XVT3D554SV - Blinking Amber / White - PS Damage
  • jason123
    • Oct 2015
    • 1068
    Hi folks
    Picked up this TV that had cycling Amber / White. Sent the board to Nick's TVs for repair.. after 4 attempts, I got the main board back with Proof of operation video.
    It's doing exactly the same thing in my set. Amber / White flashing - then white, then repeat (Ethernet port shows activity now) I don't get any picture, backlight, or any other sign of life
    All fuses on Main, and Tcon are ok. 12V is not coming on - and I can't really tell if the Main is issuing the ON signal - However in the process of removing the PS card (I was going to solder wires to force set on), I noticed a black charring around R38 and some on the leads of Q10 (See photos) - might explain why the 12V is not coming on.
    Any thoughts on how to repair this? Anyone with a schematic that can help me troubleshoot this board? Replacing the Transistor would fix it? I don't know the value of the R38, but it's reading 635 kOhm
  • R_J
    • 9535
    Re: XVT3D554SV - Blinking Amber / White - PS Damage
    Replacing Q10 will not fix the problem, you will also need ic8, R40,D13. also R38 is in the gate circuit it could be around 10~30Ω Also R39 (could be a 1k)
    I suspect R45 is open also
    Remove the baord and inspect the parts on the other side where ic8 is located.
    There may also be more wrong with this board.
    This was likely your problem all along not the main board
    • MIGUELMURILLO79
      • Sep 2019
      • 6
      • Ecuador
      amigo buenas tardes, Miguelmurillo te saluda podrías verificar la Eepron.
      • jason123
        • Oct 2015
        • 1068
        Thanks R_J.. will check shortly. The main board has many shorted Caps (indicative of U41 Failure) - That's the first time I sent it. Got it back non-responsive - they ended up replacing main CPU (re-ball) - then last trip a capacitor that was fully shorted (they say).. so I think all 3 attempts were needed. Funny they claimed they tested it in a set each time prior to shipping. Only the last attempt was returned with proof of test video.
        Thanks again
        • jason123
          • Oct 2015
          • 1068
          Thanks Miguelmurillo79. I don't speak Spanish, but I gather you suspect it's the EPROM? the damage seems to be on the Power Supply board.
          Thank you
          • jason123
            • Oct 2015
            • 1068
            R39, and R45 are open
            R38 is cracked in half
            R40 is open
            D13 shorted
            D18 shorted
            IC8 is cracked (Can't make out part number)
            Do you know of a repair kit? you seem to know exactly what's bad on this board.
            • jason123
              • Oct 2015
              • 1068
              FAN7602 IC8??
              Circuit looks different than the datasheet for that fairchild part. Trying to identify type of Diodes and resistor values.. any help is much appreciated.
              Thank you
              • jason123
                • Oct 2015
                • 1068
                Trying to identify some of the busted components and help is much appreciated.
                R45: Band 1 Orange, Band 2: White, Band 3 (silver must be gray) and Band 4 is gold and band 5 is green: 39.8 Ohm 0.5% Tol?
                R39: Brown, Black, Unknown, Orange and Gold: 10x kOhm 5%
                R38: Yellow, Red, Unknown, Black, Gold: 42x Ohm 5%
                Anyone had a board that can measure those for me? Also, on the back several diodes are shorted, any idea what type / spec diode these are?
                  R45 is 0.39 Ohms, what do get on your Ohm meter?
                  The other 2 you can go to Shopjiimy to see if they have good clear pictures of your board.
                  • jason123
                    • Oct 2015
                    • 1068
                    Hi budm
                    R40 is open
                    D13 shorted
                    D18 shorted
                    IC8 cracked in half
                    Tried shopjimmy... not much luck.. good picture, but difficult to make out colors
                    • jason123
                      • Oct 2015
                      • 1068
                      Just bought a new PS board -
                      R45 measures 0.41 Ohm
                      R38 measures 46 Ohm
                      R39 362.9 Ohm
                      R40 5.1 Ohm
                      IC8 FAN7602
                      • jason123
                        • Oct 2015
                        • 1068
                        R38 measures 46.4 Ohm out of circuit
                        R39 .999k (1 KOhm) Ohm out of circuit
                        • jason123
                          • Oct 2015
                          • 1068
                          Any additional tips or hints on how to go about repairing this board would be much appreciated. I replaced all the above component (guessed on the diodes, I used Schottky 60V 1A 1206 Package part) and no change - None of the rails other than the STBY is coming on.
                          • jason123
                            • Oct 2015
                            • 1068
                            @budm & @R_J, any input?
                              So the TV is now working after installing the new power supply board, and now you want to fix the old power supply board, correct?
                              • jason123
                                • Oct 2015
                                • 1068
                                Yes budm...
                                  Did you replace MOSFET Q10 too?
                                  R39 is replaced with 1K, correct?
                                  ZD4 tested OK?
                                  • jason123
                                    • Oct 2015
                                    • 1068
                                    Yes, Q10 is replaced
                                    R39 is 1k Ohm 1/4 watt
                                    ZD4 is shorted (in and out of circuit) - Any idea what replacement I should get?
                                      Trace out to see how that ZD4 is connected in the circuit.
                                      https://www.shopjimmy.com/vizio-fsp2...nit-board.htm#
                                      FAN7602
                                      It is may be connected like as shown in the application circuit page 12.
                                      • jason123
                                        • Oct 2015
                                        • 1068
                                        Could this be right? It doesn't match app notes or datasheet connections. It's missing that Pin 1 of IC also goes to other parts on the board.
                                        • shahnld
                                          Sony kdl 65xg9505 green amber blinking
                                          by shahnld
                                          Good Day.
                                          I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                          i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                          green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                          01-03-2024, 03:05 PM
                                        • crewdog
                                          Hp 15-dy2087nr white lights blinking
                                          by crewdog
                                          Board DAOP5HMB8F REV F
                                          Model OPSH
                                          No bios battery on board
                                          Power at cord 19.7, swapped cord 19.7V just to test, tested lid switch good
                                          Plugged in, battery in, charging port light on solid white, press power button, no fan spin, charging connector
                                          and power on light both blink white, not in sync, battery voltage 12.2 jumps to 13.0 for a second and then back and repeats.
                                          Not plugged in, battery in, press power button, no fan spin, power on only blinks white until battery removed, battery 12.7 - 12.1 for a second and then back and repeats....
                                          10-25-2023, 03:08 PM
                                        • ahmarzo
                                          Hp 15-cs laptop 5 times dc jack blinking white
                                          by ahmarzo
                                          I have two laptop hp15- cs1000tx with motherboard part no DAG7BDMB8F0 REV F
                                          First one was not powering on when battery is connected the first n channel MOSFET was short and after changing the laptop started on power and battery and charging fine
                                          Second laptop has water damaged on ram ic after cleaning and changing the ic the laptop is working fine now
                                          But now I have power led continuously blinking 5 times in both the laptop even after shutdown and when it is powered on the led keeps blinking 5 times .both the laptop is charging and working on both battery...
                                          12-28-2024, 04:46 AM
                                        • noipi
                                          DELL INSIPRON 14 No power blinking orange/white
                                          by noipi
                                          i have DELL INSIPRON 14 5410 2-IN-1 blinking orange and white when charger connected, i tried to find Boardview or schematics but cannot find. i opened the unit and the motherboard model number is 203071-1 Watchmen that i found written on motherboard. Where should i start because when i press power on, nothing happens. but i checked the main power rails voltages are enabled and the charging for battery LDO is 3.3 volts.
                                          05-06-2025, 08:08 PM
                                        • jorpec
                                          HP Elitebook 8460p battery led white and blinking orange
                                          by jorpec
                                          Hello everyone
                                          I have this Elitebook that wont turn on, only the battery led is white and blinking orange, does this even without battery.
                                          If this is a error code i couldn't find any info about it.
                                          Already tested with a another charger, measure the presence on 19v on the 19v rail, checked if there was capacitors in short-circuit
                                          Thanks...
                                          05-05-2025, 04:39 AM
