UN55KS8000 T con or screen?
  • jason123
    • Oct 2015
    • 1056
    Re: UN55KS8000 T con or screen?
    1206 100 ohm, maybe get 4 or so, replace the resistors, if no joy might need to remove the diode packs, might only need to remove one diode pack maybe both, might both be ok.
    Thank you..
    • jason123
      • Oct 2015
      • 1056
      Originally posted by Davi.p
      Diodes: uClamp6514P (UCLAMP6514P.TNT) or alternative uClamp4014P (UCLAMP4014P.TNT) by Semtech
      ESD7004 seems like the right part as it's a pack of 4 diodes in one chip
      • jason123
        • Oct 2015
        • 1056
        ESD7004 Does not work. We need a bidirectional TVS - I tried uClamp6514P does work!
          • 12111
          • U.S.
          So it's working?
          • jason123
            • Oct 2015
            • 1056
            Yes, working beautifully
              • 12111
              • U.S.
              #26
              So what was the problem, the diode was not ESD704 as reported by diff?
              • jason123
                • Oct 2015
                • 1056
                Correct #17 stated ESD7004 as an option, I got that and it didn't work. I used the uClamp6514P and that worked fine. System does work without anything stuffed in that location, but I wanted to restore to original factory - bad quality design
                • Daren87
                  Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                  by Daren87
                  I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                  08-13-2023, 03:25 PM
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
                • alltvrepairs
                  Lg TCon test pins for screen test
                  by alltvrepairs
                  i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                  Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                  Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                  Appreciate your help....
                  06-13-2025, 06:33 AM
                • smic717394
                  by smic717394
                  07-25-2024, 10:16 AM
                • Chrissygizmo
                  by Chrissygizmo
                  02-10-2025, 12:33 AM
