Samsung UE55ES6560 image becomes white issue
  • hmendez86
    • Jun 2015
    • 344
    • united states
    Re: Samsung UE55ES6560 image becomes white issue
    You have a short on the cof board smd caps or t con problem but i wont think of that. For sure cof board problem need to check shorts on board
    • Davi.p
      • Sep 2009
      • 4265
      • Italy - Milan
      I guess the gate drivers are shorted on both sides, then no exits.. but just to be sure rip off that broken tab.and try..
      • disorder
        • Sep 2015
        • 154
        • france
        hi
        can i remove the tab without any other damage ?
        in fact the panel is already dead, and more dead than dead is dead too so...
        but i try to understand things , so if i remove this tab what happen for the tv ?
        thank you
        • disorder
          • Sep 2015
          • 154
          • france
          Re
          Ok i have removed left drivers tab
          Si image Comes but there is another problem : each image persist when the other Comes
          Some pictures to explain
          Thanks again
          edit : when i unplugged the right flex of tcon i have no image just vertical lines again (at left side of the panel), but when i unplug left flex of tcon i have a good image with this remanent thing (ghosting ?)
            • 12081
            • U.S.
            That's exactly what you get with a ripped off tab, did you try the "cut off tape" method first? doesn't look like it, got to be careful whose advice you take.
            • CapLeaker
              Leaking Member
              • 7980
              i have to agree...
              • disorder
                • Sep 2015
                • 154
                • france
                #27
                Hi
                Mmmmh i have read that ripped off is more effective... And cut off more dangerous.
                Can i try to cut the coper lines that rest where the drivers were ?
                Édit : but i can't understand why if i deconnect the left side of thé panel from tcon i have this issue to. If this is due to left damage by ripping , don't have i a good image on right side ?
                Thx
                • Davi.p
                  • Sep 2009
                  • 4265
                  • Italy - Milan
                  #28
                  The bad driver was probably loading down the one on the opposite side 'cause them works in parallel. Have you tryied to clean the ripped side with alcool? Some deposit could make some resistance, but i don't think..
                  The defect of now is not so clear to me, if you have a text on screen at moment 1, at moment 2 you have 2 texts in different positon, at moment 3 you have 2 or 3 texts?
                  Consider that much probably it can be broken also the remaining side.
                  I suggest you for the future to get a complex surge discharger to place at mountain of the TV/game console/hifi/other..
                  If your balls are not broken you can check VGL,VGH on tcon..
                  • disorder
                    • Sep 2015
                    • 154
                    • france
                    #29
                    in fact each image rest on screen for 2 seconds and then disapear. example :
                    at time 0 : only one good image
                    at time 1 : first image remain and appear second image
                    at time 2 : first image start disappear, image 2 remain and image 3 appear
                    at time 4 : first image disapear , 2nd start disapear, 3rd remain and 4th appear
                    etc....
                    as if the panel was not reinitialised between each image (don't know if this the principle but don't know how explain better)
                    and only at the power on of the tv when smart tv appear i have a white cloud center at the middle up that becomes black after 1 second. i will do some more pictures.
                    • Davi.p
                      • Sep 2009
                      • 4265
                      • Italy - Milan
                      #30
                      Ok it's clear..
                        Gate tab bond failure.
                        https://www.badcaps.net/forum/attach...3&d=1568419012
                          • 12081
                          • U.S.
                          #32
                          Just to clarify, where was the tab you pulled off, top bottom or side of tv as you look straight at it like you would if you were watching a program on it.
                          • disorder
                            • Sep 2015
                            • 154
                            • france
                            #33
                            hello
                            i have only remove the side ones, only one side of course
                            but i think this tv had two issues :
                            suddenly during testing, the image disappear totaly and now i have a black screen : remember i said that i have a C01 on the right tcon panel shorted. now, when i plug the right tcon panel, the tcon board goes security and no voltages are on it. when i unplug it, all voltages are good on tcon board.
                            so i had a burn side driver tab at left, and faulty tcon panel board at right. maybe due to a tab bond issue effectively.
                            this one is dead. RIP
                            thanks help me to learn something more !
                            • Davi.p
                              • Sep 2009
                              • 4265
                              • Italy - Milan
                              #34
                              I don't know what's a "tcon panel board", do you mean "panel board"? Then the large board glued onto flats that are themselves glued to panel? Have you tried to change that small cap.? Maybe it was the reason for the ghosting!
                              • disorder
                                • Sep 2015
                                • 154
                                • france
                                #35
                                hi
                                yes that is : panel board.
                                i remove the cap of course and short still here, try to locate another component that could creat that short but none find
                                i have searched the short with the panel disconnected of tcon of course.
                                thx
                                • Davi.p
                                  • Sep 2009
                                  • 4265
                                  • Italy - Milan
                                  #36
                                  one method: connect to tcon only left part, the panel board has some different tensions on the various caps, since left and right board are almost equal find the tension on the corresponding cap as the one that results shorted on right part, then apply that tension with esternal current regulated PSU to that cap. The item that starts to get hot is the one shorted.. this is probably a time waste, i guess the shorted part is a gate tab..
                                    • 12081
                                    • U.S.
                                    #37
                                    Originally posted by disorder
                                    hello
                                    We are here to try to save stuff from the landfill, next time you have a tv with the classic double image..JUST put a little piece of tape over the ribbon connector per the video, it might not always work but it's cheap effective and it won't fook nothing up.
                                    • Davi.p
                                      • Sep 2009
                                      • 4265
                                      • Italy - Milan
                                      #38
                                      disorder check your personal mail please..
                                        09-07-2024, 05:50 AM
                                      • shlomim412
                                        samsung ua55es6800 - no image
                                        by shlomim412
                                        hi
                                        having problem with samsung ua55es6800
                                        tv had backlight on, sound working - responds to the remote control but no image.
                                        check tcon board - had 12v in but no other voltages present.
                                        when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
                                        when leaving only left side connected - again no voltages and no image.
                                        put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
                                        kept trying to block less pins on the left ribbon cable...
                                        05-15-2024, 05:00 AM
                                      • vincentedel
                                        Samsung SyncMaster 740n Phase Control Issue
                                        by vincentedel
                                        I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                        I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                        04-22-2025, 12:33 AM
                                      • Manucsl
                                        QE65Q800TATXXC Samsung TV Issue
                                        by Manucsl
                                        Hello.
                                        My TV is a QE65Q800TATXXC Samsung TV.
                                        Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                                        Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                                        Any ideas to check would be very appreciated 😊
                                        After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                                        02-19-2025, 07:47 AM
                                      • x_orange90_x
                                        Samsung LN37A550P3FXZA White screen with image
                                        by x_orange90_x
                                        So I've had this TV for a while now and I'm just getting around to trying to fix it. It has a bright white image right off the bat (as of now). Colors are normal and the image looks good, however the entire screen is washed out with white and subtle ghosting. I found a thread somewhere which someone claimed it was the long strips connecting the TCON to the LCD which were bowing and shorting out on the metal LCD frame. I took mine apart and found exactly that. They were bowed out, so I put electrical tape across them along with some padded spacers. Previously, before doing this, the image was polarized...
                                        03-26-2020, 02:06 PM
