Samsung UN75F6300AFXZA Left Half of the screen Dark
  • MilitaryBrat
    • Aug 2019
    • 14
    My back lights were out, So I ordered new strips and installed them. After the TV was put back together and turned on, the right side of the TV works perfect (side of the LED strips connectors). The left side, is darker, yellow is dark yellow, red is dark red, and so on. Sometimes the TV looks good.
    I used a backlight meter to check the LEDs after installing them in the TV. The Old led strips, has a voltage of 58volts. The new LED strips, (24 LEDs), has a voltage of 54volts. Also, when I removed the white papers, I lifted a corner and put take on them, and removed all of them as one. I also marked the corners, leftside top, rightside top.
    Could the problem still be the white papers, or even the 2 filter on the bottom of the TV.
    Any recommendation to look for when I take the TV back apart?
  • R_J
    • 9555
    Re: Samsung UN75F6300AFXZA Left Half of the screen Dark
    Any prolems with the diffuser sheets would effect the whole screen not just half, 4 volts over 24 led's will have little effect, check your cables between the t-con and panel board. hopefully you did'nt damage the screen during removal.
    • MilitaryBrat
      • Aug 2019
      • 14
      How do I disconnect the T-Com board from the filter connection? I tried pulling straight down, but not too hard. I can't get it to release. I want to check the left side to compare the right side. I had to disconnect the t-con board and keep it attached to the panel when I removed the panel.
      Also, I read somewhere to pull the foil tabs off the panel to fix this problem. If the right side is the problem pull the right foil off? Is this a good fix?
      My problem is not horizontal darkness, but a vertical darker side. I was very careful when I took the panel off. I used suction cups to lift it up high enough to place a large heavy cardboard under the panel. I then carried the card board to remove the panel to another area.
      • R_J
        • 9555
        Post some pictures, usually the t-con has 2 flat cables between the t-con and the lcd panel. they should have thin usually brown latches that lift up releasing the cable
        You need to be carefull with suction cups, too much suction can cause the panel to crack, inspect the area where you had the suction cups.
        • MilitaryBrat
          • Aug 2019
          • 14
          Sorry I did say filter connections, but I meant driver boards ribbons which connect to the T-con board.
          • MilitaryBrat
            • Aug 2019
            • 14
            I changed the t-com board and got the same problem. I switched the 2 t-com cables to see if the problem goes to the other side. it didn't. I saw someone removed the foil on the tv edge, pulled off on the bad side. Is this a good fix? Anyone know what this do to the tv? See the attachments showing the left side picture is darker than the right side picture
              • 12206
              • U.S.
              May be a tab bond issue, strip it down to the tab bonds and apply light pressure to tab bond see if that dark area goes away or changes, there's a demo video on youtube.
                • 12206
                • U.S.
                There's one video: https://www.youtube.com/watch?v=xHst6pKLtTE
                  This Samsung probably uses Sharp panel that probably has typical side tab issue, budwich knows a lot more about it.
                  • budwich
                    • Jul 2015
                    • 3097
                    what if anything is disconnected in terms of cabling during those pictures that you show? I would appear that the left side (looking at the tv) has some cabling disconnected somewhere.
                    You probably need to post pictures of the back of the set showing how things are connected along with a picture of the back at the bottom corner area where the bottom edge boards are connected to the side edge boards... hopefully that is how this set is designed / setup.
                      • 12206
                      • U.S.
                      On second thought, after taking a good look at pictures, it looks like you just have some bad leds in backlights, just for fun check your backlight setting in the menu, guessing it's at max.
                      • MilitaryBrat
                        • Aug 2019
                        • 14
                        I had purchased brand new backlight because some was out. I checked them all with a backlight checker, and checked them again when they all was connected. They all showed good. I checked the backlight setting in the menu and it was at 16 of 20. I lowered them to 11. I turned off the room lights to see if one side was brighter than the other, looking at the lights shining through the holes on the back. They looked about the same. I also thought some LEDS might be out, but sometimes the TV looks perfect until the scene change Heres different pictures, everything was connected excepted the on/off switch which is connected to the frame. I do connect this when I turn on the TV. I'll check out the YouTube link, and try to find
                        I never disconnected the edge boards for the T-com 2 cables to these boards, when I installed the new led backlights. I disconnect the single cable on top of the t-com board, removed the screws, and moved the edge boards and the t-com board as one piece.
                          • 12206
                          • U.S.
                          Are you sure you can see all those backlights on? Looks like you have a whole strip out, just a little above the center of the display.
                            • 12206
                            • U.S.
                            Did you try as I suggested in posts 7 and 8?
                            • brucetv
                              • May 2015
                              • 281
                              • united states
                              Try disconnecting the cable at the main coming from the power supply and plug in. Look to see if it's still darker in that area and also look at the holes in the back chassis and see if backlights look lit up evenly across the chassis.
                              • MilitaryBrat
                                • Aug 2019
                                • 14
                                Yes I did post 7 & 8. I watched the youtube video. I had someone watch the tv as i adjusted the edge boards, and all of the ribbon cable connected to them. Nothing flickered or made the color lighter or darker. When there is a picture of the sky, the tv looks almost normal. But when something is dark in the picture, the left side becomes dark. So because of this I believe all the backlight is working. Tomorrow I'll take the frame and screen off again. I 'll make sure all back light are the same brightness and play with the tabs on the side to see if the picture lighten up.
                                • MilitaryBrat
                                  • Aug 2019
                                  • 14
                                  The back right side is the Front left side, which is the problem. Picture showing the backlight is good on both side. The back panel is connected and laying on the right side
                                  • brucetv
                                    • May 2015
                                    • 281
                                    • united states
                                    Back lights look good. I'm leaning also towards a side tab issue. We are already seeing MU series 8000 side tab issues in the 75".
                                      • 12206
                                      • U.S.
                                      The "tape cut off" method may work, won't hurt to try: https://www.youtube.com/watch?v=j7vl7-vZEL8
                                      • budwich
                                        • Jul 2015
                                        • 3097
                                        From the last posted pictures of the configuration of the back of the set, it doesn't appear to show / indicate that there are side tabs... at least ones that I can see. I think there are on sets this large but usually they are only visible from the front. Anyway, you can try a further test that should prove whether it has something to do with connections going to the sides. In the last two pictures of the back of the set, they show "U" ribbon cables which interconnect the bottom side board "pairs". These are unclampable without ultimately causing any problems in terms of returning them back to "normal". The test here then is to disconnect the one associated with the OPPOSITE side to the "dark side". This will cause the signal to only attempt to make it thru the "bad" / dark side. IF that side has a bad signal path to the panel somewhere, then it is likely you will see NO picture. Go from there.
                                        • Chrissygizmo
                                          by Chrissygizmo
                                          02-10-2025, 12:33 AM
                                        • armoured_smiler
                                          Panasonic Tx-40cx400b top left half screen not displaying correct
                                          by armoured_smiler
                                          Trying to work out if this is TFT problem or TCon issue.
                                          The TV powers up but the top half of the screen, from the right it is OK, but as you look across to the left halfway across it starts get duller and duller until it is very dark on the lefthand side, currently I trying to clean the remote as it seems to have something film wise on the pads stopping it from registering buttons pressed.
                                          Also when changing the screen size of Windows PC display to say to a smaller pixel sizewindow, the original window displayin the top left stays/takes a few seconds to disappear?...
                                          04-08-2024, 03:40 PM
                                        • Zelek11
                                          Panasonic Plasma screen interference on left half of screen
                                          by Zelek11
                                          My Panasonic Plasma model P55VT50 has started displaying "interference" on just the left half of the screen only (left when facing the screen). Sometimes it's concentrated in about the first 30 seconds after startup, then disappears. Other times it's fine at startup and then randomly does it later on. When it flashes the interference it's very quick and doesn't stay on the screen unless it flashes repeatedly in a row.
                                          This image is a screen shot from a video I took. This is an example of the interference at its worst. Often the interference is much smaller...
                                          10-14-2022, 04:54 PM
                                        • Chrissygizmo
                                          samsung galaxy ao2s very temperamental after screen replaced
                                          by Chrissygizmo
                                          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                          Ive eventually managed to get it on and working but it's very temperamental...
                                          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                          05-26-2024, 12:05 AM
                                        • JunkmanJimbo
                                          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                                          by JunkmanJimbo
                                          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                                          No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                                          Please help. Thanks in advance!
                                          08-12-2025, 11:45 AM
