Sharp LC-55N620CU PSU 192020 help ID'ing a transistor
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    I'm working on the stand-by portion of a HiSense/Sharp power supply #192020. I found a transistor blown apart to the point I can only read a couple numbers. Can anyone help me ID this?
    They call me......."threadkiller"
  • linksys1127
    • Sep 2016
    • 121
    Re: Sharp LC-55N620CU PSU 192020 help ID'ing a transistor
    I happen to have one of these on hand. GB1 is the marking. Here's the picture.
    • DXseekerMO
      • Feb 2018
      • 1119
      • US
      Shout out to linksys1127 and Hernando MS! Thank you for posting that, super stoked up you had that board!
      The placement of this and the other transistor in the circuit makes me wonder if the over voltage event originated on the main board?
      Thank you, I appreciate it!
      • linksys1127
        • Sep 2016
        • 121
        Glad I could give back! Good luck with your repair!
          https://www.shopjimmy.com/sharp-1920...led-board.htm#
          It is on the cold side, that section looks to be something to do with driving those two Opto N881, 891.
          Is it tested bad?
          Are you not getting the 12V and 18V standby Voltages?
          • DXseekerMO
            • Feb 2018
            • 1119
            • US
            It is on the cold side.
            Is it tested bad?
            Yes it's on the cold side and it does test bad.
              • DXseekerMO
                • Feb 2018
                • 1119
                • US
                Correct, no stand-by. There is voltage on the hot side tho. Only issue I saw on the hot side was up and down voltage on the rectifier diode, DC side.
                  Please clarify, are you saying the DC Voltage on the main filter cap is going up and down?
                  • DXseekerMO
                    • Feb 2018
                    • 1119
                    • US
                    Main cap voltage across is solid at 166V, but when I check directly across the DC side of the rectifier diode the voltage goes from 166v down to about 142V repeatedly.
                    Red probe on + side and black probe on - checked directly on the DC side of the rectifier diode pins
                    • DXseekerMO
                      • Feb 2018
                      • 1119
                      • US
                      Thank you!
                        The DC Voltage at the +/- leg of the rectifer bridge is pulsing dc since there is no filter cap, the + of the rectifier is fed to the anode of diode VD804, the cathode is the connected to the + leg of the filter cap.
                        So 166V steady if is fine for running the standby power supply section.
                        Is R818 OK? It should be less than 1 Ohm.
                        P/N of the SMPS IC N834?
                        Did you remove that transistor off board and tested it? Is it shorted between E and C pins?
                        • DXseekerMO
                          • Feb 2018
                          • 1119
                          • US
                          R818 checks less than 1ohm
                          N834 is 1271A, believed to be NCP1271, datasheet attached
                          I was unable to conclusively find a datasheet for either of those transistors. I'm having a hard time turning a the numbers on them in to a part number so I an get the right sheet.
                          The 1P transistor is directly short on the top center and lower left pins
                          EDIT/ADD: I checked the components near N834 and all appear to check OK in-circuit. The IC itself is not shorted to ground and ground is not shorted to any other pins
                          • R_J
                            • 9559
                            That GB1 is a TL431 reference ic
                            Using hot ground, check if you have VCC on N834 pin 6, Also check for aprox +160v on pin 8. Then check the base of V812, it should have +16 volts (VZ810 is a 16v zener)
                              RJ, great info.
                              • DXseekerMO
                                • Feb 2018
                                • 1119
                                • US
                                Thank you R_J, how did you translate the number on the IC to the number you gave me?
                                RJ, great info.
                                Agreed, for sure!
                                • DXseekerMO
                                  • Feb 2018
                                  • 1119
                                  • US
                                  N834:
                                  PIN6 is 6.6v to 11.1v up and down
                                  PIN8 checks just like across the rectifier diode, about 144v to 161v
                                  Base of 812:
                                  6.7 to 6.8v, up and down rhythmically
                                  • R_J
                                    • 9559
                                    Check R801,R887,R803, Are you sure that was the base of V812 you checked? AC3 comes from the + of the bridge rectifier.
                                    maybe check all 3 pins of V812
                                    See if this helps
                                    • DXseekerMO
                                      • Feb 2018
                                      • 1119
                                      • US
                                      See if this helps
                                      I am sure I checked the base of V812, verified with the datasheet. The other two pins of V812 check at 6.2v
                                      R801 = 628K in one direction and about 852K in the other
                                      R887 = 632K in one direction and about 852K in the other
                                      R803 = 628K in one direction and about 750K in the other
                                      EDIT/ADD: The schematic above shows R803 as 270K resistor. The one installed on my board has the numbers 684 on it, same as R801 & 807.
                                      After that series of resistors the test point has 6.8v and is mostly stable. At the first resistor that comes directly from the + of the bridge rectifier the voltage is up and down from 141V to 165V.
                                      • R_J
                                        • 9559
                                        Have you replaced N851 ? If it is still in circuit and shorted, it could be shutting down the power supply by turning on the optocpupler. If you don't have sot23-3 find a to-92 style and use it for now, most smps use them.
                                        "PIN6 is 6.6v to 11.1v up and down" That tells me the ic's startup cell is working, the ic should pulse the fet's gate and the fet should drive the transformer, this will give you the +20 volts on C819, so check that R821 & R823 are ok.
                                        Also check that you have +160 on the V807 Fet
                                        • michalk3777@gmail.com
                                          Sharp Hisense - LC-65N7004U Error codes
                                          by michalk3777@gmail.com
                                          Hello, looking for a list of error codes for this TV. made in 2020, its manufactured by Hisense under Sharp brand. No clicks, black screen, no sound, power light is on solid. When I press power, it blinks 5 normal blinks and 1 short. and nothing happens.
                                          Anybody has a list of error codes that might apply to this TV? I have not opened it yet.
                                          Regards,...
                                          12-15-2024, 09:20 PM
                                        • DrvLikHell
                                          Sharp (Hisense) LC-55p6050u - Flashing/dimming row of pixels
                                          by DrvLikHell
                                          Hello again! I have come back for some wisdom and hopefully for some guidance with this problem I'm having. The TV is a 4k 55" Sharp LC-55p6050u and the problem is every other line of the bottom 32 lines flickers out, comes mostly back, then flickers out again, and repeats this continually. The lines on the bottom right of the screen go out completely while the lines on the bottom left are affected so slightly that it's almost impossible to see it. There is a gradual gradient from appearing almost perfectly fine on the bottom left, to an obvious problem on the bottom right.
                                          The...
                                          02-05-2025, 01:44 AM
                                        • Coolgoodman
                                          Faulty Hisense 85Q6NAU TV
                                          by Coolgoodman
                                          85” Hisense TV
                                          Greetings,
                                          Request for Technical Assessment – Faulty Hisense 85Q6NAU TV
                                          Dear TV technicians of forum, I hope this message finds you well.
                                          I am writing to seek assistance regarding my 85-inch Hisense Smart TV, model 85Q6NAU, which is currently experiencing a fault. The unit is approximately two years old, and I am not sure if it has a warranty.
                                          I have attached a photo showing the issue for your reference. I would appreciate it if your experienced technician could kindly review the image and provide some insight...
                                          07-24-2025, 03:02 AM
                                        • ShahZaib Ghumman
                                          Can I Swap Screens Between Two Hisense 75” QLED TVs?
                                          by ShahZaib Ghumman
                                          Hey folks,
                                          I'm not a professional, but I do have a decent amount of knowledge when it comes to electronic repairs.
                                          A friend of mine recently bought a brand new Hisense 75” 4K QLED Smart TV (75E7NQTUK) but unfortunately, he cracked the screen just a few days later. Luckily, he had insurance and got a replacement right away but weirdly enough, the insurance company never asked for the broken unit back.
                                          So, I took it off his hands and figured I'd try to repair it myself rather than see it go to waste. I've been searching for a replacement screen but can't...
                                          03-25-2025, 10:59 PM
                                        • nono34
                                          Hisense stuck in Colors cycle like test pattern.
                                          by nono34
                                          I accidentally changed the project ID in the service menu of my Vidaa Hisense 100U7KQ TV. When I turn on the TV, the screen displays an RGB color cycle (test mode???). I contacted Hisense, and they sent me a usb_MTK_9618.EU.bin file, but it doesn't work. I can see that the USB drive is being read, and it flashes for about 10 minutes (the screen remains in the color cycle during the firmware reading), then the TV turns off and restarts, but still in the color cycle mode.
                                          I want to mention that the 4GB USB is formatted in FAT32 MBR. I've also renamed the file to...
                                          10-24-2024, 04:31 PM
