VIZIO M552i-B2
  • ca2014mp2
    • May 2016
    • 48
    • usa
    VIZIO M552i-B2
    Does anyone have any wiring diagrams for a VIZIO M552i-B2. I'm new and I spent 4 hours online, even signed up with a paid service and found BOOK SALES in the end. I did shoot through the sticky notes but didn't find anything that said wiring diagrams. Are they to be had or do I have to wait for the right to repair bill to be passed in calif?
    Thanks for your response and welcome to the board!
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: VIZIO M552i-B2
    What is the problem with your tv?
    • ca2014mp2
      • May 2016
      • 48
      • usa
      Re: VIZIO M552i-B2
      Current symptoms is tv presents with no picture. Screen does show back light although a bit dim IMO. When tv is booted the screen displays nothing but a glow at the center of the screen. No indications of sound. When I press menu on the remote I get a different back light pattern but nothing visual - not sure if I'm seeing a horrible display of menu section or back lighting pattern. I was looking to isolate and prove the t-con board vs the mb -main board vs lcd display. T-con board was replaced as a shot in the dark purchased from amazon. I do have 26v at backlight pannel and 12 at main board with 5 and 12 volts at t-conn. Remote functions as expected limited to no visual proof.
      I need the wiring diagrams to test out components and not fire the parts cannon at the tv. I have the tools for component level repair, just need the data.
      • tvtimmy
        • Mar 2015
        • 1160
        • usa
        Re: VIZIO M552i-B2
        You are in luck! All you need to fix your set is:
        1. Leaded solder
        2. Solder sucker
        Reflow the connector between the power board and the led driver board. I then remove the solder one at a time to get rid of the lead-free solder and then resolder for good.
        Then I glue down the black connector to the power board. There are 2 rows of pins. Row 1 are all common and row 2 are all common, you could run a line across each row. Dont bridge row 1 to row 2.
        I'll bet your connection looks like this picture.
        • ca2014mp2
          • May 2016
          • 48
          • usa
          Re: VIZIO M552i-B2
          No, sorry I looked at that, it's fine.. and thanks.. any idea where I can get wiring diagrams?
          • tvtimmy
            • Mar 2015
            • 1160
            • usa
            Re: VIZIO M552i-B2
            Check all the 000 resistors on the led driver board. I think I count 6.
            • R_J
              • 9588
              Re: VIZIO M552i-B2
              Seems like the backlight is working, pressing menu has an effect on the backlight which would be expected as the backlight would be dim without any video.
              Try disconnecting one of the cables between the panel and t-con, see if you get half picture, then reconnect and try disconnecting the other cable between panel and t-con.
              Disconnect & reconnect cables with tv unplugged.
              • ca2014mp2
                • May 2016
                • 48
                • usa
                Re: VIZIO M552i-B2
                6 resistors at 6 locations are not broken @ .6 to .7 ohms
                My board pictured below
                • ca2014mp2
                  • May 2016
                  • 48
                  • usa
                  Re: VIZIO M552i-B2
                  oh things just got interesting: ok in reference to me facing the tv from the front:
                  I removed the tcon board's ribbon to the display right hand side and 3/4 of the right hand screen lit up very brightly and tappers off to the left see picture 1
                  Then I removed the tcon board's ribbon to the display left hand side and 3/4 of the right hand screen it up dimly in comparison to the first test and has the exact same pattern showing on the screen just dimmer. picture 2
                  • ca2014mp2
                    • May 2016
                    • 48
                    • usa
                    Re: VIZIO M552i-B2
                    Ok fortunately I do have another tcon board with all references the same I swapped out the board.
                    From the second board round of test:
                    I removed the tcon board's ribbon to the display right hand side and 3/4 of the right hand screen lit up very brightly and tappers off to the left.
                    Then I removed the tcon board's ribbon to the display left hand side and 3/4 of the right hand screen it up dimly and darker than the first boards test in comparison to the first test and has the exact same pattern showing on the screen just dimmer much dimmer. see picture 2
                    ON either test I didn't hear sound or OSD just what is in the picture
                    • R_J
                      • 9588
                      Re: VIZIO M552i-B2
                      Sometimes if the panel has a problem, this test can show a picture on either half of the screen. since there is no real video, it could be a faulty main board, the issue of no audio could just be the tv is set to the wrong source, sometimes connecting a hdmi source will automatically switch to the correct input and then you might have sound.
                      • ca2014mp2
                        • May 2016
                        • 48
                        • usa
                        Re: VIZIO M552i-B2
                        Well that is what i'm after, what test do you want to do to get us there?
                        • ca2014mp2
                          • May 2016
                          • 48
                          • usa
                          Re: VIZIO M552i-B2
                          what about the osd or the Viszio logo on boot up. Is that generated from the MB? I can hook up a HDMI but with no image it wont prove anything. For this test are we thinking that the tcon and display are good? Or maybe a better question is what have we proven with this test?
                            Re: VIZIO M552i-B2
                            Can you please upload good clear hi-res pictures of the whole T-CON board? There should be a bunch of Voltage points that you can check.
                            • R_J
                              • 9588
                              Re: VIZIO M552i-B2
                              I suggested the hdmi source just to see if the main board produced audio, Anything could be causing the issue on the main board, even a corrupt eeprom.
                              The osd and logo come from the main board, I'm not sure how you can track down the problem, You said you already replaced the t-con and that did'nt change anything so I would guess the fault is on the main board.
                              I have a scope to check for video signals on the main, lvds cable and t-con so I don't have to guess where the fault is located.
                              • ca2014mp2
                                • May 2016
                                • 48
                                • usa
                                Re: VIZIO M552i-B2
                                Tcon board front and back Hi-res
                                • ca2014mp2
                                  • May 2016
                                  • 48
                                  • usa
                                  Re: VIZIO M552i-B2
                                  Well come on with those measurements and where you took them. I have two scopes here. I'm setting up for the HDMI test but it will be in 30 min.
                                    Re: VIZIO M552i-B2
                                    Check the Voltages on the T-CON without having the cables between T-CON and the LCD panel connected first.
                                    Voltage test points around U2 (LCD power supplies): HVDD, VCC, VDD, VGH, VGL.
                                    On the left side of the board: VEPI, VCORE.
                                    Then do the same test with cables back in place.
                                    • ca2014mp2
                                      • May 2016
                                      • 48
                                      • usa
                                      Re: VIZIO M552i-B2
                                      Ok, on this test I didn't see any osd but it was clear that my inputs from the remote where having an effect on the tv. Shades of back light were turning up and down in brightness. After playing with the input button and doing different combinations I was able to get a flicker, just a few vertical lines that quickly disappeared to just a white screen. And then the audio came in. It was nice and clear. so I've proved sound have half a white screen but no image.
                                      • ca2014mp2
                                        • May 2016
                                        • 48
                                        • usa
                                        Re: VIZIO M552i-B2
                                        tv plugged in lcd panel disconnected:
                                        HVDD,7.87
                                        VCC,3.325
                                        VDD, 15.72
                                        VGH, 28.19
                                        VGL. 5.12
                                        VEPI,1.813
                                        VCORE.1.205
                                        tv plugged in lcd panel connect:
                                        HVDD, .8 mv
                                        VCC, 3.327
                                        VDD, 2.3mv
                                        VGH, -202.4mv
                                        VGL. -5.13
                                        VEPI, 1.811
                                        VCORE. 1.205 -- but drops to zero after 10 min during verification process.
                                        all measurement are volt unless specified different
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
                                        • mrtek
                                          Vizio M65-C1
                                          by mrtek
                                          Hi.
                                          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                          07-14-2025, 07:28 PM
                                        • howardc64
                                          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                          by howardc64
                                          Failure Symptom
                                          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                          Where is the short?
                                          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                          05-27-2025, 02:56 PM
                                        • howardc64
                                          Vizio SmartCast TV software bug that looks like hardware
                                          by howardc64
                                          Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                                          It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                                          11-16-2024, 05:17 PM
