Sony XBR-65X900C Sporadic Issues
  • Michale32086
    • Nov 2011
    • 1453
    Re: Sony XBR-65X900C Sporadic Issues
    Well, I'll be deepped in sheet!!!
    The firmware update on the 55" worked!!!!
    And it is ALSO an ANDROID TV!!!
    It took me about 15 mins of turning the TV on and off before the thumbdrive indicated it was working.. IE The firmware was updating..
    It ran for over 30 mins and i almost shut it off.. But then it powered down all by itself and then the Android Animation started and then it booted up just fine!!! Woot!!!!
    Since the 55" is an ANDROID TV, I am debating whether or not I should try it on the 65" or just leave well enough alone.. It would sure help my decision on buying a new board if I was sure that a new board would fix the 65"....
    But, given my luck, I am thinking I should just be happy with the 55" and see if get another Android SOny in from elsewhere..
    • Michale32086
      • Nov 2011
      • 1453
      The small "cellophane" connector in blue in the afore pic looks something like this...
      • Diah
        • Feb 2013
        • 6555
        now you have the 55 working.. so what about the original main board of this 55.. it will be now good enough to you to trouble shooting it on the 55 and when it work then put it on the 65 or back to 49
        • Michale32086
          • Nov 2011
          • 1453
          The 49" has a cracked screen.. So it's not viable anyways..
          The original board from the 55" suffered the same fate as the 65".. Excessive reflows...
          I just don't want to risk the working 55" board if there is even a chance that putting it in the 65" would fry it...
          On the other hand, it would be nice to confirm that a new main board is all that is needed for the 65"....
          I guess I am asking what the risk is of the 65" frying the 55" board.. Especially in light of that "cellophane" connector marked in blue that is on the 65" but not on the 55"...
          • Diah
            • Feb 2013
            • 6555
            the blue marked socket on the 65 don't have any cable connect on it at the set of 65. then its out of any risk. just focus on the LCD Panel type, are they both 55 49 and 65 same manufacture, if yes this is good
            • Michale32086
              • Nov 2011
              • 1453
              Awwww righty then...
              Here goes nothing..
              Another point is that the firmware for the 55" is identical to the firmware on the 65"
              • Diah
                • Feb 2013
                • 6555
                Here goes nothing..
                via the Model No of the 49 and 55 and 65 go to Sony firmware page and see if the 3 of them listed at same compatible model same at last firmware update
                • Diah
                  • Feb 2013
                  • 6555
                  your 65 Model with this models Applicable ,,, if your 55 and 49 listed then 100% okay same hard ware
                  XBR-75X940C
                  XBR-65X930C
                  XBR-75X910C
                  XBR-65X900C
                  XBR-55X900C
                  XBR-75X850C
                  XBR-65X850C
                  XBR-55X850C
                  XBR-49X830C
                  XBR-43X830C
                  XBR-65X810C
                  XBR-55X810C
                  XBR-65X800C
                  XBR-49X800C
                  XBR-75X940D
                  XBR-65X930D
                  XBR-55X930D
                  XBR-85X850D
                  XBR-75X850D
                  XBR-65X850D
                  XBR-55X850D
                  • Michale32086
                    • Nov 2011
                    • 1453
                    OK Update on this..
                    Yes, the firmware does seem to be identical between the 55 and the 65..
                    When I put the board on the 65, however, I still had to do a firmware update again.. Maybe the firmware has to be installed while in the TV it's going to be working in..
                    The GOOD news is that the 55" board DID work in the 65" after the firmware update...
                    Sorta....
                    Took about 40 mins to do the update, but after that, the TV booted up and I could see the boot up process work fine on the 65".. However, I had to see it by shining a bright light into the screen.. The backlights were not working..
                    Which makes a certain amount of sense because that cellophane connector marked in blue appears to have something to do with the backlights, as you can see by the attached picture...
                    Now, the GOOD new is, the stock 55" board still has the proper connections for the backlights AND the audio connections, marked in yellow on the other attached pic...
                    So, if I can get a good working 55" board, which is a lot cheaper than the 65" board, I can transfer the connections and, with a little bit of luck, I'll have a fully working 65" board..
                    At least, the theory is sound..
                    As things stand now, I put the 55" board back in the 55" TV.. As expected, I have to redo the firmware but, if all goes as planned, I should have a working 55" 4K Sony Android TV
                    • Diah
                      • Feb 2013
                      • 6555
                      ohhh. i see so the socket on 65 it had cable connected to LED back light driver board..
                      as you said. keep 55 working.. and try to spend 20USD only and learn to reball the 65 and the 55 one too.. i think its better than to buy MB for 65
                      • Michale32086
                        • Nov 2011
                        • 1453
                        I have looked into reballing.. Seems really complicated to me...
                        • Diah
                          • Feb 2013
                          • 6555
                          its much easy than reflow. search on how reball Sony Play station CPU. its same 100%
                          • budwich
                            • Jul 2015
                            • 3097
                            before you go down that path, have you tried looking at some of the voltages at the main board to ensure that they are there? Perhaps your "cooking" didn't do anything but take out some marginal components (ie. capacitors or otherwise). In particular, 5v which should be easy to see / find ... just look around the usb port area (might have to look at which pin is which). Of course, there are others. Since you know one card (55) works, that indicates the supporting cards are good.... but it depends what voltages are supplied to the main and which are derived / switched at the main board.
                            Might be a waste of time but it can't hurt as a simple check.
                            • Michale32086
                              • Nov 2011
                              • 1453
                              Sorry I missed this.. Unfortunately, I am a one man operation and since I had this on my bench, 30 TVs came thru...
                              I DID find a replacement Main Board for $300 that should arrive today.. I am hoping this will be a happy ending to a long saga...
                              I pulled the TV out of storage fully expecting I had cracked the screen at some point since it was last out.. A huge sigh of relief when I put it on the bench and saw it was in good shape.. Whew!!!
                              I'll follow up later today when the board comes..
                              Thanx again for all the help and replies.. It's all very greatly appreciated..
                              • Michale32086
                                • Nov 2011
                                • 1453
                                Well, there is no joy in mudville today.
                                The board came in and I installed it.. The Power LED comes on and pulses a couple times, then goes off.. The the LED turns orange, green, orange and then stops...
                                That COULD indicate a firmware issue, but usually (at least with the last couple times I tried it successfully) the LED stayed on orange/green/orange/green etc etc..
                                Anyways, I tried a firmware install all day yesterday and even left it going overnight.. No luck...
                                So, I am going to go back to Budwich's comment and try those voltages..
                                The board I got ostensibly says it's for the XBR-55X900C, but according to the labels on the panel, it should still work in a 65X....
                                I'll follow up with those voltages in a few mins..
                                • Michale32086
                                  • Nov 2011
                                  • 1453
                                  Something else I think I might try is to take the new board and put it on the XBR 55X..
                                  That should at least tell me whether the board is good or not...
                                  • budwich
                                    • Jul 2015
                                    • 3097
                                    that would be a good idea of at least giving you a "base check" before doing anything else like voltage checks.
                                    • Michale32086
                                      • Nov 2011
                                      • 1453
                                      I did check the 5V off the USB just for sheets and greens.
                                      I initially got a solid 5V reading but then it faded and went to wild fluctuations.. This was on the 55X TV...
                                      I didn't get a 5V again, even when the Power LED showed it was "on"...
                                      I get the exact same cycles on the 55X that I did on the 65X..
                                      Power LED comes on, fades,comes on, fades, then comes on real bright, then fades, then an orange/green LED.. Interesting to note that, the longer I let it cycle, the more orange/green flashes I see.. Starts off with 1 of each, after a few mins, 2 of each etc etc..
                                      I also noticed that the Optical Audio laser only comes on for a brief moment. In a working environment, the red laser usually stays on all the time.
                                      So, I am guessing I got a bad board..
                                      • Michale32086
                                        • Nov 2011
                                        • 1453
                                        I should also note that the afore mentioned cycle happens completely independent of any button pushing...
                                        It happens at power up and pushing any button, including the power button, has no effect..
                                        • Michale32086
                                          • Nov 2011
                                          • 1453
                                          I have identified the FIRMWARE chip.. A winbond..
                                          Advisability of an old fashioned chip swap???
                                          • HarryZ
                                            Sony XBR-49X800G networking issues
                                            by HarryZ
                                            Aloha. First post here, hope I can find someone to assist me.
                                            I have a Sony XBR49X800G with streaming issues. The issue mostly occurs watching sporting events (basketball and football). The picture will sometimes get pixelated, sometimes freeze for a few seconds while the audio continues, sometimes it's jerky. In other words, you get a headache watching the TV.
                                            My ISP provides 500 Mb service and I have verified that I have at least 500 Mb on ethernet, and something over 300Mb on WiFi. I installed Analiti on the TV (it's an Android TV) and I get ~ 70 Mb on both WiFi...
                                            01-26-2024, 04:49 PM
                                          • cheeky2
                                            Toshiba 49U7763DB (Mainboard: Vestel 17MB120) firmware issues after sporadic power cu
                                            by cheeky2
                                            I have this Toshiba 49U7763DB Tv which was suffering issues after various electrical power cuts, which happened in quick succession
                                            Originally the TV was powering on and then very shortly powering off. I managed to get into the menu structure before powering off and carry out a first time installation of the TV. Which didn't make much difference. I have managed to factory reset (that didn't make any difference either).
                                            The firmware inside the 17MB120 is corrupted and is causing some strange issues so my question is does anyone have any suitable firmware for this model?
                                            Details:...
                                            08-17-2023, 04:34 AM
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
                                          • PontyPCs
                                            Sony Android TVs eMMC Issues
                                            by PontyPCs
                                            Hi people.
                                            I have been trying to get my head round these issues with the eMMC putting the TV in to a boot loop condition, or completely dead, when a dump of the Boot 1, Boot 2 and USERDATA partitions have been made, the MLC lifetime counter has been reset, using the original eMMC with the RPMB partition intact and the eMMC is flashed with the original dump, Netflix and a few other Apps don't work. i assume all the DHCP keys and factory programmed RPMB access Key will be contained within the original dump, and as we are re-flashing the original eMMC i would expect every thing to work....
                                            12-10-2023, 10:43 AM
                                          • ptcriserx3
                                            Sony trinitron crt bowed and side color issues
                                            by ptcriserx3
                                            Hi
                                            Ive got a vintage 2001 sony trinitron flat tube tv
                                            The image is slightly bowed and the left and right sides about 1-2in has fluctuating discoloration that comes and goes if i move or hit tv on sides
                                            See many images attached...
                                            Just windering if this is not fixable or something i can correct without getting too invloved
                                            Im trying to sell the tv
                                            06-17-2023, 07:27 PM
