Top screen color fading
  • DeatRaton
    Gio
    • Oct 2019
    • 36
    Hi guys this is a TV that is at my friend's house he needs help repairing I told him I'd ask if it's even worth fixing. I will have all specs tomorrow but could this be panel issues and unfixable. Any thought?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Top screen color fading
    It looks like it could be edge lit with the top edge not being illuminated.
    • DeatRaton
      Gio
      • Oct 2019
      • 36
      I will get more info on this TV tomorrow, if it is what you are saying. Most likely it will be salvageable?
      • diif
        • Feb 2014
        • 6978
        • England
        Yes, either by replacing the individual dead LED(s) or the whole strip.
        • RJARRRPCGP
          • Jul 2004
          • 6304
          How new is that TV? Looks like later-2010s to me, and if it is, 99 percent, it's shit LEDs! Or LEDs with shit mounting!
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • DeatRaton
            Gio
            • Oct 2019
            • 36
            This is a UN75F6300
            Version UH02
            2013.
            I found a few posts on this actual TV but they never seemed to get to the bottom of the issue. So I did test the LED capacitors and I got 336 in the lower capacitor and fluctuation between 533v-561v on each of the top three capacitors. Now I'm assuming I'd have to open the whole TV up anyway to check on the LEDs?
            • yokoono
              • Apr 2010
              • 486
              https://www.youtube.com/watch?v=GIfZHsD49WU
              • zomi
                • Nov 2011
                • 505
                https://tinyurl.com/y4o9fztz
                i think they should be the strips
                confirm when you have the tv open
                best to replace them all
                • DeatRaton
                  Gio
                  • Oct 2019
                  • 36
                  Thank you I will confirm as soon as I open it up, just waiting for the weekend to have my brother help me carefully remove the huge screen don't want to crack this beast.
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    If you check the dc voltage across the two legs of each of those capacitors it cannot measure more than 400V, the rating of each capacitor, otherwise the capacitors would explode.
                    I can't quite read the print on the circuit board photo but it looks like the led drive voltage is 237V @ 250mA
                    Shopjimmy do a repair kit for this board which may give you an idea of what to check out.
                    https://www.ebay.com/itm/Samsung-BN4...-/361400226453
                    • Ryan.man
                      by Ryan.man
                      02-04-2025, 12:23 PM
                    • reformatt
                      by reformatt
                      07-31-2025, 08:37 PM
                    • smic717394
                      by smic717394
                      07-25-2024, 10:16 AM
                    • Chrissygizmo
                      by Chrissygizmo
                      02-10-2025, 12:33 AM
                    • KYBOSH
                      Trying To Fix: Samsung UN50TU7000 - Weird Fading Screen then Red blinking light
                      by KYBOSH
                      Picked this up to resurrect.
                      When I plugged it in it comes on for about 1 minute... after a minute the screen blacks out and I gets blinking red lights on the power button.
                      I read that a common issue with this model is a failed BGA so I ordered a replacement on eBay.
                      Sometimes the TV would produce an expanding blob on the screen before going black.
                      See Video here
                      I ordered a replacement board off of eBay and installed it tonight and got the same behavior.
                      Did I get another defective board or is there an issue with...
                      09-16-2024, 07:48 PM
