Working on this unit, I have check voltage to main board and are getting the 13 & 3 volts. I have check voltage to t con board and get 12v on first 2 and zero on last 2 pins. The unit does power on and has backlight but no Video or sound. I was just getting backlight but I have messed with ribbon cables on t con board and now I get some red lines on left side of screen.
sharp lc-60le640u
Re: sharp lc-60le640u
Replaced t-con for no change except to clear up the red line I caused, back to backlight but nothing else. I got some more reading from top of powerboard.
1- 12.1v. PNL 12v
3- -.009 GND
5- 13.1v UR 13.2v
7- 13.1v. UR 13.2v
9- .010. GND
11- .010. GND
13- 3.31v. AC_DET
15- 5.04v. BU 5v
17- 1.15v. PWM1
19- 1.3v. Dimmer
21- 1.15v. OFL
23- .000v. PWM2
Any suggestions from that, I can check the readings on the bottom if needed. I am not sure about 17 and 23. ThanksComment
Tcon is good. Panel is good. Sharp will fail if tcon cables are messed with while powered up. That's probably what happened. I suspect mainboard. Try heating up the mainboard with a hairdryer. probably bad bga under processor.Did I leave the soldering iron on?Comment
Could try a firmware update/reapply.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
somewhat expected (white).... is the white uniform when seen on both sides?
based on the card changes that you did so far, my guess would be a problem between the tcon and panel, potentially a smd component on the panel boards.
tracing the voltages from / at the tcon (labelled) and following those to the edge board might help.Comment
no problem... yes indeed they look ok. This appears to show that the panel itself is not a direct problem. However, some how the panel is not being driven.... either no signal or some operating voltage is not getting to the panel. Check the voltages on the tcon.Comment
See if you have voltage on each side of tcon fuse, negative meter lead on a ground.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
alas, you picture doesn't show any TPs unlike others... maybe the other side?Last edited by budwich; 02-19-2019, 07:31 PM.Comment
by ngmlI am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
This indicates an error in the communication between the outdoor and the indoor unit.
The outdoor unit is fine, so the problem is the indoor PCB.
The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
Does anybody have the schematics of this board,...2 Photos02-01-2025, 12:55 PM -
by petersorHi Folks,
I'm filling some downtime trying to resurrect a Sharp LC60E88UN. It was easy to find the service manual online, but it doesn't contain the schematic for the power board (Sharp RDENCA369WJQZ / Delta DPS-343AP A, Rev 01F) Power Supply Unit. I've looked everywhere I can think of using both part numbers and can't find it. Can someonee with access to this document share it?
Symptoms - no audio/video/backlight and blink code: 1 x power light followed by 1 x power and OPC lights together. Seems like a Lamp Error, but I'd like to check power supply components and... -
by nobbnobb1Hi guys,
Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...-
02-03-2022, 11:14 AM -
by advantThis thread is about trying to get an Universal Main Board to work with a Sharp TCON and panel.
I have a Sharp LC-46D85UN TV that has had a main board issue. Since this model is from 2009, I am not able to find an exact replacement of the main board. Instead, I decided to see if I can future proof this tv by getting a Universal Main Board (T53U21.2) from China to work with the Sharp TCON (CPWBX4291TPZA) and panel. The universal main board supports a 8 bit dual channel LVDS interface whereas the TCON requires a 10 bit dual channel LVDS input. I have modded the LVDS connector to match... -
by sefosterI have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
- Loading...
