VIZIO M552i-B2
  • dskall
    • Oct 2016
    • 2905
    • usa
    #41
    Re: VIZIO M552i-B2
    Originally posted by gregcs
    Anyone ever find a diagram for this model? I'm having a problem with my power supply board - it blew up chip IC 901 (which is an Infineon ice3b1565), which I'm able to find to order. Based on some discoloration on the back of the board, it seems like it may have a problem with part L801 as well, but I can't tell what it is. Looks like some kind of voltage regulator maybe - it's the very upper left part in this image https://www.ebay.com/itm/NEW-Vizio-M...9/114285632480
    L801 is transformer for PFC. Doubt if it's bad. Doubt if you could find one anyway. If your chip is bad, you need to check the fet it drives for short.
    • viewerau
      • May 2020
      • 305
      Re: VIZIO M552i-B2
      Thanks for the speedy reply....should power be off to the edge boards whilst testing?
      Signature:Seemingly hopeless tv fixer
      • nomoresonys
        • 12276
        • U.S.
        #43
        Re: VIZIO M552i-B2
        Yes power off, no power on while testing in diode or ohm mode.
        • viewerau
          • May 2020
          • 305
          Re: VIZIO M552i-B2
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • SS454
            vizio e650i-a2 backlight flashes then turns off
            by SS454
            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
            panel: au optronics T650HVN05.4
            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
            https://www.shopjimmy.com/vizio-56-0...-power-supply/
            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
            08-20-2020, 03:57 PM
          • mrtek
            Vizio M65-C1
            by mrtek
            Hi.
            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
            07-14-2025, 07:28 PM
          • howardc64
            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
            by howardc64
            Failure Symptom
            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
            Where is the short?
            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
            05-27-2025, 02:56 PM
          • howardc64
            Vizio SmartCast TV software bug that looks like hardware
            by howardc64
            Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
            It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
            11-16-2024, 05:17 PM
