Panasonic tc-65cx420u No Power
  • Jsikora
    • Apr 2016
    • 64
    I have this tc-65cx420u that I had to replace a couple of LED's on 1 row because the unit had the dark shadow down the center of the screen. Once those were replaced the unit worked just as before except the shadow was gone. Tried it several times to make sure everyting was going to work correctly beforere installing the panel as I did not want to take it back apart again. Replaced the panel and everything was working great. Picture was great and dark shadow was now gone. Checked several times and all was good. After reassembling the back cover on the screen I am now getting nothing what so ever. I do hear the PS noise that I had before, but have no standby light and hitting the power buttons on the TV or remote I am getting nothing. Any help with this would be greatly appreciated. Thanks.
    Also I can post pictures and give voltage measurements once I get them wrote down.
    • 12210
    • U.S.
    Re: Panasonic tc-65cx420u No Power
    Hopefully the panel wasn't damaged on reassembly, start here I guess to see where you stand: Test connector from mainboard to powerboard on powerboard side with all boards hooked up, test with tv plugged in but off then hit power, report both conditions here, give pin number, pin description/name and condition on and off.
    • Jsikora
      • Apr 2016
      • 64
      OK here are pictures. I don't think there is an issue with the panel as I had the whole front frame back on after installing the panel and everything worked fine and I had picture on the screen and was able to get into the menu and even had it hooked up to watch TV.
      So far I have checked con201 on the PS
      starating from the top at 12V going down I have
      12V = 12.81
      12V = 12.80
      DGND = -.005
      DGND = -.004
      DGND = -.004
      5V = 5.16
      5V = 5.16
      5VSB = 5.17
      PS/ON = 4.041
      5V = 5.17
      5V = 5.17
      DGND = -.004
      DGND = -.004
      When the TV is plugged in I hear the PS and nothing changes when hitting the power button on the TV except the voltage on the main board that connects to the actual swith drops from 3.278 to .073 which in my experience should be right.
      Thanks for your reply.
        12V = 12.81
        12V = 12.80
        DGND = -.005
        DGND = -.004
        DGND = -.004
        5V = 5.16
        5V = 5.16
        5VSB = 5.17
        PS/ON = 4.041
        5V = 5.17
        5V = 5.17
        DGND = -.004
        DGND = -.004
        Those Voltage readings are fine, the PS-ON control signal from main board is present so the Switched 5V and switched 12V are.
        We need to see the whole backside of the TV to see all the boards and how they are connected together.
        • Jsikora
          • Apr 2016
          • 64
          Back Pictures
          The other thing I can't figure out is no back lights or power indicator light which I had both of before the back was put on, even if the T-con is disconnected from the Panel.
          Back lights all three sets test good at 121V with BL tester.
            So there are two more connectors from the power supply/LED driver board to the main board but the pins are not labeled (I do not see them), one of those two connectors should have BL-ON and Dimming control signals for the backlights.
            The main board is not dead since the PS-ON is present, but does the PS-ON change state when you toggle the TV ON and OFF.
            I assume that you already try re-seating all the cables, flexing the boards, tightened all the boards mounting screws?
            • Grear
              • Jan 2021
              • 5
              Hello, I also have this same TV with the dark banding in the middle of the screen. Can you please tell me where you purchased the led strips and part number? I have replaced the driver board and this did not resolve the issue.
              Thanks for any help, Grear.
                • 12210
                • U.S.
                Can you show a picture of the display fault?
                • Grear
                  • Jan 2021
                  • 5
                  Currently I don't have it connected to any satellite signal. The fault is a dark vertical shadow in the middle of the display that covers approx 1/3 of the screen.
                  An image of whatever is on can be seen through it.
                  • Grear
                    • Jan 2021
                    • 5
                    Ok I found one, sorry for the content
                      • 12210
                      • U.S.
                      Ok, that looks more like a tab bond fault than a backlight issue, hard to tell tho, without testing backlights, that's where the backlight testers come in handy. Half that content is good for America, not saying which, because I don't have enough time left to waste arguing the point.
                      • Grear
                        • Jan 2021
                        • 5
                        Thanks for the reply, what would be the fix for a tab bond fault?
                          • 12210
                          • U.S.
                          Example there, it's not a certified fix but I've had pretty good luck with it, some tvs are harder to get to the tab bonds, did one recently, used a piece of rubbber-like thermal pad for the shim, only did the top right and only did one side but his method is probably better: https://www.youtube.com/watch?v=purk_SyiT44
                          • Grear
                            • Jan 2021
                            • 5
                            Thanks for the information, I'll definitely look into this.
                              • 12210
                              • U.S.
                              Sometimes the symptoms can be deceiving, some present like he has, mine was just a dark area in the middle of the screen, no flickering.
                              • Jsikora
                                • Apr 2016
                                • 64
                                OK, so I am going to give this a try once again. The last time I was doing anything with this, before the thread got hi-jacked, I lost patience. So anyway on those two 4-pin cables I am gettin voltages of
                                CN202
                                pin1 24.88
                                pin2 24.88
                                pin3 0.00
                                pin4 0.00
                                cn203
                                pin1 0.001
                                pin2 0.001
                                pin3 0.130
                                pin4 0.039
                                Not sure if that helps any or not but I'm willing to try and get this thing going again.
                                • Jsikora
                                  • Apr 2016
                                  • 64
                                    • 12210
                                    • U.S.
                                    More like he posted on an abandoned thread rather than a hijack, a year and a half since last post.
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4333
                                      • Italy - Milan
                                      The only sensed thing one tech can do here is took hook a pc through serial port and check the log, Cultraview, the manufacturer of main board, use the serial over vga port, need an RT809 or another adapter..
                                      • Jsikora
                                        • Apr 2016
                                        • 64
                                        Yeah I didn't realize it had been so long. Had a lot going on during that time. (Meds got changed several times and lost all realization of time frames.) I would like to get this working though, but right now I'm waiting on the IR/Power cable to get here from compass. Seems the end was ripped off since I was last working on this. I may just solder the wires to the board and see what I get. Didn't mean to sound like a jerk , just wasn't aware it had been so long.
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                        • oldschoolgamer
                                          Panasonic TX-50EX700B Won't Power On
                                          by oldschoolgamer
                                          Hi. I have a Panasonic TX-50EX700B which hadn't been used very often for some time. Recently it started getting used a little more often, until one day it just refused to power on with the red LED blinking 13 times. Upon researching, it turned out it apparently had something to do with the 5v power line, so I assumed it was probably the power supply.
                                          I purchased a power supply for the TV from a seller that claims that it works fine and was just taken from a TV with a broken screen. After fitting the new power supply and trying the TV, I was greeted with the power LED being red for...
                                          10-26-2022, 04:15 PM
