55lm670t backligth and sound no picture
  • wreksta
    • Aug 2013
    • 508
    • england
    hi been a while got this set in wondered if anyone can help
    the tv displays no picture other than left side blank right side with a bar that fades
    tries disconnection both ribbon cables to panel and tv displays blank full screen
    right side connected only displays lines that fade
    left side connected only displays half white and lines that fade on right side
    whats the intial diagnosis ?? hoping main board not panel
    main board is eax64307906
    this set has no tcon board
    Re: 55lm670t backligth and sound no picture
    Can we see the pictures of what we are dealing with?
    The T-CON may be integrated into the panel.
    • wreksta
      • Aug 2013
      • 508
      • england
      post updated
      • nomoresonys
        • 12206
        • U.S.
        Can you post a picture of the lines that are fading?
        • Diah
          • Feb 2013
          • 6376
          years before i got one under my hand 49LM640S do same fault and same look at LVDS remove test. first things i went to take the bezel cover and inspect the panel Tap. and it was effected by wet from cleaning the screen.. scraped
          • wreksta
            • Aug 2013
            • 508
            • england
            no water damage anywhere checked main tab bonds and driver boards
            unless this has side driver tabs ??
            picture below off 3 different phases
            both connected
            one connected
            other connected
            • Diah
              • Feb 2013
              • 6376
              the fade lines are few colors .. are u sure the panel TAP look good and there no shorted ceramic cap
              in case yes then only BGA issue on MB
              • wreksta
                • Aug 2013
                • 508
                • england
                there is a couple of very small caps on driver board both sides when tested for continuity they are on there own every 3rd of the driver board
                there make meter beep rapidly
                • Diah
                  • Feb 2013
                  • 6376
                  please always do it with photo ... if one shorted it could cause other read as short. need to check the connection of them and this with clear photo do the job for you and here too
                    Use Ohm mode, not continuity mode to check resistance of the caps for low Ohm reading.
                    Can we see the pictures of the Tb bonding boards?
                    • nomoresonys
                      • 12206
                      • U.S.
                      Could be those tabs, try the light pressure as in this video, see if lines change: https://www.youtube.com/watch?v=LysMj2Tcp4M
                      • wreksta
                        • Aug 2013
                        • 508
                        • england
                        these components make meter go postal
                        • wreksta
                          • Aug 2013
                          • 508
                          • england
                          no change mate
                          • wreksta
                            • Aug 2013
                            • 508
                            • england
                            tb bonds?
                              I cannot tell from the picture as to what you are pointing to.
                              That is tab bonding board, I can see some caps on the boards.
                              • wreksta
                                • Aug 2013
                                • 508
                                • england
                                there 1 micro cap there mate only component there
                                • wreksta
                                  • Aug 2013
                                  • 508
                                  • england
                                  dont matter magnified board they are resistors
                                    There should be lots of tan/light brown color caps on that Tab bonding board
                                    • wreksta
                                      • Aug 2013
                                      • 508
                                      • england
                                      caps test fine on driver board
                                      • budwich
                                        • Jul 2015
                                        • 3097
                                        both connected
                                        one connected
                                        other connected
                                        the second picture showing the white on the unconnected side with the vertical bars on the other.... the white is "normal" response for a disconnected side in most cases. The vertical bars on the connected side is bad.
                                        the third picture showing the "grey screen" which fades from left to right (ie getting darker), shows the now disconnected "bad" side which allows the tcon to somewhat function (ie. "uniformity")... was anything being input for this picture? You might get lucky if there are some form of side tabs along each side of the panel. Check them to see if they are discolored or any of them are hotter than others. Go from there.
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • kca
                                          Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
                                          by kca
                                          Hello all ~
                                          I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
                                          This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
                                          No picture. No sound.
                                          I tested all the voltages coming out of the power supply...
                                          10-12-2023, 05:23 PM
                                        • marekk
                                          Samsung QE55Q67RAT no sound and bad picture when streaming
                                          by marekk
                                          I got Samsung 55 inch QLED QE55Q67RAT where there is no sound at all and when using youtube for example picture is not clear and noisy.
                                          I have swapped Burr-brown 88002A chip on the mainboard but didn't help, different set of speakers didn't help either
                                          Mainboard is based on pcb BN41-02695A BN94-14007B
                                          I will appreciate any help
                                          Many thanks
                                          Marek...
                                          05-29-2025, 02:23 AM
