TCL 43S435 NO BACKLIGHT ISSUE, LEDS TEST OK
  • thetonywarren
    • Feb 2013
    • 168
    I have a TCL 43S435 with no backlights. I contacted ShopJimmy and they said power supply. I got replacement power supply, but still doesnt work. I have confirmed that there is an image with flashlight test. I have also verified that the led strips work when I probe them with LED tester. Any ideas would be helpful. I am also geting a double blink on the status led when trying to turn it on......Nothing on the power supply looks suspect, and caps look ok. Where should I start to test......Thanks!
  • EazyBone
    • Jun 2023
    • 1353
    • United states
    Just because they light up doesn't mean there isn't a bad one. How many volts does it light up as? If a second power board didn't fix it I'd be looking at the lights. Sometimes one will light up dim with the led tester and then when under load from being plugged in it won't work. I'm gonna say this is what's happening here.
    But it's generally one of the other.
    Sometimes a diode goes bad and shorts out and can be the cause. I don't see them near your lights but can check this one also just to see.
    • thetonywarren
      • Feb 2013
      • 168
      When I tested the output to the LED strip, they were around 114V, that's for the ones installed in the set. I also checked the brand new set that I purchased as replacement, if needed. They were also around 114V.......I'll check the diode....
      • thetonywarren
        • Feb 2013
        • 168
        All diodes highlighted in red boxes checked out ok. I also tested the new led strip and it looks to be 114-115v when tested. Existing shows 114-115 as well.
        • lotas
          • Jan 2016
          • 4753
          • Russia
          The connector itself provides power for the backlight when turned on with the backlight connected and when the backlight is turned off.​
          • thetonywarren
            • Feb 2013
            • 168
            Yes, understood, this is what happens when I plug that connector in and try to power on the set. See video link below.
            https://youtube.com/shorts/dtmpVzL3umw
            • lotas
              • Jan 2016
              • 4753
              • Russia
              You can upload the video here, because we have problems with YouTube.
              • thetonywarren
                • Feb 2013
                • 168
                Try this video.
                Thanks!
                • lotas
                  • Jan 2016
                  • 4753
                  • Russia
                  Originally posted by thetonywarren
                  Try this video.
                  Thanks!
                  Yes, I asked about the voltage on the backlight connector, what it is with the backlight off and with the backlight connected, does it appear at all.
                  • thetonywarren
                    • Feb 2013
                    • 168
                    With the LEDs disconnected, there is about 44vdc. When you press power, it spikes to about 70vdc, but then immediately drops back down to approx 44vdc. This happens the same when the LEDs are connected as well.
                    • lotas
                      • Jan 2016
                      • 4753
                      • Russia
                      Then try simply soldering two wires to the new backlight, disconnecting the old one and check how the power supply behaves at the backlight output.
                      • KYBOSH
                        • Oct 2011
                        • 581
                        • Unknown
                        Is this a model where the LCDs light up with the mainboard is disconnected from the power supply (like samsungs)?
                        • lotas
                          • Jan 2016
                          • 4753
                          • Russia
                          No, I doubt it. The backlight itself or its wires to the TV case may short-circuit, and the backlight driver protection may be triggered.
                          • EazyBone
                            • Jun 2023
                            • 1353
                            • United states
                            KYBOSH I believe you can disconnect the ribbon to the t-con and the lights will come on. This is how I test Hisense.
                            But you need to hit the power button to turn the lights on which is usually attached to the back panel.
                            And lotas that's a awesome idea to solder those.
                            • nomoresonys
                              • 12276
                              • U.S.
                              Maybe look up the datasheet of that 16 leg IC, fortunately you have the same tv to compare it with.
                              • thetonywarren
                                • Feb 2013
                                • 168
                                I soldered two wires to the + and - of the new led strips and the power supply reacts the same wether it's connected to the pins or not. same result.
                                • Cornito
                                  TCL 65C715 backlight issue
                                  by Cornito
                                  Hello team,
                                  I'm back with another topic.
                                  It's a 65C715 TCL tv with backlight issue.
                                  But the problem is a bit strange.
                                  When I took this tv from the marketplace backlight didn't work but picture was ok.
                                  Back at home I checked with led tester if led are alive and I can find something different in term of voltage supply => nothing
                                  Putting all back together the tv worked fine for weeks. => Contact issue??
                                  Few moment later the tv has started to have backlight issue back, turning off and on worked sometimes and tv was working....
                                  06-09-2024, 02:24 AM
                                • Riananyaina
                                  MacBook A1708 820-00840-A backlight issue
                                  by Riananyaina
                                  Hello Everyone ,
                                  today I'm coming to you regarding my issue which is no Backlight .
                                  I have image on my screen but no light .
                                  The macbook was one that I bought few month ago that I used with an external screen . Now I started to do some analysis on the MB which my limited knowledge .
                                  First thing is that it suffered from liquid damage . The fuse was not ok when I openned it the first time . But I already changed it after testing that there is no short to ground on this line .
                                  Please find below few informations which can help for the analysis...
                                  04-24-2023, 05:03 AM
                                • Cornito
                                  Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
                                  by Cornito
                                  Hello Team,
                                  I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
                                  Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
                                  Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
                                  08-08-2024, 08:09 AM
                                • Tynan Dill
                                  by Tynan Dill
                                  Assuming...
                                  11-22-2024, 01:46 PM
                                • fuzzyrunner
                                  Samsung LN52B750U1FXZA - Backlight Issue
                                  by fuzzyrunner
                                  Hello All!
                                  So here is the issue I am having. When everything is plugged in as normal, the TV turns on and I get a quick flash of the backlight. After that the backlight never turns back on but the rest of the TV works fine. If I pull the PWM pin from the cable between the main board and power board the backlight turns on and the tv works "normally". If it is plugged in I get nothing. I did do a factory reset but that didn't solve my issue. When everything is plugged in normally I get .6v at start up and continues rise over about 10 seconds. (~.6v then ~.8v then ~1.8v...
                                  02-28-2024, 07:36 PM
