SHARP LC-80LE633U has open resistor r7133 on PSU
    Re: SHARP LC-80LE633U has open resistor r7133 on PSU
    OK, I will look at the board layout of the standby power supply section and will get back to you with the test points for you to test.
    • ki4mqz
      • Aug 2020
      • 31
      Can't thank you enough. I'll be around to tonight and on standby if you come up with something. Thanks!!!
      • ki4mqz
        • Aug 2020
        • 31
        See attached photo for IC7102 Pinout with measured voltages. Using HOT ground. All DC.
        Pin 1 - 0.56v
        Pin 2 - 5.89V
        Pin 4 - 170V
        Pins 5-8 - 0v. After tracing, it looks like pins 5-8 are on the HOT ground bus.
        Also, the "burn" marks on this board is flux from where I installed the new IC. No obvious burns or anything anywhere.
        • ki4mqz
          • Aug 2020
          • 31
          After reading the PDF for the TNY274 attached earlier in this thread, I may have a direction to chase. Pin 1 of the IC controls the oscillation of the chip. Pin 1 signal is fed from the optocoupler, and the optocoupler is referencing the secondary voltage. If the secondary voltage goes high, the optocoupler begins to close the emitter and collector side of the OC, forcing the voltage of pin 1 to drop, thus controlling the secondary voltage. According to the IC PDF, Pin1 (EN/UV) switches the IC off when voltage drops below 1v. No IC on equals no oscillation which would thus keep the transformer from working.
          Looking at my diagram above, pin 1 is at 0.56v. This tells me that I might possibly have an issue with that optocoupler. One possible way to test it is to uncouple the OC from the circuit on the Collector/Emitter side and see if it powers up. Any harm in that? I will continue to dig into this tonight once I get off work.
          • ki4mqz
            • Aug 2020
            • 31
            Update! As mentioned, I began probing around IC7102 Pin 1. First I unsoldered pin 1 from PC7103 and had no affect on the voltage. Next, I unsoldered diode D7110 and viola! Pin 1 came up to 1 volt! 5v bus on and TV powers up! So it appears D7110 is bad. It appears to be a zener. Any ideas on the spec for it?
            Diode is marked either B62, 2B6, or 62B. Hard to say as the numbers go all the way around.
              That Zener diode on pin 1 (EN) is for protection to clamp down the Voltage to protect that input pin, as you can see in the application circuit, they do not even install the Zener on that pin.
              Since EN typ Voltage is about 2V per spec, you can use 6.2V or 5.1V Zener.
              BTW, did you check the resistance in both direction of that Zener?
              • ki4mqz
                • Aug 2020
                • 31
                I did check resistance. It shows resistance both ways (170 ohm forward, 350 ohm reverse) which makes me think its bad?
                  It is bad, that is why EN pin is only getting 0.56V, it should be around 2V on EN pin to enable the TNY to run.
                  I am glad you found the cause of the problem on your own.
                  When TNY blows up, it will usually take the opto and zener (if it is implemented) with it.
                  • R_J
                    • 9629
                    On a similar power supply using a TNY274PN, pin 1 has a MTZJ8.2B zener
                    • ki4mqz
                      • Aug 2020
                      • 31
                      Thanks for all the replys. Feels good to find it. Only remaining problem I am concerned about is randomly, when you power the unit up, as the backlight comes on, there is an audible rapid "clicking" coming from the primary transformer area of the board. The clicking changes speed with the brightness of the backlight. Any insight on that?
                      Edit: the backlight and all comes up and does function normally. TV performance doesn't seem to be affected by it.
                      Thanks a ton R J on the part number. Huge help!
                      • R_J
                        • 9629
                        The standby controller ic usually supplies the vcc for the main ic's also, so check that voltage. Did you replace the small elec. caps in the standby circuit? C7114, C7107.
                        It looks like Q7101 is the vcc regulator/switch, so check the voltage on it's emitter & collector
                        • ki4mqz
                          • Aug 2020
                          • 31
                          I have not replaced anything other than R7133 and IC7102. Would powering the board up with D7110 missing possibly have something to do with it? It has never done this before.
                          Collector is 18.8vdc, emitter is 15.7vdc.
                          • R_J
                            • 9629
                            I don't think having the diode out of the circuit would effect the operation as it is the standby circuit, but it is possible. The Q7101 voltages look correct.
                            • ki4mqz
                              • Aug 2020
                              • 31
                              What is your thoughts on the noise? What is it? Loudest right on top of the transformer highlighted below using a stethoscope.
                              • R_J
                                • 9629
                                Those two inductors L7203, L7204 are part of the pfc circuit, I'm not sure why they are making noise, although it might be normal as the pfc circuit turns on, or it could be as the main supply and led drive circuit comes on and starts drawing more current.
                                • ki4mqz
                                  • Aug 2020
                                  • 31
                                  It is very interesting. As it warms up, it disappears. I will get the diode you spoke of ordered and installed and see if it changes anything, but I don't expect it to.
                                  Edit: It does not sound normal. It is very audible and would not qualify as acceptable.
                                  • R_J
                                    • 9629
                                    Check the pfc voltage across one of the main primary caps, C7220 for example, the voltage should be around 160vdc in standby, then come up to around 385vdc when the tv is turned on.
                                    • ki4mqz
                                      • Aug 2020
                                      • 31
                                      It is right at 388VDC and does not fluctuate when the backlight comes up.
                                      With it making noise. The noise starts as soon as the backlight starts to come on and ramps up as the brightness comes up. It is very clearly related directly to backlight brightness.
                                        Does the noise change if you increase or decrease the backlights level (not Brightness)?
                                        • ki4mqz
                                          • Aug 2020
                                          • 31
                                          I have the TV laying face down on a bench. So changing that is going to be quite difficult. If I feed it a signal, as the input/display changes, it changes with it. But after a 30 seconds or so, it completely disappears.
                                          I said brightness, what I meant was backlight level. Sorry for the confusion.
                                          • jinu_j
                                            by jinu_j
                                            Hi
                                            05-03-2025, 10:51 PM
                                          • mikey5791
                                            Need help to replace burned resistor in 350w atx psu
                                            by mikey5791
                                            Hi to all forum members,
                                            Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                            The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                            Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                            Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                            12-26-2024, 04:55 AM
                                          • MidnightRoller
                                            Can a resistor lose resistance after hot air?
                                            by MidnightRoller
                                            I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                            I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                            02-02-2022, 11:46 PM
                                          • artvandalai
                                            What resistor ohm will work better to repair this waterpik?
                                            by artvandalai
                                            The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                                            01-05-2025, 04:10 PM
                                          • flat-earther
                                            Hoover FM216LI cordless vacuum refuses to charge
                                            by flat-earther
                                            I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
                                            I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
                                            5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
                                            So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
                                            06-06-2025, 03:14 AM
