Westinghouse wg55ur4100 no response
  • microvibe
    • Mar 2013
    • 275
    • canada
    I have a Westinghouse TV, when I plug it in the green light comes on no backlight no video showing on the screen with flashlight listed below are the voltages.
    There is no response when pressing buttons on tv or remote.
    Cn201
    V12= 12.3v
    V12= 12.3v
    Gnd
    Gnd
    Gnd
    V5= 5.1v
    V5= 5.1v
    Stb= 5.1v
    Ps-on= 3.1v
    V5= 5.1v
    V5= 5.1v
    Cn202
    V24= 24.6v
    V24= 24.6v
    Gnd
    Gnd
    Led2+ 0v
    Led1+ 0v
    Led2- 0v
    Led1- 0v
    Cn206
    Bk= 0.1v
    Adj= 0v
    Gnd
    Gnd
    • 12206
    • U.S.
    Re: Westinghouse wg55ur4100 no response
    With tv unplugged from power, unhook cable from powerboard to mainboard, plug tv into power, see if backlight comes on and stays on.
      Bk= 0.1v. Bad, there is no BL-ON from main board to turn on backlights circuit.
      Adj= 0v. Bad, there is no Dimming control control signal from main board.
      • microvibe
        • Mar 2013
        • 275
        • canada
        So find new main board. Or possible trouble shoot bl on circuit?
          Try heating with hair dryer and cooling (use canned airduster upside down) the main board to see what will happen.
          • microvibe
            • Mar 2013
            • 275
            • canada
            Tried heating and cooling no change.
            • CapLeaker
              Leaking Member
              • 8250
              Looks like the TV is actually running, just no backlights...
              BLon is generated on the main IC on the main board. :-(
              You could try to unhook the BLon at the PSU, and jump STBY or PSon to it via a 1k or so resistor. Just make sure you don't backfeed power. I'd either cut the BLon wire or take the wire with the pin out of the connector.
                • 12206
                • U.S.
                Test results from post #2??
                • microvibe
                  • Mar 2013
                  • 275
                  • canada
                  No backlights doing what says in post 2
                  • microvibe
                    • Mar 2013
                    • 275
                    • canada
                    Jumped bl on still no backlights. The led connector showing 3.5v on led1+ thats it. I cant find a 12v supply on tcon ethier
                      • 12206
                      • U.S.
                      Probably need to use a resistor on each pin ps-on and BK and maybe ADJ too, going to 5v standby, so 3 resistors, one going from each of those pins to 5v stndby. That might bring backlights on to verify backlights and powerboard.
                        • 12206
                        • U.S.
                        But most of the time when those voltages are low or missing it's just a faulty mainboard as mentioned.
                          Did you disconnect the BL-ON wire before jumping it? I hope you did otherwise you will damage the main board, which at this point it already has problems.
                            • 12206
                            • U.S.
                            Oh shit, forgot to say if you do this MAKE SURE the cable/s from powerboard to mainboard are unhooked.
                            • microvibe
                              • Mar 2013
                              • 275
                              • canada
                              Ill try jumping all 3 to stby. I did unhook main.
                              • microvibe
                                • Mar 2013
                                • 275
                                • canada
                                Jumping all 3 to stby worked for backlights. So guess need find main board unless possible to trace where issue on main is.
                                  • 12206
                                  • U.S.
                                  Nice job, yes sure looks like the main is the problem.
                                  • microvibe
                                    • Mar 2013
                                    • 275
                                    • canada
                                    Cant seem to find replacement main board, be nice if these main boards could be repaired.
                                    • microvibe
                                      • Mar 2013
                                      • 275
                                      • canada
                                      Would main board from50" work or one from 55" element?
                                      • CapLeaker
                                        Leaking Member
                                        • 8250
                                        Well, there are too many main boards. You have to look after an CV838H-B from a 55 inch tv. I could cut it down to 6 different main boards. Anyway, maybe take the main board out and see if there is a sticker on the back of it.
                                        • neilc6
                                          Factory Reset Westinghouse WG55UR4100 Android TV
                                          by neilc6
                                          I repaired the backlights on this model (symptom flash of backlights, repaired seven bad, part#3P55TA004-A2 new strips available at Shopjimmy) and now the TV is stuck on the home screen. I can only turn the TV on with the remote and no buttons work once booted on the home screen. Only the TV buttons volume -/+ and on/off work. There is no physical menu or input buttons.
                                          I think a factory reset will clear it but not a lot of options. Tried the Sony Android methods of holding down the on/off button while plugging it it and holding down vol- with power on/off....
                                          05-26-2021, 03:26 PM
                                          HP Elite 8300 computer completely locked no response from key board or mouse
                                          by sam_sam_sam
                                          Dose anyone know what would cause this issue because I do not understand what is going on
                                          The setup is the hard drive is set to never turn off
                                          The video set to not turn off
                                          Supposedly it setup is not to power down at all but something is not working correctly
                                          I have three of these computers and the other two work correctly with this setup
                                          The video is on the screen but the keyboard has no lights on and no response the mouse light is on but no response to movement
                                          The power button does not respond correctly either because if...
                                          06-19-2022, 07:49 AM
                                        • rumpumpel1
                                          Lenovo L480 NM-B461: strange power delivery response
                                          by rumpumpel1
                                          I have a L480 board with a working USB-C port and a non-working docking port that only runs on 5V. I have replaced the TB-Bios but to no avail. Both ports show 0,6V in diode mode. My Kingst Logic Analyzer showed the following strange response.
                                          The charger offers correctly 4 voltages:
                                          0.8781038000,Header,(8589951393),DataObject:4 Source V3 DFP Source_Capabilities
                                          0.8781686000,PayLoad[0],(168923436),V:5V Imax:3A
                                          0.8782978000,PayLoad[1],(1233196),V:9V Imax:3A
                                          0.8784272000,PayLoad[2],(1356076),V:15V Imax:3A
                                          0.8785566000,PayLoad[3],(1458501),V:20V Imax:3.25A​...
                                          07-23-2024, 06:17 AM
                                        • Nicktronic
                                          Westinghouse W55UW4620 No Video
                                          by Nicktronic
                                          Ok, so I know I know, it's a Westinghouse....lol It's got the backlights but no video. Likely the panel, but I'd like to take some measurements on the buffer board with help from you experts to confirm. See the attached pictures. In pic #1, there's a nice pin reference to use to take some measurements. The large IC in pic #7 gets up to 60degC when the TV is on.
                                          So, backlights, no video, go! 🙂...
                                          06-03-2024, 03:21 PM
                                        • Seville
                                          Westinghouse TV WD48FAB100 Not Powering On – Burn Mark Found on Power Supply
                                          by Seville
                                          Hello all!
                                          Westinghouse TV WD48FAB100 Not Powering On – Burn Mark Found on Power Supply .
                                          I have a Westinghouse LED TV, model WD48FAB100 that is not powering on. Upon removing the back cover, I noticed a burn mark where the AC cord connects to the power supply/main board. In this model, there is only one board combining the two functions. Previous owner said the TV experienced a lightening strike, but who knows. I checked the main fuse, tested OK. Here are a collection of readings from the power supply ports. Looking for some guidance on what to test/check next....
                                          10-10-2022, 07:31 AM
