor......!!!!!!!
          I'm only familiar with the later Philips models that have the larger DEBUG-port,.
          where are your points if you are not familiar with UART on this model.. as i wrote i did .. and with usb to TTL ... no need serial socket.. this model it had service point.. with GND RX & TX. always i use free program ( Realterm ) which better than what just you read on SM need ComPair and it suitable to all kind of TV or other platform.
          the last things his NVM Okay.. there are nothing called NAND corruption. if it had one bad sector then his TV will never come this stage hear Radio on it.
          any way we all like to fix issue with less spending and not use easy way to replace boards when it can be fixed.. wrong judgment from behind the screen and you never had this set before under yours hand will cost only OP more.
          • Maalobs
            • Jun 2016
            • 120
            • Sweden
            Please enlighten me; where is the serial connector?
            Does it operate at TTL- or at RS232-levels?
            I have seen questions about this era of models on a Swedish forum where it would had been really helpful to inspect the Linux serial output, but the owners weren't able to experiment to find out if, how and where to find the serial TXD.
            Is it connector CN412?
            From the diagrams it looks like CN412 has the pullups for I2C.
            On the QFU1.2E, there was no Bluetooth RC or USB HID available until Linux had booted, since those were features that were operated by the OS.
            The only input that worked for me while running on the 8051 standby processor was infrared, and rudimentary USB storage for the emergency upgrade mode.
            I wasn't the one who claimed his NAND is corrupt, that was a comment made by someone else earlier in the thread.
            I simply expanded on ways to move forward in case that claim was correct.
            • Diah
              • Feb 2013
              • 6565
              its standard TTL function GND / RX / TX any USB to TTL work on it..
              you gave before link to download SM .. if it was correct to this OP chassis 5700 series then you can see the service point U. on it.. or let the OP upload photo on the rear back cover connection area to see it.
              • eccerr0r
                old X58 triple channel board... memtest86 memory speed?
                by eccerr0r
                Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                06-28-2025, 09:06 AM
              • spleenharvester
                Reverse engineering of 18650 4-channel tester
                by spleenharvester
                Hi friends
                I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                05-04-2025, 02:43 AM
              • mikey5791
                Help on car amplifier only one channel works
                by mikey5791
                Hi all forum members,
                Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
                My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
                08-06-2025, 10:36 PM
              • dicky96
                Hitachi V19B01922 Channel Tune problem
                by dicky96
                Hi Guys
                I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                He also has an LG TV, so three screens in the bar
                I installed three Satlink ST-6503 DVB-T Modulators
                This model https://www.aliexpress.com/item/32916553905.html
                These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                02-09-2023, 09:20 AM
              • dicky96
                American Audio VLP1500 Distorting on one channel
                by dicky96
                Hi guys I have a VLP1500 amplifier here - one channels works fine and the other channel distorts even at low volume settings
                Protection and Clip LED are off
                There is something wrong with the BIAS voltages around T16 and T18 (in particular) on the bad channel
                I tested all diodes and transistors in this area in circuit with diode mode - both channels seem identical. Same in resistance mode across all the resistors here.
                The output DC voltages on pin1 and pin8 of the 5532D dual op amp at the input of each amplifier module are the same, and the audio...
                07-13-2022, 05:25 AM
