Sony KDL-40W2000 3 LED Blnks Error
  • nomoresonys
    • 12206
    • U.S.
    #61
    Re: Sony KDL-40W2000 3 LED Blnks Error
    F and G may be some kind of Country code, not sure, F may be the correct one for your Country.
    • StephenU
      • Dec 2013
      • 230
      #62
      Re: Sony KDL-40W2000 3 LED Blinks Error
      Usually need to match up the top letter/numbers on the white sticker of your mainboard, what is your panel number?
      Look for A-1196-582-G, on sticker of your board and the replacement board.
      This MIGHT work I see the very last letter is different F vs G, don't know how knowledgeable the seller is but you could contact m and ask if they know weather it will work or not, panel number matches: https://www.ebay.co.uk/itm/MAIN-BOAR...4AAOSwUv9c0UnY
      Thanks for this I will update Post in due course.
      S.
      • nomoresonys
        • 12206
        • U.S.
        #63
        Ok, I see 2 type boards on there, make sure you match the panel # LTY400HS-LH3 and you should be alright.
          So what happen if you run the power supply board by itself and do the force on using 300 ~ 470 Ohms resistors between 3.3V and the POWER ON, and RLY_ON?
          Do you get all the Voltage outputs as shown in the diagram?
          • StephenU
            • Dec 2013
            • 230
            #65
            Hi Budm, I have ordered a replacement Mainboard. Although I can try out these measurements over the weekend, can I take the measurements direct from the CN6200 pins 1, 2, 7, 8, 11, 13, 14 or locate the points you have highlighted on the Schematics? I've attached a pic to illustrate my connections between CN6202 pin 2 and CN6200 pin 5.
            Thanks for your help Budm
            S.
              You need another resistor for the RLY_ON (Relay On), pin 5 (CN6200) to pin 4 (CN6202) with another 470 Ohm resistor.
              Yes, you will be taking the Voltage measurement of the power supply connector since there will be no connection to the main board, we are doing the test to find out if the power supply board is OK or not.
              • StephenU
                • Dec 2013
                • 230
                #67
                Hi all just like to thank everyone for their input and help getting this tv back up and running, replaced the Mainboard and all works fine now. I matched my replacement board up with my panel # LTY400HS-LH3.
                • nomoresonys
                  • 12206
                  • U.S.
                  #68
                  Another save, well done.
                    Thanks for the follow-up, too bad the thread got this long due to wasted time on the power supply board, especially the IC6100.
                    • Mikes043
                      • Jun 2021
                      • Netherlands
                      #70
                      Hello , In the first place I have to thank all the people for sharing their knowledge on the subject.
                      I have the same problem as the OP.
                      I did the the voltage check by doing the Resistors trick
                      I used 470 ohm resistors from standby 3.3 to POWER_ON and RLY_ON
                      I put the 2 resistors on the single standby connector
                      than I measured n CN6202 18v to ground and that works.
                      Can someone tell me how to proceed ?
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        #71
                        So you have all the supply voltages. 3.3V, 10.5V, 15V and 18V
                        • Mikes043
                          • Jun 2021
                          • Netherlands
                          #72
                          I am going to check that !
                          in thought just measure 18v and if it was the specified voltage @ 1 terminal In de connector.
                          the rest would be good also
                          • AK_777
                            Sony KD-65A1 Repair – 4 Red Blinks Error
                            by AK_777
                            Hi everyone!
                            I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                            Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                            02-20-2025, 04:15 PM
                          • jchon
                            Sony A1e 5-blinks help
                            by jchon
                            Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
                            I found the service manual, which was critical to know where to probe.
                            https://www.manualslib.com/manual/20...1e-Series.html
                            With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
                            Unfortunately the 5-blinks...
                            06-28-2023, 11:52 AM
                          • Nicktronic
                            Sony XBR-65X850D 2 Red Blinks
                            by Nicktronic
                            I have the subject TV and it will work normally sometimes but suddenly go black and give the 2 red blinks blink code. When this happens, I check the power supply board voltages and all I have is the Standby 3.3V and BL_ERR 2.2V. When it's working normally, all power supply board voltages look normal and stable. I've checked the backlights with a tester and they all test good. I've also read that the 2 red blinks is a faulty power supply board, so could it be throwing up an erroneous BL_ERR?
                            Any Sony experts out there that can help??...
                            11-19-2023, 06:51 AM
                          • dumbdd
                            Sony 75X9400E TV.. 5 Red blinks
                            by dumbdd
                            I was using this TV for 5 years before it stopped working. I like this TV and would love to fix it myself.*
                            When I press the power button, the white led comes on (sony calls the module smart core) and then it switches over to 5 red blinks. No screen, no backlight, no relay click, nothing. I have disassembled the tv and found the service manual for 75x940e online. The manual suggests a faulty power board, TCON or the panel.**
                            The standby pin is at 3.3V. Fuses on the mainboard and TCON are fine. Caps on TCON also seem to be fine. When I turn on the tv the white led...
                            07-01-2023, 08:54 PM
                          • Nicktronic
                            Sony XR-55X90J 4 blinks
                            by Nicktronic
                            Hey guys, got this Sony that turns on momentarily and then goes black with 4 blinks of the standby light. I can't find a service manual, but best guess was the Local Dimming board based on a similar TV saying LD_ERR or BCM_ERR. I found a replacement, but it didn't work. Before I put more money into replacement boards, Im wondering if anybody has seen this issue and what worked for them, or has the service manual for this specific TV.
                            Thanks!...
                            02-13-2024, 07:01 PM
