Sony KDL-40W2000 3 LED Blnks Error
  • StephenU
    • Dec 2013
    • 230
    Hi all looking for some help on repairing this old TV for a friend in work. Its a Sony KDL-40W2000 (Old LCD TV).
    Any Help Guidance would be much appreciated.
    TV has the LED error code 3 -
    UNREG10.5V, PANEL5V Voltage Trouble (DCALERT1).
    When power is applied and the power switch on tv is pressed you can hear the relay switching the LED goes from RED to Green for a brief couple of seconds then it goes into the flashing Red LED state. (3 blinks pause 3 blinks pause and so on.) On doing some reading up I've found:
    "" Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault.
    This is also a problem in the power supply circuit, check T603 and R672. (I cannot find these parts on the schematics at all most parts have the letter of the component and then 4 numbers.) ""
    I have attached a pic of connector CN6200 as I took some measurements from it but no voltages were present with the connector seated or unseated.
    Some pics are attached and I hope to get back to this tonight to get more pics and measurements
    I also found this thread: https://www.badcaps.net/forum/showth...hlight=40w2000
    Thanks in advance.
    S.
  • nomoresonys
    • 12330
    • U.S.
    Re: Sony KDL-40W2000 3 LED Blnks Error
    Not even standby voltage, powerboard issue, you need at least the standby voltage to get started, check the fuse on powerboard if you didn't already.
    • nomoresonys
      • 12330
      • U.S.
      Try with tv unplugged from power, unplug everything from powerboard, plug power cord into outlet, so only thing you are powering up is the powerboard, see if you have the standby voltage.
      • nomoresonys
        • 12330
        • U.S.
        https://www.ebay.co.uk/itm/PSU-1-871...EAAOSwze9c0uRn
        • nomoresonys
          • 12330
          • U.S.
          Are you sure you have the right schematics?
          • StephenU
            • Dec 2013
            • 230
            Watching this at the minute but would rather try do some debug on it to narrow it down to components rather than just swap out complete board if I can.
            Thanks for the reply nomoresonys
            • StephenU
              • Dec 2013
              • 230
              Yes i'm pretty sure they are the correct schematics, they came from here >>
              • StephenU
                • Dec 2013
                • 230
                Gettting ~240v on both sides of the fuse - What i don't get is I get nothing on the standby 3v3 pin and i have a Red standby LED then goes to green when powered then, when failure occurs and 3 blinks code appears. I monitored pin 5 STBY+3.3V (CN6200) when on standby, green light and when 3 blink error is repeating, still nothing. DMM set too Auto range on VDC = 0.00v
                Will redo everything tonight again - if I can eliminate one board from another I will let him know what the price is with a board swap, just trying to keep the price down and get the TV back to him
                • nomoresonys
                  • 12330
                  • U.S.
                  I see, something is amiss, can you try your meter on something else, to verify it's working correctly?
                  • StephenU
                    • Dec 2013
                    • 230
                    Its seeing the 240v input at both sides of the fuse when metered and on AC then switch to DC to take readings from connector but no voltage coming from pins.
                    • nomoresonys
                      • 12330
                      • U.S.
                      Ok, guess the first thing you need to do is get the standby circuit working. As a test try heating the powerboard with a hairdryer be sure to heat the capacitors on there too, see if tv comes on or anything changes.
                      • Diah
                        • Feb 2013
                        • 6563
                        did you inspect the back side of the PSU of crack soldering point?
                        could you listed the voltage you have on all legs of IC6100. be sure the black probe on HOT area chassis
                        • R_J
                          • Jun 2012
                          • 9624
                          If you are getting the led on the front of the tv and you here the relay click when you press the power button, you MUST have STBY3.3V. Check for the STBY on L6300 It will be there.
                          If you had an older SONY CRT you WOULD find these parts. This has NOTHING to do with this LCD tv. got to love the internet
                            +1, no way you can have blinking LED if the STBY 3.3V is not present.
                            • R_J
                              • Jun 2012
                              • 9624
                              There may be a problem with the panel, check if you have +5v on the t-con, Also disconnect the lvds cable between the t-con and the main and see if you get the same error.
                                Service manual:
                                https://www.manualslib.com/download/...l-40w2000.html
                                Error code 3-blink:
                                3 ) UNREG10.5V, PANEL5V Voltage Trouble (DCALERT
                                So perform test as RJ suggested.
                                • Diah
                                  • Feb 2013
                                  • 6563
                                  wrong
                                  3 error blink very wide at Sony platform not all listed on service manual are the case.. when 3.3V went grounded via IC6100 there other line continue feed the set to register error. this is from experience not SM.
                                    Which board and at what page of the service manual IC6100 located?
                                    • Diah
                                      • Feb 2013
                                      • 6563
                                      look on the photo OP posted PSU 18 legs IC
                                        SM manual page 60.
                                        So how does 3,3V STBY is grounded via IC6100? So you are saying the SMPS IC6100 (for the +18v, +15v, +10.5V, and +33V) is bad?
                                        I do not see STBY 3.3V feed the IC6100 which is in the HOT side.
                                        • jason123
                                          Sony XR-55A80J OLED TV 5 blinks - Troubleshooting steps
                                          by jason123
                                          Hi there,
                                          I see a couple of posts related to the troubleshooting of similar TV. The one I have is acting slightly differently and I'd love your help.
                                          So it has the 5 blinks. Previous owner got a TCON, no luck. Got a new Main board (though he didn't do the USB firmware update), again, no improvements.
                                          I see 2 posts that are relevant:
                                          https://www.badcaps.net/forum/troubl...j-oled-5-blink
                                          https://www.badcaps.net/forum/troubl...g-hardware-dev...
                                          10-29-2025, 02:01 PM
                                        • matwan
                                          Sony XR-55X90J 5 blinks
                                          by matwan
                                          I have problem with SONY 55X90J. After several check status is as below;
                                          1. Running power board as stand alone:
                                          TCON_12V =~ 12.6V
                                          EVDD V On Max 24V= 19V.
                                          2.
                                          Running power board with TCON as stand alone:
                                          Effect as below, attched.
                                          3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
                                          "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
                                          Best regards....
                                          09-28-2025, 04:26 AM
                                        • GoodCapDude
                                          Sony XBR-75X940E intermittent 6 blinks error code
                                          by GoodCapDude
                                          Hi everyone. First post on Badcaps!
                                          I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                                          09-20-2025, 06:07 AM
                                        • AK_777
                                          Sony KD-65A1 Repair – 4 Red Blinks Error
                                          by AK_777
                                          Hi everyone!
                                          I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                                          Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                                          02-20-2025, 04:15 PM
                                        • jchon
                                          Sony A1e 5-blinks help
                                          by jchon
                                          Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
                                          I found the service manual, which was critical to know where to probe.
                                          https://www.manualslib.com/manual/20...1e-Series.html
                                          With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
                                          Unfortunately the 5-blinks...
                                          06-28-2023, 11:52 AM
