Samsung UE55ES6560 image becomes white issue
  • disorder
    • Sep 2015
    • 156
    • france
    hello
    i need some help for a tv samsung.
    backlight and sound ok
    the image does two things :
    -vertical white lines,
    -screen progressively becomes white
    the lines can occur first at the middle or the side and fast appear everywhere
    when i check the t-con board, serial : lsj550hw04, on the left side, i see two circuit that is very similar with a IC regulator D9323.
    when i test them, only the resitance at Vout are different, but at Vout of the chip i have 3V for the bottom one that seems ok, but only 1,1V at the upper one.
    can my problem due to this ?
    thank you
    Re: Samsung UE55ES6560 image becomes white issue
    We need pictures of the whole backside of the TV showing all the boards, and then the screenshot of what you are seeing on the screen.
    • chrismurphy
      • May 2014
      • 251
      • australia
      T con fault if whole screen affected
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4341
        • Italy - Milan
        Post tcon picture very bright and one or more screenshot
        • disorder
          • Sep 2015
          • 156
          • france
          Hello
          Here some pictures
          I have inverted the two ic and the voltage are the same so they are ok
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4341
            • Italy - Milan
            I'm wondering why you do modifications whitout the advice of the forum, the risk is to make unusable good parts to sell. The pictures change every thing, this is a common panel fault, none of the users since many years has discovered a solution for this, what i can suggest is to disconnect the tcon output flats one at a time and see if you have a good half screen, but don't expect much!
              • 12206
              • U.S.
              Could try the "cut tape" method, might not work but won't hurt to try: https://www.youtube.com/watch?v=j7vl7-vZEL8
              Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND IT'S ALWAYS IGNORED SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS.
              • disorder
                • Sep 2015
                • 156
                • france
                hi
                thanks for the information
                it's not a problem for me to desolder-resolder IC chips. i fix many other stuff but i'm not good as i want for tv t-con and motherboard yet..
                when i unplugged the left or right flex, the screeb does exactly the same on the side plugged.
                i have already seen this repair by tape but never really understand it, can you explain me how thecircuit works on this lines ?
                my impression is that the pixels of the tv can never go black when they were "open" by signal. that's it ?
                thanks you all
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4341
                  • Italy - Milan
                  There is no solution. Forget it..
                    • 12206
                    • U.S.
                    Seen MANY MANY panel problems solved on youtube alone, some of the techniques are simple some are complex. Just because one self proclaimed "genius" doesn't know the solution doesn't mean a real one can't get the job done.
                      Since the tab bonding boards are on the bottom edge of the panel which can easily be damaged by the cleaning liquid.
                      1) I would start checking the Voltages at the test points on the T-CON board, I.E. VGH, VGL, VCC, etc.
                      2) Inspect the tab bonding boards for damages.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4341
                        • Italy - Milan
                        Genius? Noooo, you understand very few..
                        Let's see the Pro what have to say to us, you have open field....
                        i'm happy to discover new things..
                          • 12206
                          • U.S.
                          No comprendo????????????????????????????
                          • brucetv
                            • May 2015
                            • 281
                            • united states
                            Since this is a ES series also check the connector's for any arcing. This can cause vertical lines and boot looping issue's. It will be the cable going from the power supply to the main board. Unplug and look for dark brown or arcing in the pins.
                              • 12206
                              • U.S.
                              Yep, do as post #11 advises.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4341
                                • Italy - Milan
                                Now i use translator..
                                You understand very little ..
                                Let's see what the Professional has to say, you have a free field ...
                                  • 12206
                                  • U.S.
                                  • disorder
                                    • Sep 2015
                                    • 156
                                    • france
                                    Hello
                                    Stay calm friends
                                    I have find the culprit there is a tab bonding at the left side that is dead
                                    And find short on c01 on panel tcon
                                    • Diah
                                      • Feb 2013
                                      • 6376
                                      . credit to bud
                                      • disorder
                                        • Sep 2015
                                        • 156
                                        • france
                                        Do you think i Can bypass from tcon to it ?
                                          09-07-2024, 05:50 AM
                                        • shlomim412
                                          samsung ua55es6800 - no image
                                          by shlomim412
                                          hi
                                          having problem with samsung ua55es6800
                                          tv had backlight on, sound working - responds to the remote control but no image.
                                          check tcon board - had 12v in but no other voltages present.
                                          when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
                                          when leaving only left side connected - again no voltages and no image.
                                          put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
                                          kept trying to block less pins on the left ribbon cable...
                                          05-15-2024, 05:00 AM
                                        • vincentedel
                                          Samsung SyncMaster 740n Phase Control Issue
                                          by vincentedel
                                          I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                          I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                          04-22-2025, 12:33 AM
                                        • Manucsl
                                          QE65Q800TATXXC Samsung TV Issue
                                          by Manucsl
                                          Hello.
                                          My TV is a QE65Q800TATXXC Samsung TV.
                                          Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                                          Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                                          Any ideas to check would be very appreciated 😊
                                          After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                                          02-19-2025, 07:47 AM
                                        • x_orange90_x
                                          Samsung LN37A550P3FXZA White screen with image
                                          by x_orange90_x
                                          So I've had this TV for a while now and I'm just getting around to trying to fix it. It has a bright white image right off the bat (as of now). Colors are normal and the image looks good, however the entire screen is washed out with white and subtle ghosting. I found a thread somewhere which someone claimed it was the long strips connecting the TCON to the LCD which were bowing and shorting out on the metal LCD frame. I took mine apart and found exactly that. They were bowed out, so I put electrical tape across them along with some padded spacers. Previously, before doing this, the image was polarized...
                                          03-26-2020, 02:06 PM
