Samsung LN46D630 no picture
  • Bloup101
    • Mar 2019
    • 15
    Hello I'm by no means savvy but I can spot boldged caps and do basic soldering. I've fixed e few TVs but this one has me stomped. Visually everything look good. The TV has the same symptoms as the following post.
    https://www.badcaps.net/forum/showthread.php?t=53599
    Audio but no picture, if I disconnect the inverter board the LCDs come on for half a second.
    BLU_ON 5.05v
    PS_ON 4.87v
    CP802 158v should be 380-390v? 515 ohm
    CP803 158v should be 380-390v? 515 ohm
    DP810 445 ohm
    Inverters 841 ohm
    CP801 481 ohm
    CP802 481 ohm
    CI1818 0 ohm is this expected?
    CX802S 0 ohm
    CX802S 0 ohm
    Both fuse are good
    CM811 450 ohm
    CM809 199 ohm shouldn't it be the same as CM811 they are the same part?
    • 12206
    • U.S.
    Re: Samsung LN46D630 no picture
    Test connector from mainboard to powerboard on powerboard side with all boards hooked up, test with tv plugged in but off then hit power, report both conditions here, give pin number, pin description/name and condition on and off, that is where you start in most cases, it gives the helpers a lot of info. to work with. When you get the audio no picture, can you see any text or anything on screen with a flashlight by pressing menu or anything?
      Skip.
        BLU_ON 5.05v
        PS_ON 4.87v
        DP810 445 ohm
        Inverters 841 ohm
        CP801 481 ohm
        CP802 481 ohm
        CX802S 0 ohm
        CX802S 0 ohm
        Both fuse are good
        CM811 450 ohm
        Right now you do not have the PFC Boosted Voltage even though the PS-ON is present. Please upload good clear straight shot pictures of the power supply board top and bottom side of YOUR board, also pictures of the whole backside of the TV showing all the boards.
        Your power supply board is BN44-??????
          • 12206
          • U.S.
          • Bloup101
            • Mar 2019
            • 15
            Bn44-00463a i46f2_bhs
              • 12206
              • U.S.
              Look closely check for bad/cold solder joints.
              • Bloup101
                • Mar 2019
                • 15
                Looks like I can only have one attachment per post
                • Bloup101
                  • Mar 2019
                  • 15
                  Is it normal I get 2 different readings for 2 identical caps? I'm measuring on the back of the board. I set my DVM to ohm 2k and get these readings.
                  CM811 543ohm
                  CM809 880ohm
                  Both caps are 105c 25v 1000uf
                    • 12206
                    • U.S.
                    So what happens if you unplug cable from powerboard to mainboard, (tv power cord unplugged of course) then plug tv power cord in, see if backlights come on.
                      • 12206
                      • U.S.
                      CM811 543ohm
                      CM809 880ohm
                      Hard to get an accurate reading in circuit.
                      • Bloup101
                        • Mar 2019
                        • 15
                        DMV set to 200k reading is 47.5 on DP810
                          • 12206
                          • U.S.
                          What do you get on DP810 with meter on diode mode?
                          • Bloup101
                            • Mar 2019
                            • 15
                            Main board disconnected from power board: I get no sound and LED strips light up for half a second. I did the flashlight test and I see no text or image. The low and high voltage pins going to the inventer board 0v.
                              Your post #1 shows: DP810 445 ohm
                              Now it shows as: set to 200k reading is 47.5, that will be 47.5K Ohms which is much higher than 445 Ohms as reported in post #1. Are you 100% sure you reading the meter correctly?
                              • Bloup101
                                • Mar 2019
                                • 15
                                DMM in diode mode reads 442 on DP810
                                • Bloup101
                                  • Mar 2019
                                  • 15
                                  All my readings in post 1# were in diode mode. Sorry I'm learning...
                                  • Bloup101
                                    • Mar 2019
                                    • 15
                                    All boards plugged in I get 4.86v on ps_on and 5.05v on blu_on
                                      The control signals are fine but you do not have PFC boosted Voltage so you need to check and work in the PFC section first to get that 380 ~ 400VDC on the main cap first.
                                      So you need to get the P/N of the PFC IC ICP801 to look up the spec sheet to find out which pin is the VCC pin so you can verify if the VCC is present or not for the PFC IC to run.
                                      Samsung BN44-00463A (I46F2_BHS) Power Supply Unit
                                      https://www.shopjimmy.com/samsung-bn...upply-unit.htm
                                      Repair kit:
                                      https://www.shopjimmy.com/samsung-bn...repair-kit.htm
                                      • R_J
                                        • 9557
                                        Can you explain? when you say the LCD comes on for half second, do you mean the backlights come on for half second?
                                        if that is true, disconnecting the inverter will NOT give you any backlights at all. Or did you dissconect the MAIN board from the power supply, and that gave you half second of backlight
                                          09-07-2024, 05:50 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Dodgethis
                                          Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                          by Dodgethis
                                          Hello all,
                                          This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                          09-11-2024, 07:39 AM
