DELL INSPIRON P66F BLINKING AMBER 3 TIMES AND WHITE LIGHT 5 TIMES
  • NConstantinou
    • May 2017
    • 353
    • Cyprus
    I REMOVED INTERNAL BATTERIES AND I SUBSTITUTE RAM BUT STILL THE SAME.
    WHEN I PLUGIN CHAGER I DO HAVE 3.3,5 AND 1.8 V. AND ON PL700 I GET 0.27V.
    BIIOS PINS 7,8 I HAVE 3.3V
    IS THE PROBLEM ON MOTHERBOARD OR BIOS.
  • NConstantinou
    • May 2017
    • 353
    • Cyprus
    I WOULD LIKE TO MENTION THAT I FLASH BIOS AND NOW FAN SPINS BUT NOTHING ON SCREEN AND STILL THE SAME WITH FLASH LIGHTS
    • mon2
      • 14742
      Which motherboard? LA-802P?
      Remove all power. Meter in resistance mode. Measure the resistance to ground of PL700. What is the resistance in ohms?
      • NConstantinou
        • May 2017
        • 353
        • Cyprus
        PL700 IS 9K. WHEN POWER ON I DO HAVE 3.3,5,1.8,1.2,0.6,1.35,0.9 BUT ON PL700 I GET 0.05V
        I FOUND A SCHEMATIC AND PL700 HAS TO DO WITH BATTERY WHICH IS NOT CONNECTED SO IT IS CORRECT.
        BUT MOTHERBOARD SWITC ON FOR A MINUTE AND THEN SHUTDOWN. NO DISPLAY
        IN ORDER TO POWER ON AGAIN I HAVE TO WAIT TO DISCHARGE 2-3 MINUTES AND THEN PLUGIN AGAIN TO POWER ON.
        PL605 HAS NO VOLTAGE I WILL SEE THAT
        • NConstantinou
          • May 2017
          • 353
          • Cyprus
          CHECKING THE IC PIN VSWH I GET 10 OHMS TO GROUND. IS THAT NORMAL!
          • NConstantinou
            • May 2017
            • 353
            • Cyprus
            I DISCONNECTED PIN1 OF PL605 AND I NOTICED THAT THERE IS NO OUTPUT FROM IC 605 PIN8 VSWH.
            THAT MEANS I HAVE TO ORDER AOZ5019QI_QFN23
            • ahmarzo
              Hp 15-cs laptop 5 times dc jack blinking white
              by ahmarzo
              I have two laptop hp15- cs1000tx with motherboard part no DAG7BDMB8F0 REV F
              First one was not powering on when battery is connected the first n channel MOSFET was short and after changing the laptop started on power and battery and charging fine
              Second laptop has water damaged on ram ic after cleaning and changing the ic the laptop is working fine now
              But now I have power led continuously blinking 5 times in both the laptop even after shutdown and when it is powered on the led keeps blinking 5 times .both the laptop is charging and working on both battery...
              12-28-2024, 04:46 AM
            • YasaCh
              Sony kdl 40p5500 red light keeps blinking 3 times
              by YasaCh
              Hello...
              my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
              i opened the back cover no sign of damage on the powery suply or motherboard
              when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
              another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
              07-07-2025, 11:53 AM
            • shahnld
              Sony kdl 65xg9505 green amber blinking
              by shahnld
              Good Day.
              I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
              i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
              green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
              01-03-2024, 03:05 PM
              DELL Inspiron 3650 Inspiron i7-6700 Specification for Upgrade or Repair
              This specification for the DELL Inspiron 3650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3650 boardview and Inspiron 3650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
              09-12-2024, 03:44 PM
              DELL Inspiron 3650 Inspiron i5-6400 Specification for Upgrade or Repair
