Westinghouse LD-4695 T-Con Mainboard Mismatch?
  • pdog_phatpat
    • Aug 2009
    • 37
    Re: Westinghouse LD-4695 T-Con Mainboard Mismatch?
    Just to put a bookend on this. I found a mainboard 60.EB41M.0SA. Installed it. TV works as it should. There are 2 main boards for these TVs. Make sure you get the correct one. Thanks to everybody who helped, it was appreciated!
    • nomoresonys
      • 12330
      • U.S.
      #42
      Thanks for the follow up, glad to hear you fixed it.
      • kca
        by kca
        Hello all ~
        08-31-2025, 06:38 AM
      • alro7779
        Westinghouse WD32HN1640-S black screen-no backlight, mainboard TP.MS3393.PB818
        by alro7779
        Hello, guys!
        I have this Westinghouse 32" LCD TV that turns on, standby led lights up (blue) but no image. If I knock on the screen there's no backlight present. I took the back cover off and injected voltage on the led connector using a Led TV Backlight Tester, and no light at all, so... it must be that there's some bad Leds, right? Or there is some another testing that should I have to do? Any guiding I'll appreciate it very much. Thanks in advance!
        Alex....
        10-03-2025, 05:49 PM
      • x_orange90_x
        TCL 50S535 bad tcon or panel issue?
        by x_orange90_x
        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
        03-29-2025, 11:02 PM
      • mmartell
        General Questions on the Relationship Between Mainboard, TCON and Panel
        by mmartell
        My goal here is to be able to use boards on hand to swap into faulty sets when the faulty board is not obvious.
        I will start by asking what is the format of the output from the mainboard and is it generic in any way or does it vary by manufacturer and/or model ?
        And as far as I know a tcon and panel must be a matching pair because the timing of the signals and the voltages required to drive the panel are specific to the panel itself. (That may be a blanket statement that isn't true in some cases where the panel creates its own sub-voltages on its panel boards?)...
        01-06-2024, 01:32 PM
      • advant
        by advant
        02-03-2020, 12:25 AM
