Sansui 55" LCD T V Model STY0955 (Backlight issue)
  • angelos
    • Dec 2012
    • 571
    • South Africa
    Hi Guys, i posted this message yesterday and now i cant find it anywhere on the forum so now i am going to repost.
    I have added pictures to assist in your understanding.
    Originally this set would come up bright and back lights would switch off intermittently. I opened up the panel and saw that all the LED's do come on but then at a point thy all just fade off. I checked around the PWM controller and at some point while measuring the LED's went dim. I can still see a blueish light emanating from the rear of the TV and am measuring 38.6V on the LED+ line with respect to chassis gnd. On the 6 LED- lines i get 1.6V.
    Would this indicate a failed power supply or can it be the back lights causing this dim light issue?
    I bought myself a LED backlight tester but i dont know if its a quality unit because it only indicates the LED voltage once connected to a LED string.
    I get LED's brighting up somewhat with a voltage indication of about 41V on the tester.
    My question is is it the power supply or the back lights?
  • angelos
    • Dec 2012
    • 571
    • South Africa
    Re: Sansui 55" LCD T V Model STY0955 (Backlight issue)
    Is there way to delete this post since i am the author?
      • 12206
      • U.S.
      If your backlights are blue they need replaced.
      • angelos
        • Dec 2012
        • 571
        • South Africa
        They have a blueish color when driven at very low voltage. When the power supply was working correct and i had removed the LCD to investigate this problem they where bright white. I am going to check what Budm asked for and then post the result on the duplicate thread. He wanted an oscillogram of the ADJUST pin. I was busy diagnosing the problem when the customer got all funny and requested me to close the set and he took it. Now after a month he brought it back so now i can continue my diagnosis. Check the other thread for the history.
          Please stay in this TV section instead of the power supply thread so I can easily keep track.
          So I copied your paost 1 and my reply here:
          https://www.badcaps.net/forum/showth...887#post882887
          Angelos:
          Hi Guys,
          This tv came in with a back light that used to switch off intermittently. After measuring around the PWM IC and i can confirm that i made NO SHORT CIRCUIT the LED's went quite dark and stayed like that. They barely shine!!!
          This is the readings i have,
          LED+ = 38.6V
          LED+ = 38.6V
          LED+= 38.6V
          LED+= 38.6V
          LED+= 38.6V
          LED+= 38.6V
          LED6- = 1.62V
          LED5- = 1.60V
          LED4- = 1.61V
          LED3- = 1.62V
          LED2- = 1.62V
          LED1- = 1.63V
          also the Adjust pin is 5.1V
          and BL-ON = 1.6V
          If i use a backlight tester and they all come on, not to say that they are not intermittent but the LED tester indicates a voltage of 41V on all six circuits and there is a blueish light emanating from the rear stand offs. I guess being biased slightly.
          Previously before these back lights went from intermittent off to permanently dim i did take off the LCD display and put power to see that all LED's came on nice n bright and then after a few minutes they just faded off. I then started fault finding around the PWM and that's what caused the failure of output voltage.
          Just to give you an idea i disconnected one of the LED- leads and put my Fluke meter in series to monitor the current and when i powered up the TV the backlights flashed and went off immediately. As if it did not like the fluke in series and i cant understand why.
          My question is, is it the back lights or the power supply?
          My reply:
          1) TV OFF, put meter probe on the the two legs of capxon cap C13 (100uf 100V).
          2) Set meter to 200V scale then turn on the TV while watching the meter to see how high it goes up to then wait 10 seconds to see how low it goes down to.
          3) Report the reading.
          • angelos
            • Dec 2012
            • 571
            • South Africa
            Hi Budm
            The test is as follows.
            Set on standby and i press the standby button,
            Initially the voltage goes to 30VDC and then peaks at 38.63V after a few seconds, 10 seconds thereafter the reading remains at 38.6V
            I added additional info you asked for previously.
            The picture DSC0018 is the ADJUST pin as measured on the plug CN1 at about 5VDC
            The picture DSC0019 is the BL-ON pin as measured on CN1 measuring 200HZ at about 5VDC
              Are you sure that you did not get the two control signal backward, the BL-ON should be steady Voltage that either LO (<1V), or HI >2.5v.
              The Dim may be PWM 200 Hz freq.
              Can you read the P/N of the LED power supply IC?
              • angelos
                • Dec 2012
                • 571
                • South Africa
                No, i double checked, what i can do is make a small video of me measuring those two pins and upload it to youtube. Would that be fine?
                The PWM IC is a AP3041. The datasheet is on the other thread i made together with the schematic of that power supply.
                  Please provide the link to the schematic of the power supply.
                  It is not here: https://www.badcaps.net/forum/showth...887#post882887
                  • angelos
                    • Dec 2012
                    • 571
                    • South Africa
                    Here it is again.
                    • angelos
                      • Dec 2012
                      • 571
                      • South Africa
                      I can confirm that the silk screen printing on CN1 is incorrect. It reads that pin 1 is Adjust and pin 2 is BL-ON but in actual fact they are swapped around. I followed the race and Adjust goes to pin 15 of AP3041 and BL-ON goes to pin 4 of the same IC.
                      I will now take oscillograms on the input pins of the PWM of both these voltages and post an update.
                      • angelos
                        • Dec 2012
                        • 571
                        • South Africa
                        This really confuses me but i traced out a simplistic sketch of the two inputs to the AP3041
                        Picture DSC_0020.jpg measured directly on pin 4 of AP3041
                        Picture DSC_0021.jpg measured directly on pin 15 of AP3041
                        I added a simple sketch of how i traced out the diagram. Hope this helps. I am dumb struck.
                        • angelos
                          • Dec 2012
                          • 571
                          • South Africa
                          What if someone has swapped the individual conductors on CN1's pin 1 and 2 around. This makes sense to me. Could swapping them around to test cause any damage? Since both are inputs to the AP3041 and the datasheet for the PWM IC shows that it can handle a range of voltage. I means the ENABLE pin is to switch on and off the PWM IC. Should it be doing that at 200Hz?
                            The EN pin needs to see stable high or stable low, if it is switching HI/LO the the IC will be turning on and off. So did some one work on this TV before you?
                            • angelos
                              • Dec 2012
                              • 571
                              • South Africa
                              Yes, the warranty seal was disturbed. Its night time now but in 8 hours i can work on this set. Can i swap those two wires? Have i got anything to lose?
                                Yes you can, you need to get EN control signal to be steady HI to enable the IC.
                                • angelos
                                  • Dec 2012
                                  • 571
                                  • South Africa
                                  Problem sorted out. TV working. Just monitoring to see for possible intermittent faults. Thanks BudM for your guidance.
                                    Thanks for the follow-up, I wonder why some decide to swap the control signal wires; it makes no sense to me and made me wonder what the original problem was.
                                    • angelos
                                      • Dec 2012
                                      • 571
                                      • South Africa
                                      The customer said that the back lights would switch off intermittently. The tv worked for 6 hours today without issue. In the mean time i found a bunch of dry joints on the AP3041 which i soldered. At least its sorted. Off topic i needed to order some speakers for a 55" inch LG TV. The price i got for the set is shocking.Close to $100.
                                      • alextuning15
                                        • Jan 2020
                                        • 9
                                        • VENEZUELA
                                        Hello, I have a problem with the PSU of the TV Haier 50 "same PSU as the Sansui model STY095, I have replaced all the LEDs, two mosfet aod4286, check resistors, checked filter / inflated capacitors and nothing. Measuring voltage on pin 3 of the ic ap3041 I have 1.65vdc, but I miss that when I place the tip of the fluke the LEDs turn on, thinking that it would be a false contact, I rectified the welding but the problem continues.On the board is present 5, 12 vdc but I have raised the 30vdc to 33vdc. Any other help would be welcome to solve the problem.
                                        • Cornito
                                          TCL 65C715 backlight issue
                                          by Cornito
                                          Hello team,
                                          I'm back with another topic.
                                          It's a 65C715 TCL tv with backlight issue.
                                          But the problem is a bit strange.
                                          When I took this tv from the marketplace backlight didn't work but picture was ok.
                                          Back at home I checked with led tester if led are alive and I can find something different in term of voltage supply => nothing
                                          Putting all back together the tv worked fine for weeks. => Contact issue??
                                          Few moment later the tv has started to have backlight issue back, turning off and on worked sometimes and tv was working....
                                          06-09-2024, 02:24 AM
                                        • thetonywarren
                                          TCL 43S435 NO BACKLIGHT ISSUE, LEDS TEST OK
                                          by thetonywarren
                                          I have a TCL 43S435 with no backlights. I contacted ShopJimmy and they said power supply. I got replacement power supply, but still doesnt work. I have confirmed that there is an image with flashlight test. I have also verified that the led strips work when I probe them with LED tester. Any ideas would be helpful. I am also geting a double blink on the status led when trying to turn it on......Nothing on the power supply looks suspect, and caps look ok. Where should I start to test......Thanks!...
                                          04-23-2025, 10:48 AM
                                        • shellybelly
                                          Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
                                          by shellybelly
                                          Back Story
                                          I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
                                          So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
                                          08-27-2023, 10:40 PM
                                        • Riananyaina
                                          MacBook A1708 820-00840-A backlight issue
                                          by Riananyaina
                                          Hello Everyone ,
                                          today I'm coming to you regarding my issue which is no Backlight .
                                          I have image on my screen but no light .
                                          The macbook was one that I bought few month ago that I used with an external screen . Now I started to do some analysis on the MB which my limited knowledge .
                                          First thing is that it suffered from liquid damage . The fuse was not ok when I openned it the first time . But I already changed it after testing that there is no short to ground on this line .
                                          Please find below few informations which can help for the analysis...
                                          04-24-2023, 05:03 AM
