LG 65UH5500 Dead
  • hbdeals
    • Oct 2014
    • 55
    LG 65UH5500 Dead
    It does does nothing, no power light.
    It was getting all of the 80, 13 voltages, but Zero on the standby pin. I warmed the board with a hair dryer for 30 seconds. Now the 80 volts is 45. The 13 volts is 8. Still no life on standby pin.
    Disconnecting LED board makes no difference in the voltage readings.
    It makes a faint high voltage hissy pulse sound coming from the larger transformers.
    Bridge rectifier shows 160 volts output.
    360 volts on the 3 long capacitors.
    The small yellow LP2 gets 130 degrees F.
    The bridge rectifier heat sink gets 125 degrees F.
    Everything else is room temperature.
    Resistor RF1 reads open, replaced it, no change.
    All diodes and fuses check good.
    Not sure where or what to check next.
  • hbdeals
    • Oct 2014
    • 55
    Re: LG 65UH5500 Dead
    The power board.
    • neilc6
      • Nov 2015
      • 1550
      I would just replace the power supply and buy one from a seller that takes returns on ebay. Schematics would be hard to find and difficult to debug a power supply without one after checking usual suspects (shorted diodes, fets, rectifiers, blown fuses, cold solder joints). That model does suffer from backlight failures as well so I would turn down the backlight level after being repaired.
      • hbdeals
        • Oct 2014
        • 55
        yep, that's the very reason I'm trying to fix the power board. I'm not too crazy about the other common failures on this one. I've been down the rabbit hole before of replacing board after board and then find out it needs LED strips too.
        So anyway, I put the power board in plastic bags and let it sit in the freezer for 30 minutes. hooked it up and the high voltage fizzy pulse got much louder.
        Once it went back to room temperature, it's the same faint level it was before.
        Guess I need some of that fancy freeze spray.
        • R_J
          • 9588
          The stb pin is the control pin from the main board, it is used to turn the power supply on and off, If you are getting 80 volts and 13 volts, the power supply is working, I suspect your problem is on the mainboard and it is holding the STB line low
          • Diah
            • Feb 2013
            • 6436
            man, are you posting here to trouble shooting TV or Kitchen Oven ? reading temprature or all what did you wrote on first post had nothing to bring any good known member to join and help.
            1- start with upload complete photos on whole boards to see how they are connected each other, either the edge BL strip and the connector
            2- you have noise at the transformer at hot area... mean you should consider on cold area but you should 100% disconnected main board from PSU and just trace PW ON voltage at PSU side... so you can start repairing
            • hbdeals
              • Oct 2014
              • 55
              STB is zero volts without any connection to any boards. Getting 45 Volts on the 80 and 8 on the 13.2 pins.
              • hbdeals
                • Oct 2014
                • 55
                The oven might be in this boards future indeed.
                It is disconnected.
                I posted a picture of it earlier. It only has one 15 pin connector.
                • R_J
                  • 9588
                  Well then STB needs to be high to turn on the power supply. What voltage are you expecting on the STB pin?
                  I suspect the main board takes the 13 volts (standby 8) and regulates it to either 5 or 3.3 volts. the main board will send (3.3/5v) to the STB pin turning the power supply on fully.
                  with the main disconnected you should be able to apply 3~5 volts to the STB pin and the 80 & 13v will come up full.
                  • hbdeals
                    • Oct 2014
                    • 55
                    Sounds good. From another post of a person on here, I have deducted that the STB pin should be 3.3 volts. Would a Lithium 3.3 volt battery do it? Thanks
                      Post #1
                      "Bridge rectifier shows 160 volts output.
                      360 volts on the 3 long capacitors."
                      Sounds like the PFC boosted Voltage is present so PS-ON must be working then. Or may be wrong data if STB stays 0V, or it may be active- low signal.
                      "Resistor RF1 reads open, replaced it, no change."
                      Pictures of this RF1? Also provide other pictures as requested by other helpers.
                      • hbdeals
                        • Oct 2014
                        • 55
                        The resistor is circled in the picture. That's the one that tested open.
                        • hbdeals
                          • Oct 2014
                          • 55
                          The yellow LP2 gets warm. 130 degrees via infrared thermometer.
                          • R_J
                            • 9588
                            Coils do get warm , did you try turning on the power supply with the battery?
                              I am also surprised that you even getting and DC on the output when RF1 (1 Ohm fusible resistor) is open circuit.
                              • R_J
                                • 9588
                                RF1 seems to be a fuse resistor for the circuit that has C56 as the filter and could be the vcc for u1 ? it seems to connect to pin 6 . whatever U1 is
                                • hbdeals
                                  • Oct 2014
                                  • 55
                                  Not yet, not sure how to hook a battery to it. Negative to chassis, positive to pin?
                                  • hbdeals
                                    • Oct 2014
                                    • 55
                                    That thing is a fuse? Dang well the resistor I replaced it with is a 1 ohm resistor. C56 wasn't charging with the old resistor fuse. It charges up now with a good snap if I short the cap out with a screwdriver.
                                    • R_J
                                      • 9588
                                      It can be called a fusable resistor or it could just be a 1Ω flame proof resistor, it is there to protect the power supply if something shorts like the main ic, DON'T short capacitors like that, the high current spark can cause damage elsewhere in the circuit, like the main u1 ic. Always discharge a cap with a proper resistor
                                      And to turn on the power supply with the 3v battery, it is negative to ground pin, positive to STB pin (main board plug disconnected)
                                      • hbdeals
                                        • Oct 2014
                                        • 55
                                        I'm aware of the "rules", and I fully understand what you mean. I have fixed many tv's with these rudimentary methods, but this one is one of those that's beyond my backwoods electronic skills. It's ok if this one don't pan out, I have a pile of them in line for more torture... haha
                                        I will try to be more civil with this one until there is a conclusion. I promise that there will be an ending to this story, good or bad. Thanks for the help.
                                        • BTubbs200
                                          Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                                          by BTubbs200
                                          Dell Latitude 5420 P137G
                                          Board: LA-K491P REV A01
                                          I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                                          Board seems to have no shorts, all power rails are fine and show high resistance.
                                          When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                                          01-24-2025, 08:15 PM
                                        • Nagyesz
                                          Lenovo ideapad 330ICH - Dead, no volts on coils
                                          by Nagyesz
                                          Hi everyone, I replaced this motherboard because it was important to get it working, but it's been with me for a very long time. Now I finally have time to figure out what the problem is,
                                          I've never encountered something like this before;
                                          No charging light, full dead
                                          Lenovo Ideapad 330-17ICH
                                          • PL3102: 5 ohms
                                          • PL3001: 3.2 ohms
                                          • PL3101: 2 ohms
                                          • PL5801: 3.5 ohms
                                          • PL5501: 270 ohms
                                          • PL701: 35 ohms
                                          • PL501: 146 ohms
                                          • PL503: 390 ohms
                                          • PL402: OL (0.27V) +5VALW_P
                                          • PL301: OL
                                          • PL401: OL (0.03V) +3VALW_P
                                          + Dc-in mosfet @PQ311 pin 5 20v, pin 1-4 0V , @PQ312 no volts...
                                          10-11-2024, 10:12 AM
                                        • u666sa
                                          HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                                          by u666sa
                                          Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                                          Platform: ipa32 la-m024p rev 1b
                                          Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                                          I found a short on the other side:
                                          10-04-2025, 05:03 PM
                                        • MisterAIL
                                          PS5 digital / No Power / No Beep / Good power supply
                                          by MisterAIL
                                          Brought a non functionnal PS5. Apparently only a bad PSU...
                                          No beep, nothing.
                                          After some tests i found this :
                                          - PSU is fine (12 volts stable)
                                          - 12 volts line is shorted
                                          - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                                          - By the way, nothing change. No signal, no power, no beep.
                                          Mesuring all rails with my workbench psu (12 volts input)
                                          - 0.00 amp drawing
                                          - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                                          03-12-2024, 03:24 PM
                                        • _AcE_
                                          JBL Soundbar 2.1 Deep Bass PSU No DC Power Output (Detailed, w/ Schematics)
                                          by _AcE_
                                          I have two of these soundbars, both with the exact same issue. The soundbars were hit by lightning and no longer power on. The PSU does not output any voltage on the DC side. When plugged into mains, the DC output is a stone-cold 0.0 volts. The AC side of the PSU seems to be functioning correctly (as far as I can tell). When checking the plugged-in PSU with my thermal camera, the OB5269CP PWM controller (U1) and the two resistors (R12 and R13) pulse on and off. These run to the positive DC side of the bridge rectifier (among other components along the way).
                                          There's no physical damage...
                                          08-10-2025, 09:27 AM
