Sony xbr 75x850e flashing lines
  • codycowgill
    • Aug 2015
    • 21
    https://youtu.be/ICJ084ZxN7w
    Here is a video of the problem. I have replaced every board to no avail. There is no visible screen damage. Pressing on the bottom ribbon cables does nothing. The tcon board makes a faint screeching noise when the lines are present on the screen. Thanks
    • 12085
    • U.S.
    Re: Sony xbr 75x850e flashing lines
    Maybe try the "cutoff tape" method, might not work but won't hurt anything, just be careful not to damage ribbon cables, never force anything, the clamp on the connector usually just flips up with a fingernail: https://www.youtube.com/watch?v=j7vl7-vZEL8
      Panel problem, side tab bond Gate drive. Taped off may work, the panel may be made by Sharp so it may have side tab bond issue.
      • budwich
        • Jul 2015
        • 3097
        as suggested, your problem is probably a side tab problem. IF / when you take the back off, you will see at the bottom of the set where the tcon cables go towards the small narrow edge boards. It is quite likely that you have two narrow edge board "serving" each half of the panel. There is a "u" shaped "flex tape" cable interconnecting the two boards. It is unclampable, much like the cables at the tcon. With the power off / disconnected, unclamp one of the "U" cables.... power up and see what happens to the display / problem. Repeat the process, on the other side "pair" and again see what happens with the display. Go from there with your posted results.
          • 12085
          • U.S.
          Try as suggested in post # 2, if it works it most likely confirms a gate driver issue, which is a panel problem, mostly not fixable without proper equipment, it's quick and easy and what I would try first.
          • codycowgill
            • Aug 2015
            • 21
            Thanks for the help I will upload pics tonight of the boards and panel but this panel does not have side tabs which baffles me. Are they some how integrated within the panel? I will try the tape and dissconectneach side of the tcon board and post the results with pics
            • budwich
              • Jul 2015
              • 3097
              you can't see the side tabs from the back.... you have remove the front bezel to see the tabs.
              • codycowgill
                • Aug 2015
                • 21
                Yes I removed all the side bezels and there are no tabs, even lifted the lcd up a bit and nothing. I started to try the tape method and unhooking one side of the tcon causes just a fully white side with no distortion. Unhooking the other side still causes distortion with the white so I am guessing the side that takes away distortion is the problem side
                One problem though...the screen will no longer display anything...just a black screen. The back light is on and I can tell there is something happening because when I hit buttons on the remote the screen dims and lights up...I tried the reset method with the green light and all but still no picture.
                • codycowgill
                  • Aug 2015
                  • 21
                  Here are some pics. I included one with the side bezel removed. Both sides look the same. No tabs. Lifted lcd layer up a bit and there are none tucked underneath either
                  • codycowgill
                    • Aug 2015
                    • 21
                    Here is a video of the current problem that developed after unhooking tcon board. I can only get something to show up on one side of the picture by wiggling the tcon ribbon while loose.
                    https://youtu.be/j1yoEhf1K8s
                      • 12085
                      • U.S.
                      Could be tab bond problem, here's how to check, just a little light pressure on them see if display changes or clears up: https://www.youtube.com/watch?v=LysMj2Tcp4M
                      • budwich
                        • Jul 2015
                        • 3097
                        That usually means that you don't have the cable align properly in the connector or that there is an issue on the contacts at the end of the cable or in the connector. Look carefully to see what up. Further, when a cable is removed, there corresponding side should be white as you seen. IF that no longer happens, then there is a problem usually with the edge boards (ie. shorted / open smd components).
                        • ggil44
                          Sony XBR-65X750D Horizontal lines bottom of screen
                          by ggil44
                          Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                          05-30-2023, 07:51 PM
                        • Chrissygizmo
                          Sony KD-55XG9505 lines on screen problem
                          by Chrissygizmo
                          Hello again everyone,
                          This is my latest mission, to try getting this Sony tv back to normal working order…
                          I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                          02-19-2025, 11:31 AM
                        • noisykid
                          Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                          by noisykid
                          5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                          12-30-2024, 07:15 PM
                        • stav242
                          Sony KD-55X8509C white flashing/pulsing LED
                          by stav242
                          I was asked to look at a Sony KD-55X8509C as it was not powering on, no lights.
                          On inspection, there was no physical issues.
                          I seated all cables and repowered the TV, then the LED light flashed Green / Amber.
                          - this seems to indicate repairing required, done by Firmware update.
                          so downloaded the latest Firmware from Sony website and wrote to 4Gb USB drive.
                          Inserted the drive and repowered the TV.
                          LED changed to white flashing/pulsing ... and it sat there for over an hour.
                          i was unsure what was happening so repowered the TV and now it just...
                          01-08-2024, 07:39 AM
                        • gpo23
                          Sony KDL-40V3000 - Vertical lines
                          by gpo23
                          i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                          With the new t-con the color are good but there are vertical lines on all the screen :
                          I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                          Is there a way to fix the vertical lines on the new t-con ?
                          Thank you for your help
                          gpo23...
                          10-04-2023, 09:11 AM
