Sony KDL-52V4100
  • dprit
    • Jul 2015
    • 49
    Sony KDL-52V4100
    Does anyone have a schematic for the signal board that is attached to the panel? This is the board that is connected to the panel and goes to the T-Conn board via a flat ribbon cable. I have something shorted on the Left board as it blows the fuse on the T-Conn when I hook up the ribbon to the left signal board. The right side of the panel has a perfect picture with its ribbon cable hooked up.I need a schematic.
    Re: Sony KDL-52V4100
    Most failures on that tab bonding board are due to shorted cap, so start checking the resistance of the caps.
    • toty79
      • Mar 2019
      • 42
      • Italia
      T-con FS_HBC2LV2.4 ?
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • delpiero3
        Sony Vaio SVS MBX-261 board failure
        by delpiero3
        Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
        Nevertheless, let's say, i don't come as a total beginner.
        I have this old laptop, which suit perfectly my needs, with the...
        10-29-2024, 06:16 AM
      • huj3r
        Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
        by huj3r
        Hi there!
        I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
        Photo of the situation after the black shadow dissipates:
        After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
        I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
        > This indicates HFR Communication error. [ HFR Communication...
        08-15-2023, 10:55 AM
