Sony KDL-46ex520
  • Global Safari
    • Nov 2019
    • 32
    Re: Sony KDL-46ex520
    I just did a continuity test on the 3 fuses.All tested fine except F6001. Read bad. This is the culprit. Can it be replaced ( looks very small) or is this a whole board replacement.
      https://www.badcaps.net/forum/attach...2&d=1575327673
      As I suspected, F6001. Check the resistance between Ground and the bottom leg of the fuse to see if it shows low resistance reading or not.
      Also check those caps you had marked earlier to see if they show low resistance reading or not.
      You can use through hole type fuse since the board has lots of room for through hole type fuse such PICO fuse.
      • Global Safari
        • Nov 2019
        • 32
        Thanks for the information.
        • Global Safari
          • Nov 2019
          • 32
          Thanks for the information.. what size PICO fuse would I need?
          • Global Safari
            • Nov 2019
            • 32
            Found a pack of ( 6 ) 4 amp 125 volt... will order tonight PICO Fuses.
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • delpiero3
              Sony Vaio SVS MBX-261 board failure
              by delpiero3
              Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
              Nevertheless, let's say, i don't come as a total beginner.
              I have this old laptop, which suit perfectly my needs, with the...
              10-29-2024, 06:16 AM
            • huj3r
              Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
              by huj3r
              Hi there!
              I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
              Photo of the situation after the black shadow dissipates:
              After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
              I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
              > This indicates HFR Communication error. [ HFR Communication...
              08-15-2023, 10:55 AM
            • cheeky2
              Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
              by cheeky2
              For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
              See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
              01-08-2024, 05:56 AM
