LG 37lv375s no 24V
  • chrle
    • Sep 2013
    • 158
    • slovakia
    LG 37lv375s no 24V
    hello guys
    I buy today LG 37lv375s Smart tv
    Problem is when I plug cord and turn on tv ,something clicks ,flash 2 times red light and off.
    backlight not turning on
    I measure voltage on power board
    I got 3.5 volt,12volt but 24volt is 0.voltmeter shows 8 volt for second and then 0 ,jumping voltage.
    Re: LG 37lv375s no 24V
    Can we get straight shot pictures of the whole top side and bottom side of this power supply board?
    • R_J
      • 9632
      If you have +12 volts, you should also have +24 volts, they both come from the same T101 transformer, so check for poor connections on the transformer pins and diodes 251, D252, D255
      • chrle
        • Sep 2013
        • 158
        • slovakia
        uploading pic
        • chrle
          • Sep 2013
          • 158
          • slovakia
          ok guys I have all voltages OK on power board
          3,5 12v and 24v
          now I must to see why is not powering backlight..
          • chrle
            • Sep 2013
            • 158
            • slovakia
              • 12323
              • U.S.
              Try tv unplugged from outlet, unplug cable from powerboard to mainboard, plug tv back in outlet, see if backlight comes on and stays on.
                • 12323
                • U.S.
                After above test, with cable hooked back up, test connector from mainboard to powerboard on powerboard side, test with tv plugged in but off then hit power, report both conditions here, give pin number, pin description and condition on and off.
                • chrle
                  • Sep 2013
                  • 158
                  • slovakia
                  ok cable unpluged from main board
                  power tv ,no backlight
                  • chrle
                    • Sep 2013
                    • 158
                    • slovakia
                    ok tv in stand by mode
                    N.C
                    0v
                    0v
                    0v
                    GND
                    GND
                    3.5V
                    3.5V
                    GND
                    GND
                    0v
                    power-on 0V
                    after turn on :
                    N.C
                    12.1V
                    12.1V
                    12.1V
                    GND
                    GND
                    3.5V
                    3.5V
                    GND
                    GND
                    24.9V
                    POWER -On 3.3V
                      • 12323
                      • U.S.
                      If you have an ok button on the tv panel try holding that for 15 seconds see if tv starts up or try holding ok button on panel and remote for 15 seconds or so.
                        • 12323
                        • U.S.
                        Guessing a backlight issue, which it usually is like 98 percent of the cases with led lit tvs.
                        • chrle
                          • Sep 2013
                          • 158
                          • slovakia
                          ok but I cant see menu when I put light on display
                          and i look on power led turn to blue when I turn on tv..hmm
                          • chrle
                            • Sep 2013
                            • 158
                            • slovakia
                            I think that Led driver board is faulty,24 volt is coming to board but 0V out from board, with or without cable disconnected from led strips
                            • R_J
                              • 9632
                              Check the fuse on the driver board, it is labeled F101 [M] (4amp), if the fuse is ok, check the voltage across c219 or c220, this voltage needs to be monitored when you first turn on the tv, If there is a fault with the backlights, the board will error and shut down.
                              • chrle
                                • Sep 2013
                                • 158
                                • slovakia
                                fuse is ok ,no voltage on c219 and c220
                                C101 24v
                                • R_J
                                  • 9632
                                  It could be that there is no backlight on or INV_ON signal going to that driver board, My guess is that Q502 switches the +24 volts on for the driver board, It looks like the BLON is pin 12 of J1, check the voltage on pins 11~14
                                  • chrle
                                    • Sep 2013
                                    • 158
                                    • slovakia
                                    pin 14 3.35V
                                    pin 13 2.44v
                                    inv ON 0.03
                                    • R_J
                                      • 9632
                                      There you go, you are missing inverter ON, monitor that pin when you first turn on the tv to see if it comes up to 3 volts then drops. What about pin 11 DET?
                                      • chrle
                                        • Sep 2013
                                        • 158
                                        • slovakia
                                        from zero to 0.03V not 3V
                                        pin 11 0V
                                        • gabri2211
                                          external hd Seagate, broken down the +12 volt and USB 3.0 SATA board
                                          by gabri2211
                                          Hi to all 😎
                                          I'm looking for any useful information to repair this interface (I have attached the image).
                                          On this board I read E3215-1215A_4D.
                                          This is the small plate inside the HD enclosure that allows to connect a 12 volt power supply, interface the disk with a USB 3.0 socket and is connected to the HD with the SATA connector.
                                          If any of you have found a burnt or short-circuited component in a circuit like mine​, if you have useful diagrams for the repair, or even better a description for the tests at the test points, I would be very grateful.
                                          in particular...
                                          11-12-2024, 08:08 PM
                                        • GRANDGG
                                          LG 42lw4500 flashing red light , wight light , 2 clicks
                                          by GRANDGG
                                          Hi i have an issue with LG 42lw4500 wich after pressing the power button flashes red then goes solid white light 2 clicks and nothing , the weird thing is SOMETIMES if i leave the tv plugged in it would come on and fuction normally (i should mention that vertical rectangle going from the bottom to the top of the screen have some red dot artafacts it only appear in somthing like the tv input menu and any input i give like vga , but not in the system menu , i thought i should mention this , i cannot confirme if the tv had this issue when it was up and running in its previous owner . ) when checking...
                                          05-09-2025, 12:27 PM
                                        • CapLeaker
                                          LG 65UQ70 horizontal bars jumping
                                          by CapLeaker
                                          So I bought this LG 65UQ70 today at Walliworld. Put the wall mount on, set it up, worked for 30 mins and then I get these jumping horizontal bars. Let the TV do updates and let it cool down for 5 mins. Worked perfect for 2 mins. As soon the TV is warm I get the jumping vertical bars again.
                                          Keep the other TCL thread in mind. Now I am questioning are all COVID 2022 / 23 TV’s bad or what? That’s two 65” TV’s one from Amazon and this one from Walmart. What are the chances on that?
                                          I guess this one goes back either later today or tomorrow morning, unless...
                                          08-13-2024, 09:41 AM
                                          Using a 5 volt @ 12 amp switching power supply and two USB doctor volt / amp meter to three IPads on one power supply
                                          by sam_sam_sam
                                          I have been wanting to do this project for some time using a Mean-well switching power supply that I bought at least ten of them that were originally in a device that was abandoned for some reason they were listed new but removed from equipment that was never used
                                          I do not understand Mean-well the capacitor next to the voltage reference ic chip was a brand that is known for failure over time the other capacitors are brand name needless to say it got replaced before I even powered it on for the first time
                                          I used a four USB outlet and electrical plate that is made for...
                                          08-03-2024, 07:54 PM
                                          I need to order some 1000uf @ 16 volt it has to be 8mm in diameter what is a good choice
                                          by sam_sam_sam
                                          Here is the page of capacitors that I can choose from what is a good choice for a FSP 400-60GLC
                                          https://www.digikey.com/en/products/...Xmc1YPJ6BlESoA
                                          I try to use a 565-1664-ND which is a 10mm in diameter unfortunately it will not fit because there are two of them the same size and value and there is no room and they go to two different circuits not in parallel...
                                          08-03-2024, 02:54 PM
