Westinghouse LD-4695 T-Con Mainboard Mismatch?
    • 12331
    • U.S.
    Re: Westinghouse LD-4695 T-Con Mainboard Mismatch?
    If you have some internet wifi module deal unplug it so we can take it out of the equation for now.
    • pdog_phatpat
      • Aug 2009
      • 37
      It's total bullshit that they hide how to get into service menu, what they need to do is put in full instructions and have it readily available of how EVERYTHING in service menu works and what to be careful not to mess with and have a simple reset in case you do adjust something wrong.
      Yeah, it is BS. I kinda think maybe there is no service menu, only board revisions/firmware to work with different parts. I'm certain this TV would work if I could access a service menu, but it may not have the ability to do so.
        • 12331
        • U.S.
        Did you try post #11 step by step? need to hit return key on remote if you get that far.
        • pdog_phatpat
          • Aug 2009
          • 37
          Yes. The W logo never blinks.
            • 12331
            • U.S.
            Check your remote batteries sometimes when they are low the remote acts up, it is paired to tv? some need to be.
            • pdog_phatpat
              • Aug 2009
              • 37
              They are new batteries. It isnt just the remote that acts weird sometimes, the side touch board, besides the + - volume being reversed, will also bring up that "Lets Get Connected" menu if you press the buttons fast enough. I've posted a few pics of the touchboard. I wonder if I would need physical buttons, or maybe a jumper to do the button combo you posted.
              • pdog_phatpat
                • Aug 2009
                • 37
                I'll tell ya, I dont think there actually is a service menu on these things. Maybe the old ones had them. But if they have them, why doesnt ANYONE know how to access it? You would think that after all these years, there has to be SOMEONE who worked on these that let that info out. Yet, no one here seems to know. I've searched online for hours upon hours and havent been able to find it. Its like it doesnt exist. So yeah, maybe it doesnt exist because there isnt one. Its garbage because I'm certain this has a perfectly working panel but I'd have to pay someone 80-100 bucks for a mainboard that *might* *hopefully* work. UGH.
                • nicholas1110
                  • Aug 2012
                  • 127
                  • usa
                  #28
                  Just a idea, you could buy a eeprom from shopjimmy for the main board that you suspect goes in your tv. I'm pretty sure there is only 2 main boards for that model. The eeprom come programmed with the panel info so that should solve your issue.
                  • pdog_phatpat
                    • Aug 2009
                    • 37
                    I thought about that. The concerns I have are 1. Is the main board physically different(would the eeprom work for this MB)? 2. My soldering skills are ATROCIOUS and I have crappy equipment so I'd have to find someone to do it for me(not a huge deal). I've truly only seen 2 different types of mainboard(with diff firmware numbers) for this, they do look similar but I wouldnt know what to look for. I will admit to buying a different TCon, one that is physically diff from the other one I bought and it produced a ghosty white image and vertical panels. So yeah, that was a bust.
                    • R_J
                      • 9624
                      There are many differences between the two boards, if you go to shopjimmy and compare the two you will see some of them, as an example RN20 & RN21 [dual 0Ω] (between U1 and the lvds connector) are on your board (60EB41M0Ma02P) but are missing on the (60E41M0SA01P) I suspect there are others, or maybe that is the difference that is causing the issue? who knows.
                      • pdog_phatpat
                        • Aug 2009
                        • 37
                        Thats what I was afraid of. Thank you for the information and taking your time to check that. So I guess...I dont know. I toss a TV that has an otherwise perfectly working LCD panel? Seems pretty dumb. Anybody else have any ideas?
                          • 12331
                          • U.S.
                          #32
                          What's the issue? does the tv work without that clip hooked up at all not soldered in at all? if not then you might need the other mainboard. I wouldn't invest too much in a westinghouse, the customer reviews are pretty awful.
                            • 12331
                            • U.S.
                            #33
                            Ok, now is the board with this number 60.EB41M.0MA on the sticker, the one that is NOT matching up?
                            • pdog_phatpat
                              • Aug 2009
                              • 37
                              Thats a good question. I didnt think of that. I contacted the previous owner who said she would try to get me the picture they took of the old mainboard they replaced. She said she had forgotten and would look. Not sure how that will help things, I just would like to know.
                                • 12331
                                • U.S.
                                #35
                                OOps wrong thread. first sentence was meant for different thread.
                                • pdog_phatpat
                                  • Aug 2009
                                  • 37
                                  60EB41M0MA01P is the board thats in there now.
                                    • 12331
                                    • U.S.
                                    #37
                                    It's looking like you need 60.EB41M.0SA, I think the other folks ordered the M.OMA and that's probably where the problem lies.
                                      • 12331
                                      • U.S.
                                      #38
                                      Now the 15 dollar eeprom on ebay might be the same for both mainboards and might work, someone with just a little soldering experience could probably get the job done, it's a 20 minute job with a coffee/beer break in the middle, even if you are slow. BUT if the boards are different then it probably wouldn't work, but if it's just a firmware problem it might work, at this point I would take the 15 dollar gamble on the eeprom.
                                      • pdog_phatpat
                                        • Aug 2009
                                        • 37
                                        I agree. She said they gave the person they bought the "new" board from the numbers off the board and thats what they seller sent them. I'm not sure why they didnt return it and try for a diff board but she said they were over it at that point and just wanted to cut their losses and get rid of it. I would like to know exactly what board was in there they replaced to begin with. If they still have the old one or a decent picture of it we could put this to rest. The TV is worth maybe $50 working to me and I have $16 in it by fault of me throwing 2 T-Cons at it. If someone with the right mainboard would trade me for mine plus a little cash that would be super swell. The chances of that happening are slim.
                                        • pdog_phatpat
                                          • Aug 2009
                                          • 37
                                          Picture I was sent of the "old" mainboard was terrible. Picture taken of a picture on a monitor screen. She doesnt have anything better. Not gonna post it here because the resulting laughter at my expense would just be insult to injury, lol. I can make out that there is nothing populating the RN20 & RN21 locations. So, the original defective board was the correct board(obviously) and they did indeed get the wrong replacement board. I'm done harassing her over something she gave me for free. I'm going to try to sell the mainboard in the TV, and then put the $ toward one I found online for a decent cost.
                                          • kca
                                            by kca
                                            Hello all ~
                                            08-31-2025, 06:38 AM
                                          • alro7779
                                            Westinghouse WD32HN1640-S black screen-no backlight, mainboard TP.MS3393.PB818
                                            by alro7779
                                            Hello, guys!
                                            I have this Westinghouse 32" LCD TV that turns on, standby led lights up (blue) but no image. If I knock on the screen there's no backlight present. I took the back cover off and injected voltage on the led connector using a Led TV Backlight Tester, and no light at all, so... it must be that there's some bad Leds, right? Or there is some another testing that should I have to do? Any guiding I'll appreciate it very much. Thanks in advance!
                                            Alex....
                                            10-03-2025, 05:49 PM
                                          • x_orange90_x
                                            TCL 50S535 bad tcon or panel issue?
                                            by x_orange90_x
                                            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                            03-29-2025, 11:02 PM
                                          • mmartell
                                            General Questions on the Relationship Between Mainboard, TCON and Panel
                                            by mmartell
                                            My goal here is to be able to use boards on hand to swap into faulty sets when the faulty board is not obvious.
                                            I will start by asking what is the format of the output from the mainboard and is it generic in any way or does it vary by manufacturer and/or model ?
                                            And as far as I know a tcon and panel must be a matching pair because the timing of the signals and the voltages required to drive the panel are specific to the panel itself. (That may be a blanket statement that isn't true in some cases where the panel creates its own sub-voltages on its panel boards?)...
                                            01-06-2024, 01:32 PM
                                          • advant
                                            by advant
                                            02-03-2020, 12:25 AM
